Yamaha YSP-1600 - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #121 of 128 Old 01-11-2018, 06:26 PM
Quoted: 1887 Post(s)
Liked: 1084
If you want it to turn/off devices and input switching CEC needs to be on. Like I said other features need to be on.
Ellebob is offline
post #122 of 128 Old 01-16-2018, 05:10 AM
Liked: 0
How do i enable de CEC on the Yamaha Ysp 1600 and on the Sony 55X8505C as well as the ARC on both?
Rui Fernandes is offline
post #123 of 128 Old 01-16-2018, 05:14 AM
Liked: 0
Yamaha ysp-1600
Originally Posted by Foxbat121 View Post
I don't think CEC on the cable box matters for ARC. Only the TV and sound bar ARC and CEC needs to enabled. Typically, both are disabled by default.
post #124 of 128 Old 01-16-2018, 05:22 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 487
Not sure about your TV. But on soundbar, you need to go to setup screen to turn it on.
Foxbat121 is online now
post #125 of 128 Old 01-16-2018, 08:54 AM
Liked: 1084
The TV it is called Bravia sync in the menus. It always takes me a minute to find it when I go through the menus.
Ellebob is offline
post #126 of 128 Old 01-18-2018, 09:16 AM
Liked: 0
Hi,
update 3.01 for Yamaha YSP-1600 done. Excellent sound, like we are in the movies........ thew only bad thing is no HDR Passthrough
post #127 of 128 Old 02-21-2019, 03:17 AM
Liked: 1
Hi all,
Would you get that soundbar in 2019?
My setup is LG tv with hdr and webos 4. (watching netflix and amazon video).
I also have Apple TV 4k.
Does that soundbar still good? Or are there other alternatives which are better now?
murph3699 likes this.
URI998 is offline
post #128 of 128 Old 08-05-2019, 07:42 AM
StevenC56's Avatar
Quoted: 571 Post(s)
Liked: 203
Trying to update the firmware from 3.01 to 3.1. Only getting the right 2 green lights to illuminate after 30 minutes. Anybody else have this problem? The soundbar will not respond to any remote control input, but I'm afraid to power it off and brick the unit.
JVC X750R Projector,Yamaha CX-A5200 Pre-Pro, Yamaha RX-Z11 Receiver, (Amps Only) Yamaha MX-D1 Power Amps x 2, Yamaha RX-Z1 (L&R Surround Channel Amp), Oppo BDP-103D BR, Panasonic DP-UB820 UHD, Pioneer Elite CLD-99 LD, Definitive Tech BP7000SC Mains, CLR3000 Center, BPVX Surround Sides&Backs, BPX F&R Presence, Martin Logan Abyss Front L&R Subs/Dynamo L&R Rear Surround Channel Subs, Infinity SSW-210 Center Channel Sub.
StevenC56 is offline
Reply Soundbars
yamaha ysp-1600
