GoldenEar SuperCinema 3D Array XL 5.1 System Official AVSForum Review - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 43Likes
post #121 of 134 Old 03-04-2017, 09:50 AM
Nick V's Avatar
Quoted: 310 Post(s)
Liked: 303
Current configuration:
WOLVERNOLE and Patriot666 like this.
Main System: Vizio P70 4K TV. Selah Vigore Speakers. KEF Q100 Rear L/R, Mirage BPS 400 LFE Sub. (2x)Rythmik FM8 Subs. Denon AVR-X4500H Receiver. Lyngdorf TDAI-3400 Integrated (2 channel). Oppo BDP-103. Zappiti Mini 4K HDR. GIK 242 Panels, Tri Traps, Monster Bass Trap. Various Vicoustic Desktop: Dynaudio BM6A mkII. Paradigm SUB10 w/ PBK. Cambridge DACMagic+ DAC. GIK 242 Panels, Monster Bass Trap Master Bedroom: Vizio M55 4K HDR. BG Radia In-Wall/Ceiling Speakers (5.2.2). NAD T758v3 Receiver
Nick V is offline
post #122 of 134 Old 03-21-2017, 07:26 AM
Liked: 1
I posted on "recommend me a soundbar" but thought it made sense to also ask here. I'm deciding between the GE SC3D X and Phase Tech Teatro TSB3.0. No Phase dealers nearby so unfortunately can't test drive both. Price is not the ultimate consideration, but I'm trying to gauge whether the Goldenear is effectively worth paying 50% more for. Couple details on usage:
- 70/30 home theater to music
- I will add a subwoofer but no other speakers
- Room size is 21x17 but the back of the room is entirely open (opens into kitchen)
Reviews for both products individually are very good but haven't found anything comparing the two so would appreciate thoughts from anyone that has had experience with both. Thanks!
nchan50 is offline
post #123 of 134 Old 03-21-2017, 01:25 PM
Quoted: 1887 Post(s)
Liked: 1084
I don't know about the Teatro TSB 3.0 but the Teatro PC3.0 I would definitely take over the GE.
Ellebob is offline
post #124 of 134 Old 03-21-2017, 01:48 PM
Nick V's Avatar
Quoted: 310 Post(s)
Liked: 303
Having lived with the 3D Array X for almost a year in my living room system, I can't recommend it highly enough. There is some "magic" built into the crossover and the outer l&r woofer that's designed to reduce "interaural crosstalk" between the front l/r channels, and it works!
When I close my eyes and listen to well recorded music on Tidal (HiFi) the stereo image extends well beyond the physical width of the speaker. Phase Tech makes good speakers (I haven't heard any of their soundbars) but to my knowledge, it's just 3 small speakers built into an enclosure. No "magic".
Mine crosses over to a Rythmik L-12 subwoofer at ~100Hz and sometimes I'm still in awe of what that system can do for the size (and price). My 3D Array X is in a living room that has 19' ceilings (open to two stories), has an open staircase leading to the upstairs, is open to the kitchen and dining area behind the couch and is open to the main hallway leading to the front entrance. In other words, not an ideal space. Together with the Rythmik L-12, this system can fill the area with sound, and it makes real music.
WOLVERNOLE and hingerson like this.
Nick V is offline
post #125 of 134 Old 03-21-2017, 02:11 PM
hingerson's Avatar
Quoted: 183 Post(s)
Liked: 64
You have the exact setup as me, 3D array X paired with a Rythmik L12 and I agree with you the sound is amazing and I also highly recommend!
Sent from my Pixel using Tapatalk
LG 65 B7A
hingerson is offline
post #126 of 134 Old 03-22-2017, 05:47 AM
Carldalynx's Avatar
Quoted: 13 Post(s)
Currently running SC3D XL with two Speedwoofer 10S, powered by a Denon AVR-X4300H. Our Sony 65Z9D stands on a console, with the GE under it. Had to raise the TV 3" to clear the soundbar. Also, angled the SC3D XL upward to direct it at the listeners' ear level. The soundbar is a perfect match to the 62" width of the TV console.
In our 30X16X9 family room, open to the kitchen and a hall on one side, the sound has been very clear and, at higher levels, the sound stage is very wide. The subs are in the front corners, one behind the TV, which sits in a corner and the other behind a large chair in the other corner. Surround is currently handled by a pair of antique Realistic bookshelf speaker that have upgraded crossovers, sitting on stands. They actually do quite well.
Crossover is at 120 as Sandy recommended and I have boosted the center channel a little to make speech clearer. The bass, with the two small subs, is enough to shake the floor and I have had to turn the boost down a bit to keep the wife happy.
