Samsung HW-K850 & HW-K950 Dolby Atmos Soundbars - Page 157 - AVS Forum | Home Theater Discussions And Reviews
 1429Likes
post #4681 of 4987 Old 12-25-2018, 12:56 PM
Liked: 2
Originally Posted by WaterBottle View Post
Wanted to voice my opinion on the K950 and ask for help on a couple of things.
Question 1: Why does the sound bar constantly turn itself on and off? This happens when the TV is off. The “hello” and “d.in” messages seem to cycle probably 5-10 times an hour. Why? I thought maybe it was some type of idle power from the TV sending a data through HDMI, so I switched to optical and the same thing happens. Not the biggest thing in the world, but it is annoying.....
In mysterious way Samsung want it o be like this and nothing you can do. We are many how hate this and next Soundbar gonna be a Sony.
John Jensen 2 is offline
post #4682 of 4987 Old 12-26-2018, 04:05 AM
Liked: 5
Originally Posted by naustin View Post
See the earlier post, 4K HDR 30 fps is the max these inferior HDMI 2.0 ports can handle for video or gaming. It is in the Owners Manual under specs.
I assumed it was HDMI 2.0b, I thought there was no reason why the soundbar shouldn't work with games at 4K 60hz. I just want to watch HDR Blu rays in HDR with Atmos on my Xbox One X. Should I have gotten the Sony ST5000 instead?
Originally Posted by Viscious82 View Post
Get an hdfury integral 2 or avr key or a similar audio splitter to separate the video and audio signal coming from your Xbox. Ive both of these products with my xbox one x and K950 and it worked well. Full video at Xbox and full audio at the soundbar.
Sent from my SM-G960U using Tapatalk
I would rather not spend any extra money. I'm an AV noob so I really don't understand the use of the product you suggested. As I said above, I only want to watch 4K Blu rays with Atmos on the Xbox One X. My TV has two HDMI enhanced ports, one with ARC and one without. I already have 2 HDMI 2.0b cables ready for when the speakers come. Are you saying I need to spend more money in order to achieve what I want? I do not care about movies in 4K 60hz and the games that I play at 4K 60hz 60fps do not support Dolby Atmos anyway.
SliChillax is offline
post #4683 of 4987 Old 12-26-2018, 05:03 AM
Viscious82's Avatar
Quoted: 201 Post(s)
Liked: 62
If you only care about movies then you don't need the hdfury products that I mentioned. The k950 will reproduce the atmos sound if you connect the xbox one x directly to one of its hdmi inputs. The xbox converts audio to dolby atmos for everything your watching or playing on it.
What you will miss out on is 4:2:2 hdr video while playing games because the soundbar cannot handle that video format. You will have degraded image quality. The Hdmi audio extractors that I mentioned allow you to resolve the problem by separating the audio and video signals from the xbox one x so that you can connect the video signal directly to your TV and audio signal directly to the soundbar maximizing the quality of both. You don't have to buy the audio extractor it's optional.
Viscious82 is online now
post #4684 of 4987 Old 12-26-2018, 07:20 AM
2mchpwr's Avatar
hi all - need help with my combo getting Atmos to the soundbar when playing VUDU on my tv via my tv's smart app.
Vizio M75-E1 television. Only one input, Input 1 (ARC), supports HDMI 2.0a. Does this send the atmos signal to the k950?
When i use the Vizio smart app to connect to VUDU to get my 4k movies, i don't see the blue LED on the k950 to signify atmos.
So shouldn't i just hook up the vizio input 1 ARC to the HDMI ARC on the k950 and I should see blue LED? but its not working
Primary:
2017 Vizio M Series - 75"
Samsung HW-K950 (no ATMOS via ARC)
2nd room - TV Samsung PN64F8500
2mchpwr is offline
post #4685 of 4987 Old 12-26-2018, 09:47 AM
naustin's Avatar
Quoted: 2023 Post(s)
Liked: 1369
Originally Posted by 2mchpwr View Post
hi all - need help with my combo getting Atmos to the soundbar when playing VUDU on my tv via my tv's smart app....
Sorry no Atmos via ARC on the K950 which is a 2016 model. The new (2018) N950 does Atmos over ARC.
naustin is offline
post #4686 of 4987 Old 12-26-2018, 11:01 AM
2mchpwr's Avatar
thanks so much.
So the Vizio M series TV does send atmos signal out of its HDMI out ARC but the Samsung k950 does not recieve that signal via its HDMI ARC.
That really sux.
Any cheap workarounds?
2mchpwr is offline
post #4687 of 4987 Old 12-26-2018, 12:01 PM
naustin's Avatar
Liked: 1369
thanks so much.
That really sux.
No, but you can get DD+ (w/o Atmos) via ARC. Read back a bit, an xbox UHD player with built in Apps connected to HDMI 1 or 2 is probably the cheapest solution at about 200 USD and some here are knowledgeable.
