One lens of 3D glasses is not working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-07-2019, 04:50 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
I have 5 Hi-SHOCK glasses and one of them is not working properly, for which I received a new one (I was buying 4). The right lens is not lightning properly and I would like to try fixing it. So I am asking for your suggestion what can I try to do or what could be wrong with it. Is it the connections, battery or is the lens itself?
I've attached photos, so that you can see what is the problem and what's inside of the glasses.
The first two ones are showing what's the problem, but not sure why non-working lens (right one) in the second picture looks more pinky, that's why I've put the firs picture as well, which I think is a better representation.
Third picture is glasses turned off, forth picture is normal working glasses, how it supposed to look.
And the last ones are inside of the glasses, non-working lens on those pictures is left, since the picture is taken in-front.
ID:	2637882   Click image for larger version
ID:	2637884   Click image for larger version
ID:	2637886   Click image for larger version
ID:	2637888   Click image for larger version
teidybugi is offline
Reply 3D Tech Talk
