Best Method for 3D MKV Playback - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By Actionable Mango
post #1 of 18 Old 06-02-2019, 08:58 PM - Thread Starter
Joseph Clark's Avatar
Quoted: 281 Post(s)
Liked: 324
I'm trying to find the best playback system for 3D MKV rips. I have a couple of older Mede8er players, but they don't handle Disney seamless branching titles well. Using PotPlayer with a PC seems to work in limited testing, although I'd rather have a simple set top box instead of a full blown PC for the job. I'm using Plex now (with a Synology NAS), but the nVidia Shield I love for 2D movies doesn't support 3D. I thought I heard mention of a Raspberry Pi (utilizing Plex) that can play MKV 3D rips, but I can't find any solid info on it. Any ideas?
Joe Clark
Joseph Clark is offline
post #2 of 18 Old 06-03-2019, 02:34 PM
Actionable Mango's Avatar
Quoted: 333 Post(s)
Liked: 279
Seems like most people use the Dune or Zidoo media players, both of which will play MVC MKV.
I figured out how to process MVC MKVs such that they would play in my TV's native Plex application, so no external box was needed at all. This makes for very high usability. Unfortunately it is a lot of work on the back end.
Actionable Mango is offline
post #3 of 18 Old 06-03-2019, 04:09 PM
tomtastic's Avatar
Quoted: 1340 Post(s)
Liked: 597
Not sure HD audio would be supported that method. My Plex app is no longer supported on my TV's plus PS4 because they auto updated and now my server is too old so I went back to using a mac mini but just for 2D.
I can confirm my KDLINKS does not support MKV 3D files in MVC, only works with ISO files. MKV 3D support, probably best way is with PC. ISO method on my KDLINKS is pretty flawless as well as HD audio, only thing I need to get a bigger single volume since it won't play without stuttering with connected drive volumes. A design flaw of some kind because it should be fast enough over USB 3.0 or even 2.0. But that limits how many titles I can have on internal drive.
The easiest, bulletproof method with all 3D titles available (aside from playing from the disc) is when I was just ripping to half resolution files. I'm about ready to go back to that. Not looking forward to re-ripping my entire 3D collection though.
This line intentionally left blank.
tomtastic is offline
post #4 of 18 Old 06-03-2019, 04:25 PM
Quoted: 333 Post(s)
Liked: 279
I actually use the Zidoo box with ISOs. I found myself spending too much time going down rabbit holes, and dealing with media was becoming a hobby unto itself. I want to spend my free time watching the media, not installing/configuring/managing/optimizing it.
ryudoadema and Car67 like this.
post #5 of 18 Old 06-03-2019, 08:37 PM - Thread Starter
Quoted: 281 Post(s)
Liked: 324
Thanks, guys. I'll take a look at Zidoo and Dune. The Mede8er boxes work with iso or MKV files, and for most titles they're just fine with attached USB storage. Disney titles, though, don't play cleanly over the network or USB. I just discovered PotPlayer, and it supports 3D MKV MVC on my PC.
Joe Clark
post #6 of 18 Old 06-03-2019, 08:57 PM
zombie10k's Avatar
Quoted: 5684 Post(s)
Liked: 6272
Joe, hi how are you it's been a long time. I am still big into 3D and still collect every title I can find.
I have the Dune 4K Pro and the Zidoo Z9s. I would pick up the Zidoo, it's less expensive and handles the 3D MKV files well. I posted some info about it with 3D here:
https://www.avsforum.com/forum/39-ne...l#post57172388
zombie10k is online now
post #7 of 18 Old 06-03-2019, 09:26 PM - Thread Starter
Quoted: 281 Post(s)
Liked: 324
Funny. I just went looking for you with a search here on AVS and noticed you'd responded to my question.
I take care of my mom, so I haven't had much time to pursue tech the way I used to. But, I'm still into 3D, and I needed a project. I'll check out the link. Good to connect with some old friends here, like you and tomtastic.
Joe Clark
post #8 of 18 Old 06-07-2019, 07:40 PM - Thread Starter
Quoted: 281 Post(s)
Liked: 324
Thanks, Jason. I ordered the Zidoo Z9s, and it's working extremely well so far. Ironically, the only mkv files it seems to have a problem with are from my own original Blu-ray discs created in Sony Vegas. Commercial 3D and 4K mkv files are smooth as butter over SMB from a Synology NAS. That's the most important thing I was looking for in a box. I'm happy not to have to consider a PC for this purpose. Thanks for the help.