After listening to just about every high end soundbar I could find, both powered and passive, I couldn't find a bar that had better sound quality. In our environment, the XL provides a broader soundstage and seems to have a cleaner center channel. I could not go with any of the Atmos bars, due to the corner location of the TV, the openings in the room and the beamed ceiling.
In addition, got the SC3D XL, in brand new condition, for less than half the retail price. That made my choice a no brainer. Oh yes, my support phone call was returned by Sandy Gross. Can't beat that for customer service.
I heartily recommend the Goldenear.
Carldalynx is offline
post #127 of 134 Old 03-22-2017, 07:31 AM
Liked: 1
Thanks everyone for the feedback, I was leaning towards the GE anyways so it seems like my decision is basically made up now.
nchan50 is offline
post #128 of 134 Old 04-05-2017, 07:57 AM
Liked: 1
Had a chance to listen to it this past weekend (and separately the Triton 5's) and was blown away.
nchan50 is offline
post #129 of 134 Old 04-05-2017, 08:03 AM
Justins123's Avatar
What's a good, relatively inexpensive AVR to pair up with the 3D Array XL? It sounds like Audyssey is not necessary, although 4k HDR support would be ideal.
Something like a Denon X2200? Or is that overkill?
Justins123 is offline
post #130 of 134 Old 04-05-2017, 09:28 AM
Nick V's Avatar
Quoted: 310 Post(s)
Liked: 303
I use a Denon AVR X3200 and it's not overkill. I still use Audyssey for the subwoofer and center channel in "bypass l/r" mode. Because of the crossover design, Sandy recommends against using Audyssey on the front l/r channels. I think he actually recommends against it altogether, but I still use it in "bypass l/r" with great results.
Nick V is offline
post #131 of 134 Old 04-30-2017, 08:23 AM
RolandOG's Avatar
Quoted: 287 Post(s)
Liked: 330
Post deleted
Sony A1E OLED | Yamaha RX-A1060 | Sony UBP-X800 | PS4 | ATV4
B&W 684 S2 | HTM61 S2 | SVS SB12-NSD
RolandOG is offline
post #132 of 134 Old 06-06-2018, 01:23 PM
Craer's Avatar
I've done a ton of reading on the 3D Array XL, it seems like the perfect fit to my problem, but this thread has been quiet for over a year. Has something better come along that I should look into?
I moved into a new house that I absolutely love, however the biggest draw back is the living room is horrible for audio/video. The only place to put the TV is above the fire place, the room is very large, opens to the kitchen, and a stair case to bedrooms upstairs. The ceilings are vaulted and at peak are about 15' high. The wife wants nothing to do with separate speakers and has requested in wall or a sound bar to accompany the room. Everything I have looked at seems to lead me to the GE 3D Array XL.
My current setup is the following:
Denon AVR 1913 (Will want to replace, need 4k passthrough)
Polk Monitor 60 Series II L/R
Polk Center
In Wall Proficient surrounds
Proficient M3 sub (In Wall)
Id like to replace the L/C/R with the 3D Array XL and look to replace the Denon 1913 as well. Any thoughts on what to pair it with? I think the surrounds are probably fine for now unless there is a reason to replace them. Any thoughts are more than welcome.
Craer is offline
post #133 of 134 Old 07-21-2018, 11:55 AM
Quoted: 2325 Post(s)
Liked: 1130
Polk Center
To answer your question... "Has something better come along that I should look into?" - not that I am aware of.
Shopping List:
TV: Samsung Q90R, or LG C9, or Sony ...
Blu-ray: Panasonic UB820, or Sony X800M, or Pioneer Elite LX500
Soundbar: Samsung Q90R, or Sennheiser Ambeo, or...
AVR and Speakers: Marantz 8012, or... and GE Triton Reference, or...
New24K is offline
post #134 of 134 Old Today, 10:53 AM
Patriot666's Avatar
Quoted: 134 Post(s)
Liked: 89
I just set up my new Supercinema XL yesterday sitting on my tv console. I need to raise my tv a bit for my remote to see the IR receiver on the tv, but that's an easy fix. I'm wondering if it would be a better idea to decouple the speaker using speaker isolation foam vs having it sit directly on the console. I like the foam idea because it would protect the speaker as well, and has a little lip in the front. Thoughts?
Foam:
https://www.amazon.com/ISOL8-Studio-...ateway&sr=8-23
This speaker sounds great by the way!
Patriot666 is online now
Reply Soundbars
frontpage , Goldenear , soundbar
