Yamaha ysp-2200 not showing blue light for BR on "Into Darkness" 3D - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-30-2013, 07:07 AM - Thread Starter
nastymatt's Avatar
I have set up my Yamaha ysp-2200 with my PS3 to play BR discs, (set the output to Bitstream and ticked correct audio types). When playing "Into Darkness" in 3D the light on the soundbar was orange ie surround only.
Curious I put the 2D discs in and the blue light comes on.
So.. the same film with the same audio format dolby trueHD, 2D disc is fine, 3D is surround only. Any ideas???
(I have played other 2D BR and they play fine. I have played 3D discs but can not remember what the audio came out as.)
nastymatt is offline
post #2 of 4 Old 09-30-2013, 10:53 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4791
You're not the only one....it's the PS3, can't do 7 ch TrueHD via bitstream and 3d at same time. Some info here http://community.us.playstation.com/t5/PlayStation-General/PS3-No-Dolby-TrueHD-7-1-on-3D-Blu-rays-Playstation-3/td-p/38788291
nastymatt likes this.
lovinthehd is offline
post #3 of 4 Old 10-01-2013, 01:39 AM - Thread Starter
nastymatt's Avatar
Thanks for finding that. At least I now know it's not something I have done. Shame tho as it reads that Sony just need a firmware upgrade to enable this.
post #4 of 4 Old 10-01-2013, 01:54 AM
lovinthehd's Avatar
Liked: 4791
Someone pointed it out to me a while back in another thread around here somewheres, and I hadn't even noticed until I read about it, but did some experimenting and sure enough (although most of the 3d blurays I've got are DTS MA and not TrueHD so it wasn't real obvious). It came up recently in a couple other threads re STID so yours caught my eye. It doesn't seem Sony has any intention at this point of fixing it. Apparently the PS4 will not have this issue...
Reply Soundbars
Yamaha Ysp 2200 Digital Sound Projector Black
