Klipsch R-10 or R-20B? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By drh3b
post #1 of 5 Old 07-30-2017, 01:59 PM - Thread Starter
Zen Traveler's Avatar
Quoted: 688 Post(s)
Liked: 686
I have a friend who is looking at these two soundbars and wonders if there is an $80 difference? I also would be curious if there is anything else comparable in the under $400 range? Thanks.
Zen Traveler is offline
post #2 of 5 Old 07-31-2017, 07:03 AM
drh3b's Avatar
Quoted: 2009 Post(s)
Liked: 3913
Consumer Reports tested a bunch of bars about two years ago, only 2 did better than mediocre in SQ, one was Sonos, but the other was the older version of this. Well under $300.
https://www.amazon.com/Samsung-HW-M5...K550+Sound+bar
You can add this to make it 5.1 A little over $400 total new, or less from Ebay or refurb.
https://www1.crutchfield.com/p_305SW...0S.html?tp=190
https://www.ebay.com/i/182636821430?chn=ps&dispItem=1
After I went to Crutchfield, I found out they had both on sale for $400 until August 12.
https://www1.crutchfield.com/p_305HW...g-HW-M550.html
Follow the prompts, and it will drop to $400 in the cart.
Klipsch didn't do well, but the ones they tested were lower models than the ones you were looking at, I think.
Zen Traveler likes this.
My World Beating System!
Spoiler!
drh3b is offline
post #3 of 5 Old 07-31-2017, 07:23 AM
drh3b's Avatar
Liked: 3913
As @Scars pointed out on the Klipsch thread, the R20 is on sale for $400 at Crutchfield, about 1/2 off, and the user reviews there for it are very good.
https://www1.crutchfield.com/p_714R2...nce-R-20B.html
Spoiler!
drh3b is offline
post #4 of 5 Old 07-31-2017, 07:35 AM - Thread Starter
Quoted: 688 Post(s)
Liked: 686
Thanks @drh3b --That was very useful information to consider.
post #5 of 5 Old 07-31-2017, 07:49 AM - Thread Starter
Quoted: 688 Post(s)
Liked: 686
Thanks @Schwa and I will post a link here to that recommendation: https://www.avsforum.com/forum/89-spe...l#post54558520
Originally Posted by Schwa:
The R-20B is definitely worth the premium. It's got a 10" vs 8" sub and 4 vs 2 midrange drivers. If he's not in a huge hurry the R-20B has popped up 2x in the last few months on woot.com for $279.
Another option is to track down an Icon SB-1 soundbar. It's basically the same thing as the R-20B minus Bluetooth.
Reply Soundbars
