Stereoscopic Player, HDMI and BitStreaming through Reciever?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-28-2018, 07:58 PM - Thread Starter
The_Nephilim1's Avatar
Quoted: 139 Post(s)
Liked: 36
Hey guys,
I just moved and I need to incorporate my PC room and Home Theater Room into 1 room.. So far all is well and I have my Home theater half setup..
Now, I was wondering since I have Stereoscopic player and a PC with a nVidia 1080GTX, I am trying to determing If I play 3D Blurays with Stereoscopic player on my PC, will I be able to I think the term to Bitstream the Audio to my Integra 40.3 Reciever from the nVidia card HDMI and have the HD Audio come through the reciver.
I tried looking on and doing searches and from what I can tell it should work but I am not 100% sure it will.. So basically here is my setup as is:
1. PC with a i5 7600K @ 4.8GHZ and a 1080GTX vid card.
2. Integra 40.3 Reciever
3. Optoma HD142x 3D Projector
4. PC has a Sound Blaster Z.
I was also thinking I could buy another Soundcard that would do the bitstreaming for me to listen to the HD Audio.. IF I am unable to use the nVidia card with an HDMI cable to bitstream how can I get the PC to use the HD Audio formats through the receiver??
My Humble HT: Integra 40.3 Audyssey Calibrated / Denon 1930Ci SACD/DVD-A Player / Sony 3600 3D blu Ray / Behringer iNuke 3000DSP / Mach 5 IXL 18.4 Subwoofer / Optoma HD142x 3D REady 1080P DLP Projector / 92" 16:9 Manual screen / miniDSP HD2x4
The_Nephilim1 is offline
post #2 of 7 Old 11-30-2018, 11:10 AM - Thread Starter
Quoted: 139 Post(s)
Liked: 36
OK I just tried getting this to work minus the HDMI connection.. It looks really funky with streaming of the video like a delay in the action..
I think I am going to try and just run from the Bluray player and receiver that looked perfect before.. I do have a fast PC but it looks a bit laggy or something..
thnx and I don't need help with this anymore..
post #3 of 7 Old 12-01-2018, 12:00 PM - Thread Starter
Quoted: 139 Post(s)
Liked: 36
Well I gave it some thought and since I am using a curved screen I am unsure what the image will look like from the Bluray player only.. I looked into a warping processer those things are really expensive..
So I am back trying to get my pc to work with the 3D blurays.. I am going to be able to hookup my gear soon and I can try the PC to HDMI hooked to the treciver to see if I can bitstream the HD audio..
post #4 of 7 Old 12-01-2018, 12:46 PM - Thread Starter
Quoted: 139 Post(s)
Liked: 36
Well I think I figured out why it looked laggy a bit in the 3D image.. MY PC is 3D vision capable and I had 3D vision enabled I turned it off and when I played the 3D Movie it looked fine at 1080P 60hz..
I just need to test if the Audio will bitstream from the nVidia video card to the receiver via HDMI.. I think I will get my Speaker cable Monday and the HDMI cable I will have to see if I can find one around the house somewhere..
So far so good I just hope it will be able to bitstream HD Audio to the receiver..
post #5 of 7 Old 12-02-2018, 08:52 PM - Thread Starter
Quoted: 139 Post(s)
Liked: 36
Well I just hooked up the bluray player and wow what a superior picture then the PC.. The image did not look to bent on the curved screen and looked good enough to stop trying to get the PC to work for the bluray..
I should get the speaker cable tomorrow and I will be better able to get the system working.. I should be setup tomorrow afternoon..
This is gonna work better then I thought..
post #6 of 7 Old 12-03-2018, 10:56 AM
3DBob's Avatar
Quoted: 1088 Post(s)
Liked: 587
Glad to see you got this worked out. I doubt the curved screen will make much difference. Bluray players are definitely the way to go for 3D, and it's also very important to have the right hdmi cable for 3D.
3DBob is offline
post #7 of 7 Old 12-03-2018, 11:08 AM - Thread Starter
Quoted: 139 Post(s)
Liked: 36
Well with the curved screen I was wondering if the image would be distorted to much to watch but it looked pretty good from what I could see..
I have the right HDMI cable just need to find it..
Reply 3D Source Components
