Samsung HW-K850 & HW-K950 Dolby Atmos Soundbars - Page 160 - AVS Forum | Home Theater Discussions And Reviews
 1429Likes
post #4771 of 4987 Old 05-09-2019, 07:38 AM
mulesqb's Avatar
I have been on of the lucky ones with my K950..no real long term issues. Had a Directv issue pop up yesterday. Since that was resolved my sub and rears aren't connecting. Been searching high and low on this thread to see if anyone had similar issues. haven't been able to find.
have tried unplugging main unit a few times and that hasn't worked. Did the ID set and that didn't work. any other suggestions?? Any help is much appreciated!
If you have to tell people how good you are, you're not as good as you think.
mulesqb is offline
post #4772 of 4987 Old 05-09-2019, 08:57 AM
naustin's Avatar
Quoted: 2023 Post(s)
Liked: 1369
Originally Posted by niccic View Post
What kind of audio splitter? I knew k950 convert lpcm in stereo also if source is lpcm 5.1
Many Tv channel on air for example (sat or dtv) are in lpcm 5.1, but only stereo in my k950...
I use an HDFury AVR-key to split the Apple's audio since the K950 doesn't pass Dolby Vision video. Generally you want Satellite boxes set to DD or bitstream or Auto. I know my latest Gen Hopper3 if set to PCM will only pass stereo. The Apple is the rare device that decodes to LPCM 5.1 with Atmos which the K950 handles fine w/o any adjustments.
naustin is offline
post #4773 of 4987 Old 05-09-2019, 09:03 AM
naustin's Avatar
Liked: 1369
Unplug everything and follow the install instructions. I believe its replug Main, the Sub, then surrounds. Check that the lights are blue indicating pairing. Last stop, contact Samsung Support.
naustin is offline
post #4774 of 4987 Old 05-09-2019, 10:14 AM
Quoted: 12 Post(s)
Liked: 1
I use my TV (Lg oled 65 B8) to view sat channels, connected to K950 with hdmi ARC. On TV I set dtv out AUTO and tv hdmi arc AUTO (not pcm).
Everything is stereo. Nothing is 5.1.
Netflix and Prime video app on Lg tv sound 5.1.
niccic is offline
post #4775 of 4987 Old 05-09-2019, 11:54 AM
naustin's Avatar
Liked: 1369
I think the issues are your Sat channels are broadcast as 2.1 not 5.1 or 5.1 PCM doesn't pass via ARC. Try setting DTV to digital or bitstream rather than auto since 5.1 PCM may not pass via ARC. You could also try DTV directly into HDMI 1 or 2 on the SB since I know LPCM 5.1 works this way (Apple example) as a test of whether DTV is sending 5.1. You could also try asking on a DTV thread.
naustin is offline
post #4776 of 4987 Old 05-09-2019, 06:46 PM
Liked: 2
LPCM 5.1 works fine coming from 4k apple tv to my k850 soundbar. I know it's working correctly because if I put in standard mode I can hear the center speaker working . Like naustin said I would check your cable box settings. Make sure it isn't set to stereo.
Sean Nielsen is offline
post #4777 of 4987 Old 05-09-2019, 11:06 PM
Quoted: 12 Post(s)
Liked: 1
I use Lg tv as sat tuner. K950 is connected with hdmi arc. I haven’t sat or cable box.
niccic is offline
post #4778 of 4987 Old 05-10-2019, 12:33 AM
naustin's Avatar
Liked: 1369
Are you using a DirectTV app or a coaxial connection into the Lg? Either way set DTV to digital not PCM.
naustin is offline
post #4779 of 4987 Old 05-10-2019, 01:26 AM
Quoted: 12 Post(s)
Liked: 1
I'm in Italy and I don't know what is Direct TV app
The antenna cable into my LG TV Oled B8.
I set DTV out to Digital.
naustin likes this.
niccic is offline
post #4780 of 4987 Old 05-11-2019, 10:59 AM
NJPapi1977's Avatar
Quoted: 397 Post(s)
Liked: 114
So I got extremely lucky and Best Buy had the K950 sound bar like new and when I mean like new it had the stickers on it. Only thing missing was the HDMi cable
I am loving the sound bar and for the price of 440 is a steal no?
But I have the ps4 pro connected and it wont do RGB if connected to the sound bar. It must only do optical if I want to connect to tv
Is the picture degraded bad if not using RGB on my QLED tv?
Also on ps4 pro do i select Bitstream Dolby and not Linear PCM for gaming and movies?
NJPapi1977 is offline
post #4781 of 4987 Old 05-11-2019, 04:29 PM
Quoted: 49 Post(s)
Liked: 27
At 440 it’s a real good price.
With the money you saved you can buy a splitter and send audio only to the k950 and keep full rgb on your ps4/tv.
In sound mode i use bitstream on my ps4.
bassem77 is offline
post #4782 of 4987 Old 05-11-2019, 05:30 PM
NJPapi1977's Avatar
Quoted: 397 Post(s)
Liked: 114
Can anyone link me to this splitter
post #4783 of 4987 Old 05-12-2019, 05:52 AM
Quoted: 49 Post(s)
Liked: 27
HDFury is one of the best if not the best.
You can also check on aliexpress it’s cheaper.
bassem77 is offline
post #4784 of 4987 Old 05-13-2019, 05:36 PM
NJPapi1977's Avatar
Quoted: 397 Post(s)
Liked: 114
Is this a good one? Can I have PS4 and xbox one x connected?
post #4785 of 4987 Old 05-13-2019, 05:39 PM
NJPapi1977's Avatar
Quoted: 397 Post(s)
Liked: 114
Also which sound mode is used when watching cable or playing ps4 pro and xbox one x?
