Need a 3d player recommendation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-11-2020, 06:29 AM - Thread Starter
mikedrules's Avatar
I just installed a BenQ TH671ST 1080p Short Throw Projector and currently own a Oppo BDP-80. We'd really like to watch a couple of movies in 3d so I ordered DLP LINK eD Elite 144 Hz 3D Glasses. However, I don't think the BDP-80 supports 3D.
Can someone recommend a Blu-ray player to watch some 3D movies? I was hoping to not spend more than $300 and don't mind used.
The player would be hooked up to a soundbar (Sonos Beam) that is hooked up to the projector.
Thank you.
mikedrules is offline
post #2 of 3 Old 04-11-2020, 11:24 AM
DenisG's Avatar
Quoted: 103 Post(s)
Liked: 47
If you don't need 4K, you can get a cheap Sony 3DBD play like the BDP-S6700. I have the previous gen the 6500 and it work just fine. I also use the built in vudu app for vudu. 3D movies I own.
DenisG is offline
post #3 of 3 Old 04-13-2020, 05:39 AM
3DBob's Avatar
Quoted: 1140 Post(s)
Liked: 627
I second the S6700. Excellent for 3D and you get 3D window depth adjustment as well, and 2D->3D. Plus screen sizing. You can get these for less than $100 now. Don't spend anymore for something touted as being better. The S6700 was latest generation with 4K upscaling of 1080p as well.
3DBob is offline
Reply 3D Tech Talk
#3d
