How to convert 3D Blu ray to 2D - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By tomtastic
post #1 of 4 Old 12-27-2019, 05:56 PM - Thread Starter
Quoted: 1005 Post(s)
Liked: 283
Hello,
Is it possible to convert a 3D Blu ray to 2D?
Are there not two different images in frame packing? Which one would it extract?
With what software?
LE: MakeMKV can do it.
noob00224 is online now
post #2 of 4 Old 12-28-2019, 01:09 PM
brazen1's Avatar
Quoted: 625 Post(s)
Liked: 356
Just disable 3D and a frame packed iso for example will display in 2D.
HOW TO - Kodi 2D - 3D - UHD (4k) HDR Guide Internal & External Players
W10 1909 / MPC-BE\HC / PotPlayer / PowerDVD 19 / DVDFab Player 3&5 / KODI 19 videoplayer
GTX960 4GB / RGB Full 4:4:4 / 8bit Desktop mode =60Hz / 10/12bit Video mode = Matched Refresh rates IE 23,24,25,60Hz
65JS8500 UHD HDR 3D / Denon S720W
brazen1 is offline
post #3 of 4 Old 12-28-2019, 03:27 PM - Thread Starter
Liked: 283
I waned to reduce the size of the file as well.
post #4 of 4 Old 12-28-2019, 09:48 PM
tomtastic's Avatar
Quoted: 1283 Post(s)
Liked: 533
Generally you would get the left view, but this is not the correct way to rip 2D. The correct way would be to use the 2D disc. There are several reasons why. One, some discs use different gamma levels with 3D to compensate for the glasses this will differ between the 2D release and the 3D release. Other reasons could be they use floating windows which they use to fix edge violations. The floating windows could be on the left and right view so there's no avoiding it. And another big reason is on converted movies they create two views by implementing rotoscoping and painting, this is only for the 3D version not 2D.
Best to use the 2D disc for 2D.
rdlohr likes this.
This line intentionally left blank.
tomtastic is online now
Reply 3D Tech Talk
