H450 Soundbar and Samsung H6400TV audio issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-18-2014, 05:45 AM - Thread Starter
pia2001slo's Avatar
Liked: 0
Hi everyone,
mine "problem" is as follows. I have external set top box (for viewing IPTV Chanells from my provider) and is hooked to soundbar via HDMI. Soundbar is connected via HDMI to TV HDMI2 (ARC). When i watch Tv program i have HDMI message on soundbar (or simetimes TV ARC) sound is good but i think too quiet, because when i play for example trailer from Samsungs smart function, loudness is almost 2 times higher and basses are realy kicking on the same volume on soundbar ??!! When i watch as stated and get louder sound only when i change input on soudbar to TV SOUNDCONNECT (i guess wirellesly).
But then again, the soundbar doesn't turn off together with tv (via HDMI this works flawessly)
any ideas ?
Janko
pia2001slo is offline
post #2 of 8 Old 12-18-2014, 08:23 AM
HDMI Guy's Avatar
Quoted: 177 Post(s)
Liked: 48
Originally Posted by pia2001slo View Post
Hi everyone,
any ideas ?
Janko
If you have an unused HDMI input on the TV connect the set top box to that.
HDMI Guy is offline
post #3 of 8 Old 12-18-2014, 11:49 PM - Thread Starter
pia2001slo's Avatar
Liked: 0
@HDMI Guy
the audio from IPTV will then be passed-through ARC HDMI to Soundbar ?
post #4 of 8 Old 12-19-2014, 03:40 AM
HDMI Guy's Avatar
Quoted: 177 Post(s)
Liked: 48
Yes
HDMI Guy is offline
post #5 of 8 Old 12-19-2014, 04:17 AM - Thread Starter
pia2001slo's Avatar
Liked: 0
and same if i let's say connect xbox to next free hdmi on TV or should i connect console (audio) separately to "optical in" on soundbar ?
post #6 of 8 Old 12-19-2014, 08:51 AM
HDMI Guy's Avatar
Quoted: 177 Post(s)
Liked: 48
It should work either way. I would try HDMI to TV. The sound should be just as good as the Smart function apps on the TV.
HDMI Guy is offline
post #7 of 8 Old 01-04-2015, 10:08 AM
raducanmihai's Avatar
Liked: 0
Did you try connecting your soundbar via SoundShare? I have a H450 soundbar and F6400 TV (last year model) and they ar paired together via SoundShare. I can use only one remote (TV remote) to turn ON/OFF the TV and the soundbar but for other settings (dimming, sound effect, etc) I have to use soundbar's remote. I see no difference in volume no matter what the source is and the quality is ok.
raducanmihai is offline
post #8 of 8 Old 01-08-2015, 01:31 AM - Thread Starter
pia2001slo's Avatar
Liked: 0
@raducanmihai
yes i did i while ago and everything went ok...sound is much better through Soundshare (loudness 10 EQ loudness 20 on TV ARC)
Reply Soundbars
