Help with 3D Setup - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By brazen1
post #1 of 11 Old 02-25-2019, 01:55 PM - Thread Starter
Liked: 0
Help with 3D Setup
This is one of those times I feel stupid.
I have a relatively new setup and everything except 3D works. I get the message "3D Experience Requires 3D Enabled Player and TV"
I have:
Sony UBP-X700 Player (firmware at latest).
Yamaha RX-V683 Receiver (firmware at latest)
Monoprice Blackbird 4K Splitter (powered)
Epson 5040UBe (wireless projector)
New high capacity HDMI cables.
Thinking that the splitter or the fact that I have a non-3D TV connected, I unplugged the TV from the Splitter. I also tried running the Sony player directly to the projector's transmitter (no splitter at all) just to see if I could get the video to work, no luck.
The Yamaha specs say that it supports 3D and does true pass thru (HDCP 2.2). Here's the data from their website:
Full 4K Ultra HD Support
This AV receiver completely supports the latest HDMI® standards. Thanks to transmission of 4K video at 60 frames per second pass-through, you can fully enjoy the high definition video quality of 4K without degradation. It also adheres to the HDCP 2.2 copyright protection standard for 4K video transmission. It also supports HDR (high dynamic range) Video including Dolby Vision™ and Hybrid Log-Gamma which provides incredible contrast, smooth tone and rich, bright colors. Furthermore it supports the wider color gamut of BT.2020 pass-through. This AV receiver is also compatible with 3D, Audio Return Channel and CEC for easy operation.
Everything worked just fine playing 4K UHD discs and bluray discs.
Am I missing a setup item in my Yamaha or in the Epson? I looked over the 3D setup items in the Epson and have it set to auto (tried 3D) too, same result.
Any help would be appreciated. Thanks All!
Mark Smolen is offline
post #2 of 11 Old 02-26-2019, 07:29 AM
3DBob's Avatar
Quoted: 1087 Post(s)
Liked: 586
Have you tried more than one 3D movie? This happens with some old bluray discs. You should always turn on the projector first. That way it will it will be visible to the X700. If you turn on the X700 first then the projector, it might not see the projector. If you are going through your receiver, then turn on projector first, then the receiver, then the x700.
In the X700 setup, put everything on auto, and make sure the 3D setting is on, not off. And set type of source to Projector. Also change the size of the screen to your actual screen size.
Try turning the X700 off, then on again--this sometimes works. Splitters can be an issue as I have discovered, so try to go directly to projector. Do you have a previous bluray player that has 3D, but not 4K? You might try to see if that works.
Many of us that go through receivers have had problems with 3D also. If it continues, I would try another cable. How long of a cable run do you have?
3DBob is online now
post #3 of 11 Old 02-26-2019, 08:27 AM - Thread Starter
Liked: 0
Thanks Bob.
I'm using a brand new 3D disc from the movie Passengers (came with the 4K UHD disc).
I will try the power-up sequences and check the settings--that is what I wanted to know...wasn't sure what to set it to.
Regarding the cables, I'm only running 5ft cables and they are all new high speed cables...I've tried swapping them around thinking I may have had a bad connection.
I'll post results...thank you!
post #4 of 11 Old 02-26-2019, 08:29 AM
Seilerbird's Avatar
Quoted: 207 Post(s)
Liked: 219
3D does not work on non-3D TVs.
LG OLED55C6P
Sony STRDH770, Sony UBP-X800, Sony PS3 160
2 - Polk TSi300, 1 - Polk CS10, 4 - Polk T15, 1 - Polk PSW125
Seilerbird is offline
post #5 of 11 Old 02-26-2019, 08:48 AM
brazen1's Avatar
Quoted: 614 Post(s)
Liked: 339
He's using a 3D capable PJ.
RonAlam likes this.
HOW TO - Kodi 2D - 3D - UHD (4k) HDR Guide Internal & External Players
W10 1909 / MPC-BE\HC / PotPlayer / PowerDVD 19 / DVDFab Player 3&5 / KODI 19 videoplayer
GTX960 4GB / RGB Full 4:4:4 / 8bit Desktop mode =60Hz / 10/12bit Video mode = Matched Refresh rates IE 23,24,25,60Hz
65JS8500 UHD HDR 3D / Denon S720W
brazen1 is offline
post #6 of 11 Old 02-26-2019, 09:17 AM
3DBob's Avatar
Liked: 586
I questioned that too until I realized he was using the splitter for both a regular non-3D TV and the Epson projector.
3DBob is online now
post #7 of 11 Old 02-26-2019, 09:55 AM
Seilerbird's Avatar
Quoted: 207 Post(s)
Liked: 219
I still don't think that will work.
LG OLED55C6P
post #8 of 11 Old 02-26-2019, 11:49 AM
3DBob's Avatar
Liked: 586
You are right. The splitter isn't going to detect the EDID coming back from the projector telling the X700 it's a 3D player. Also, I just realized he's going through wireless to the projector, and that is probably a one way communication, so @Mark Smolen needs to be directly connected with the projector.
3DBob is online now
post #9 of 11 Old 02-26-2019, 12:17 PM
Quoted: 75 Post(s)
Liked: 47
I would question the wireless link. It may just not have the bandwidth for HDMI 1.4. Recommend trying plugging in the HDMI cable directly into the projector.
Roussi is offline
post #10 of 11 Old 02-28-2019, 05:01 PM
Actionable Mango's Avatar
Quoted: 330 Post(s)
Liked: 276
Standard troubleshooting. Connect x700 directly to projector with HDMI cable and see if you get 3D.
If you don't get 3D, there is disc/settings/firmware/cable issue.
If you do get 3D, then the problem is one of the devices that you removed from the chain. One by one add a device to the chain (receiver, splitter, wireless adapter). When 3D stops working, you'll know which component has the problem. Depending on which component it is, it may have an incorrect settings, it might need a firmware update, or it may simply be incompatible.
One of the unfortunate aspects of HDMI+HDCP is that, even if every device is individually compatible and configured correctly, the sheer number of devices and even physical distances can cause various problems.
Actionable Mango is offline
post #11 of 11 Old 03-01-2019, 08:26 AM
tlogan6797's Avatar
Quoted: 155 Post(s)
Liked: 168
I have a somewhat similar issue with my wired Epson 5040UB and the Monoprice 4x4 4K matrix switch. I have an Oppo 103D and have to set it to force 3D...it no longer works when Oppo 3D is set to Auto. I can leave the projector set to Auto and it will recognize the 3D from the Oppo when the Oppo is in Force mode.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
Reply 3D Tech Talk