Joe Clark
post #9 of 18 Old 06-23-2019, 12:01 PM - Thread Starter
Quoted: 281 Post(s)
Liked: 324
Thanks, guys, for the info. I'm generally very pleased with the Zidoo Z9s. For its main purpose, it's excellent - that is, for smooth and reliable 3D MKV playback via SMB from my Synology NAS. It does have its quirks, though. The main one is that it balks at most (if not all) PCM audio playback. I get nothing. Secondly, it's inconsistent in how it handles multi-part discs and sequels. That's kind of a mess. It also seems a bit darker in video playback than the Shield.
Along with Plex and the Shield, and the Z9s, my bases are now covered. If anyone has tips on dealing with the issues I describe above, I'd appreciate the assistance.
As usual, I was able to find a quick answer from this community. Thanks again.
Joe Clark
post #10 of 18 Old 06-24-2019, 11:32 AM
Quoted: 333 Post(s)
Liked: 279
Probably best to ask here:
https://www.avsforum.com/forum/39-ne...96-soc-49.html
post #11 of 18 Old 06-24-2019, 07:43 PM - Thread Starter
Quoted: 281 Post(s)
Liked: 324
Thanks. I'll check it out.
Joe Clark
post #12 of 18 Old 08-01-2019, 11:56 AM
Liked: 0
Joseph,
I've never had an issue with 3d Disney titles through my Mede8er X3d 600 or 1000. I rip them in MakeMKV.
I just purchased an HDR TD10 and looking into Vegas to edit. From what you said, I am assuming you did not have any issues streaming your own original Blu-ray discs created in Sony Vegas through you Mede8er?
I am just a hobbyist who will dabble from time to time in editing 3d, is there any reason I should spend the extra to get newer that Vegas 14 Pro? I'm not even sure I need pro to author BDs, just looking into this.
thanks, Brad
3d4ever is offline
post #13 of 18 Old 08-02-2019, 12:02 PM - Thread Starter
Quoted: 281 Post(s)
Liked: 324
Hi, Brad,
I haven't been able to do much 3D editing the past few years, because of a move and family issues. I never upgraded past Vegas 13. It worked for me, although it could be flaky and crashed (and gave wonky results) more frequently than it should. My camera of choice was the JVC TD1, whose mp4 files Sony never got around to supporting. Edius supported those files natively, so I did all my main editing in Edius and rendered the final Blu-ray 3D at 24p in Vegas. Vegas did a good job of converting 60i to 24p, although I had to be careful not to include too much fast motion.
I don't recall having any issues with the old Mede8er boxes and my self-authored Vegas 3D projects. Both the Zidoo Z9s and the nVidia Shield with Plex see my own 3D projects (ripped to MKVs) as two separate 2D films in their GUIs. They're the only videos that are treated that way. All commercial discs show up as true 3D movies in the Z9s.
Joe Clark
post #14 of 18 Old 06-29-2020, 06:09 PM
Quoted: 252 Post(s)
Liked: 49
Hey guys,
I’m coming at this from the opposite side of things. Looking to enable 3D playback on a PC, preferably though Kodi DSPlayer or MPC-BE. Following the instructions I’ve found on the forums (installing the latest lav filters with the 3D option and installing 3Dfix) results in side by side 3d coming up, but the player doesn’t seem to make any effort to play back in frame packed mode. Is this still working for people? Any idea what I’m doing wrong?
filmgeek47 is offline
post #15 of 18 Old 06-30-2020, 09:54 AM
Quoted: 95 Post(s)
Liked: 51
Originally Posted by filmgeek47 View Post
Hey guys,
Not sure what 3Dfix is or does, but Madvr renders to frame-packed.
Roussi is offline
post #16 of 18 Old 06-30-2020, 10:26 AM
Quoted: 252 Post(s)
Liked: 49
So you claim I can't seem to get it do output as FP. 3D fix manager is a hack someone developed to allow the latest Nvidia drivers to continue to output 3D (Nvidia discontinued support some time ago).
post #17 of 18 Old 06-30-2020, 11:23 AM
Quoted: 95 Post(s)
Liked: 51
As I said on the other thread, apparently your source video is SbS, and MPC cannot convert these (and does not have to, as most 3D displays can do it); Stereoscopic Player can. Try a frame-packed video. I cannot advise on NVidia compatibility, as I am on AMD and old NVidia hardware/driver; all 3D works for me.
Roussi is offline
post #18 of 18 Old 06-30-2020, 11:30 AM
Quoted: 252 Post(s)
Liked: 49
MakeMKV rips from 3D blu-rays are always frame-packed, and the same files output as frame-packed from my raspberry pi. The issue isn't the file.
Reply 3D Source Components