I don't use an xbox rather streamers and a couple AV splitters (HDfury & an Oppo) into my K950 and P65-C1; an expensive kludge .
naustin is offline
post #4688 of 4987 Old 12-31-2018, 01:12 PM
PJO1966's Avatar
Quoted: 271 Post(s)
Liked: 79
I have a Caavo hooked up to the k850 and lately everytime I'm in the Caavo menus the sound bar input switches to d in. Is there any way to lock input to one source only?
PJO1966 is offline
post #4689 of 4987 Old 12-31-2018, 01:37 PM
naustin's Avatar
Liked: 1369
Try turning ARC off on your TV.
naustin is offline
post #4690 of 4987 Old 01-03-2019, 09:31 PM
PJO1966's Avatar
Quoted: 271 Post(s)
Liked: 79
Switching inputs on the TV did the trick.
I'm having an old problem pop up again. If I watch something on Netflix on my Apple TV and then switch to Amazon Prime, I lose audio. I need to toggle the input on the sound bar and then I'm good. It's happened every night this week. It's really annoying.
PJO1966 is offline
post #4691 of 4987 Old 01-04-2019, 04:08 AM
bobbino421's Avatar
Quoted: 1364 Post(s)
Liked: 885
Anyone with a Sony A9F or Z9F get Atmos with the K950 from the TVs internal apps? If so how do you have it hooked up?
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
Denon X4500H AVR
Klipsch 5.1.4 Dolby Atmos with Martin Logan 1000W SUB
bobbino421 is offline
post #4692 of 4987 Old 01-04-2019, 05:06 AM
Quoted: 49 Post(s)
Liked: 27
Unfortunately you can’t, nor with any other tv brand.
It’s a limitation from the sb itself.
bassem77 is offline
post #4693 of 4987 Old 01-04-2019, 06:52 AM
naustin's Avatar
Liked: 1369
Sorry no Atmos via ARC on the K950. The new N950 does however.
naustin is offline
post #4694 of 4987 Old 01-04-2019, 09:40 AM
Liked: 0
Unhappy
Hi there
I need help. I have an issue with this soundbar wich was working well until a couple of days ago.
My installation :
- TV LG OLED 55C6V
- UHD BR player LG UP970
The soundbar is connected to the UP970 via its HDMI audio output.
I first noticed the problem with the Netflix app from the UP970. No sound at all as long as the audio selected is in 5.1, but ok with stereo.
Then I tested some 4K BR and same problem with Atmos tracks : no sound at all (nor blue light on the bar). The DTS-HD or Dolby Digital tracks work fine but same issue with a Dolby True HD track.
I tested with another HDMI cable but didn't work.
I am confused.
Could you help me figure this out ?
nova44 is offline
post #4695 of 4987 Old 01-04-2019, 11:35 AM
Liked: 0
Turns out a reset of the soundbar (holding the settings button) solved my problem.
I am relieved.
nova44 is offline
post #4696 of 4987 Old 01-10-2019, 05:52 PM
2mchpwr's Avatar
pulling my hair out trying to get ATMOS to work on the soundbar.
I just bought the roku ultra and hooked it up with the HDMI cable that came with it to the HDMI input 1 on the soundbar.
From soundbar, use the ARC to the TV (vizio M-series).
when i hit info on the tv remote, top banner says HDR10 and 2160. shouldn't it say ATMOS and shouldn't there be blue LED on the k950?
its a 4k movie with atmos from VUDU.
any ideas?
Primary:
2mchpwr is offline
post #4697 of 4987 Old 01-11-2019, 03:39 AM
lparsons21's Avatar
Quoted: 161 Post(s)
Liked: 87
any ideas?
During play with that source it should show the blue light on the soundbar. The TV info won't show it as the Vizio M series doesn't know what ATMOS is.
I don't have a Roku so I can only ask, is there a setting on the Roku for Atmos support?
Lloyd
lparsons21 is online now
post #4698 of 4987 Old 01-11-2019, 06:33 AM
2mchpwr's Avatar
Thx...see the roku screens attached.
ID:	2509240   Click image for larger version
ID:	2509242   Click image for larger version
ID:	2509244   Click image for larger version
Primary:
2mchpwr is offline
post #4699 of 4987 Old 01-11-2019, 08:02 AM
naustin's Avatar
Liked: 1369
any ideas?
I never could get Atmos with my Roku Ultra plugged directly into HDMI 1. The problem is the K950 can not accept a HDR 4K signal @ 60Hz only 24 or 30Hz (see the specs). You can try setting you Ultra to HDR 4K 30Hz or use an AV splitter to just route audio to the K950. I use my Oppo to split the AV.