Standard or Movie or Surround mode?
post #4786 of 4987 Old 05-14-2019, 05:52 AM
lparsons21's Avatar
Quoted: 161 Post(s)
Liked: 87
The best way to take advantage of the 950 if you have an Xbox One in the mix is to use a combination of the splitter and an HDMI switch that's capable of passing 4K video. The connections for that are:
1. Source device to the HDMI switch input. For instance I have my Tivo, AppleTV and FireTV connected to mine
2. Output of the HDMI switch to the splitter (HD fury or another one)
3. Video output of the splitter to the TV
4. Audio output to the Xbox One that is running the Dolby Experience app.
5. Xbox One HDMI out to the 950
What that does is give you real or faked ATMOS for all sources and really makes the 950 come alive.
Orrkis likes this.
Lloyd
lparsons21 is online now
post #4787 of 4987 Old 05-29-2019, 06:50 PM
PJO1966's Avatar
Quoted: 271 Post(s)
Liked: 79
Out of nowhere the K850 stopped talking to my Samsung TV. They were working fine yesterday. It appears HDMI-CEC is off on the 850 and nothing I do turns it back on again. I'm going to unplug it overnight.
So annoying.
PJO1966 is offline
post #4788 of 4987 Old 05-31-2019, 11:36 AM
Broncocap's Avatar
Quoted: 22 Post(s)
Samsung n850
Sorry if this is a dumb question just brought the n850 how do I know it’s playing atoms? It doesn’t display it on the sound bar when watching an atmos movie thanks
Broncocap is offline
post #4789 of 4987 Old 05-31-2019, 02:35 PM
bobbino421's Avatar
Quoted: 1364 Post(s)
Liked: 885
I have the 950 and believe the bars are identical in function it should scroll across the display when it detects an Atmos track! The other way to know is if you can get playback info from you device where the content is playing like a blue ray player.
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
Denon X4500H AVR
Klipsch 5.1.4 Dolby Atmos with Martin Logan 1000W SUB
bobbino421 is offline
post #4790 of 4987 Old 05-31-2019, 02:37 PM
naustin's Avatar
Liked: 1369
This is the K series thread try the N series thread https://www.avsforum.com/forum/195-s...lby-atmos.html
naustin is offline
post #4791 of 4987 Old 05-31-2019, 02:45 PM
bobbino421's Avatar
Liked: 885
I didn’t see that I guess maybe they not the same
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
Denon X4500H AVR
post #4792 of 4987 Old 05-31-2019, 03:08 PM
naustin's Avatar
Liked: 1369
Thought I read there is no blue Atmos light on the N series, I believe the Atmos led still scrolls across the bar but I would not say definitively.
naustin is offline
post #4793 of 4987 Old 05-31-2019, 06:57 PM
Quoted: 203 Post(s)
Liked: 125
Correct.
william06 likes this.
Nvidia Shield - Zidoo X9S - HTPC/MPC-HC
Oppo 203 - Samsung HW-N950 - SVS PB12-NSD 7.2.4
LG 86UH9500
ntxoa is offline
post #4794 of 4987 Old 06-02-2019, 11:06 AM
naustin's Avatar
Liked: 1369
I see Best Buy is now selling the 2019 Samsung HW-Q90ZA soundbar for 1699 USD. N950 is also still in stock.
naustin is offline
post #4795 of 4987 Old 06-02-2019, 12:08 PM
william06's Avatar
Quoted: 936 Post(s)
Liked: 521
See my quote on your comments in the N950 thread
naustin likes this.
Lg oled65G7P
Panasonic UB9000 . pioneer lx500 uhd blu ray players
atv4k 2nd gen cube, roku ultra 2019
Toshiba Xa2 HD-DVD
Samsung HW-Q90R ZA soundbar
william06 is online now
post #4796 of 4987 Old 06-02-2019, 01:28 PM
naustin's Avatar
Liked: 1369
Thanks for the comments. When the n950 drops more in price, I might replace my k950 just to get Atmos via ARC. Using an HDFury avr-key and my Oppo 203, allows me to get Atmos from my AppleTV and Roku, but it isn't a very user friendly setup.
naustin is offline
post #4797 of 4987 Old 06-02-2019, 02:02 PM
william06's Avatar
Quoted: 936 Post(s)
Liked: 521
I have really been enjoying mine and it was great to retire the avrkey
post #4798 of 4987 Old 06-03-2019, 05:17 PM
Quoted: 70 Post(s)
Liked: 35
So annoying.
My samsung tv and older samsung bar did this recently. I saw a thread that said to unplug the TV from the wall, wait a bit, plug it back in. I thought no way it would work, but sure enough my tv and soundbar started talking again. So weird, but I'd give that a try.
Mike Credelle is offline
post #4799 of 4987 Old 06-04-2019, 03:40 PM
PJO1966's Avatar
Quoted: 271 Post(s)
Liked: 79
What I ended up doing was unplugging both the sound bar and the TV, and then plugging the sound bar in first followed by the TV. That did the trick.
I've found that Caavo tech support will help you troubleshoot any device that's connected to their Control Center. They've been really helpful tracking down obscure things to try.
PJO1966 is offline
post #4800 of 4987 Old 06-10-2019, 07:08 PM
PJO1966's Avatar
Quoted: 271 Post(s)
Liked: 79
I'm losing my mind. How do I prevent the K850 from shutting down when a program is paused? I've done it before and can't find it in the manual.
PJO1966 is offline
Reply Soundbars
4096x2160 , HW-K850 , HW-K950 , hwk950 , Samsung , samsung soundbar , soundbar
