3D Vision? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By russellhk
post #1 of 6 Old 02-25-2020, 03:56 PM - Thread Starter
scbesterman's Avatar
3D Vision?
Since NV dumped driver support for 3d Vision, has anyone gotten it working without having to use year-old drivers? Have 3x 27" 120Hz monitors and itching to get it working again.
Thanks in advance
scbesterman is offline
post #2 of 6 Old 02-26-2020, 06:28 AM
3DBob's Avatar
Quoted: 1140 Post(s)
Liked: 627
According to this, Nvidia still supports 3D and VR gaming with the new drivers: https://www.nvidia.com/en-us/geforce...-ready-driver/
I think you can still use the latest drivers and if you truly need 3D vision, you can load that driver separately.
3DBob is offline
post #3 of 6 Old 03-05-2020, 02:18 PM
steevo123's Avatar
Quoted: 203 Post(s)
Liked: 50
Not with the RX cards. Nvidia has no 3d support anymore.
Some guy
steevo123 is offline
post #4 of 6 Old 03-23-2020, 03:48 PM - Thread Starter
Yeah...nvidia stopped supporting 3d vision in April of last year (the article you linked is virtual reality not 3d vision). The last driver package to support it was 418.
Seems that step 1 in getting everything working is to add a 3rd 1080ti. My cards only have a single dvi-d port (@ 120Hz), the other ports only support 60 Hz. Do have another but have to see if it'll fit in the case and then psu becomes a little bit of a concern. 7940x (HT disabled) and 3x 1080ti's (cpu and all vgas overclocked) draw some power. Have a 1600watt psu and a couple calculators estimate 1400 watts so may be ok.
If I add the 3rd card so all 3 monitors get 120Hz signals, I'm thinking install driver package 418, reboot, install the newest driver package but do not select to perform a clean install. Should get 3d surround working properly but still have newer drivers?
post #5 of 6 Old 03-24-2020, 07:25 AM
3DBob's Avatar
Liked: 627
Sounds like a good test. In theory, it should work.
3DBob is offline
post #6 of 6 Old 04-22-2020, 01:04 PM
russellhk's Avatar
Quoted: 66 Post(s)
Liked: 39
For anything 3d vision, head over to MTBS3D - https://www.mtbs3d.com/phpbb/viewforum.php?f=105
There are many workarounds available. We all jumped ship to MTBS3D when Nividia updated (destroyed) their own forums a while back.
ryudoadema likes this.
russellhk is offline
Reply 3D Tech Talk
