Samsung k650 issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-11-2016, 12:43 PM - Thread Starter
Liked: 0
Samsung k650 issues
I have a new Samsung K650 Sound bar, paired with two 360 R5's for rear speakers, all connected via WIFI. It was awesome for about two months, then a setting seems to have been switched. Now it is way too 'bassy', can hardly hear voices, while the special effects are way overpowering. Other small anomoly, when using TV remote to adjust volume, it used to read out on the sound bar display, and does not anymore. Not sure if linked or not. Anyone have any ideas?
Steve S. 1980 is offline
post #2 of 2 Old 11-17-2016, 08:48 AM
a_bob36's Avatar
Quoted: 18 Post(s)
Liked: 31
I just got this soundbar and will be pairing it with a couple 360 R1's (R5 not WAF enough). I have it paired with a new KS8000. When I adjust volume on TV, I never see the volume indicator on the soundbar. How are you connecting it to your TV? Also, you are sure you have not changed the sound mode on the soundbar?
*EDIT SOLUTION FOUND*
https://us.community.samsung.com/t5/...und/td-p/11954
Here is the simple fix that corrected the problem for me:
Got to Settings=>Sound=>Expert Settings and change the HDMI Audio Format from Bitstream to PCM.
a_bob36 is offline
Reply Soundbars
radiant 360 , Samsung , sound bar