2mchpwr likes this.
naustin is offline
post #4700 of 4987 Old 01-13-2019, 06:36 AM
2mchpwr's Avatar
dude thank you so much. i would not have thought that a "display type" setting in roku settings would impact ATMOS.
i had the roku ultra on "auto detect" and it was detecting at "4K HDR at 30Hz HDCP 2.2" but NOT GETTING ATMOS.
So based on your suggestion, i went to "4K 30Hz TV" and ATMOS light popped on yay but how much is my video quality being impaired by not using "4K HDR @ 30Hz"?
Primary:
2mchpwr is offline
post #4701 of 4987 Old 01-13-2019, 09:08 AM
Quoted: 49 Post(s)
Liked: 27
All movies are at 23.976 hz 4:2:0 chroma so don’t worry.
For series and tv shows the impact will be invisible except maybe for sports (i said maybe depending on your sensivity).
Well for video games this will be another story....
2mchpwr likes this.
bassem77 is offline
post #4702 of 4987 Old 01-13-2019, 07:31 PM
gblhs's Avatar
Does the K850 support Apt X over bluetooth? If so, is there anything I need to do to enable it? I've been trying to find out, but can't seem to find an answer.
gblhs is offline
post #4703 of 4987 Old 01-14-2019, 07:21 AM
giantfan1's Avatar
I have a similar setup to 2mchpwr except tv is TCL. My soundbar, which I just picked up over the weekend (great deal), is HW-K850. The Roku Ultra automatically detected 4K HDR @ 30Hz, but I went back in and changed it to 4K HDR @ 60 Hz to see what would happen. Only have tried with Jack Ryan on Amazon Prime but it is still working for me and I get Atmos!
I am sure it has already been covered many times in this thread so my apologies but anyone have suggestions for favorite settings with speakers, subwoofer, equalizer, sound effect, etc? Movies and shows sound very good but it seemed off when playing the NFL game yesterday. I expected a much fuller sound coming from this beast compared to the smaller soundbar it replaced (HW-K360). On the NFL game the 360 sounded much more natural, especially the announcers.
giantfan1 is offline
post #4704 of 4987 Old 01-19-2019, 10:25 AM
naustin's Avatar
Liked: 1369
Started the new Season of the Punisher on Netflix. On the AppleTV 4K it is in Atmos.
naustin is offline
post #4705 of 4987 Old 01-20-2019, 05:34 AM
Liked: 5
Damn I'm loving these. Bought the K950 on Amazon for 800 euros because the package was slightly damaged and let me tell you these are a steal for that price. I just saw Sicario in 4K Blu ray and Atmos is amazing. Any movies that take fully advantage of Atmos? I wanna hear the sound bouncing from the top mostly.
post #4706 of 4987 Old 01-20-2019, 05:38 AM
Viscious82's Avatar
Quoted: 201 Post(s)
Liked: 62
Damn I'm loving these. Bought the K950 on Amazon for 800 euros because the package was slightly damaged and let me tell you these are a steal for that price. I just saw Sicario in 4K Blu ray and Atmos is amazing. Any movies that fully advantage of Atmos? I wanna hear the sound bouncing from the top mostly.
Try bladerunner the Final Cut.
post #4707 of 4987 Old 01-20-2019, 05:47 AM
Quoted: 49 Post(s)
Liked: 27
I got mine for a bit less and brand new also from amazon.
The sound in dts and atmos is really jaw dropping.
My film list for atmos :
- john wick 2
- first man
- mission impossible fallout (waw)
- mad max fury road
bassem77 is offline
post #4708 of 4987 Old 01-20-2019, 07:05 AM
bobbino421's Avatar
Liked: 885
Just got a Sony X700 Blu-ray Player and I’m getting Atmos from the Vudu app but not Netflix or Amazon? Anyone have this player with this sound bar getting similar or different results?
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
Denon X4500H AVR
post #4709 of 4987 Old 01-20-2019, 09:03 AM
naustin's Avatar
Liked: 1369
Netflix only supports Atmos on a few devices. https://help.netflix.com/en/node/64066
The only program on Amazon with Atmos that I know of is the Jack Ryan series (HDR version). Good luck.
naustin is offline
post #4710 of 4987 Old 01-20-2019, 10:31 AM
bobbino421's Avatar
Liked: 885
Others on the forum have reported getting Atmos from the X700 Netflix app and Amazon app and yes I’m aware Jack Ryan is the only Atmos show on amazon. I have no luck with this soundbar getting both Atmos and DV simultaneously! I know this bar has no DV pass through and won’t work with E-ARC! I was using a HD Fury Vertex with no luck either. I can only get Atmos from the Vudu app on the X700 and was hoping someone who has both X700 and K950 had and a definitive answer?
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
Denon X4500H AVR
Reply Soundbars
4096x2160 , HW-K850 , HW-K950 , hwk950 , Samsung , samsung soundbar , soundbar
