Samsung HW-MS750 Soundbar & SWA-W700 10" Wireless Sub Hands-On - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 55Likes
post #331 of 341 Old 11-09-2018, 06:40 AM
Liked: 3
I came somewhat late to this combo but I can fully support more or less everything what Mark said.
I have tested a number of soundbars in the recent past, including Sony's HT-ZF9 (which sounds surprisingly bad to me given the overall positive reviews), Bose's ST300 (which has a serious HDMI bug and a sort of "Auto-Gain" function that cannot be disabled), Samsung's K950 (strangely balanced rear speaker levels, only correct in Atmos mode), plus some others.
I recently got a MS650 for a very low price that sits in the bedroom. I was surprised how good this thing sounds, even without a sub and especially for voices and music. So I have the MS750 a try for the living room and today I added the SWA-9000S rears (that I had already in use along with the MS650) and the SWA-W700 sub. And that sub really really makes a hell of a difference. With movies as well as with music, this set very clearly outperforms all other systems that I had here, including Samsung's K950. Yes, you do sacrifice Atmos, but it's exactly as Mark said (at least for me) - the advantage of Atmos can be used occasionally only, while the huge difference that this sub makes is present all the time.
One question I have: SWA-8500 and SWA-9000 - does anyone know if there are any other differences than the wireless dongle that is shipped with the SWA-9000? From what I can see, the speakers also also the base unit are absolutely identical. Since the SWA-W700 already comes with a wireless dongle, I am thinking about getting the (approx 50 bucks cheaper) SWA-8500, hoping that it will pair with the dongle from the SWA-W700 the same way as the SWA-9000 would and where I would have no need for the dongle that comes with it.
New Old Deuteronomy is offline
post #332 of 341 Old 11-16-2018, 05:48 PM
Shinee8888's Avatar
Liked: 0
I have ordered & waiting for my unit to arrive..
In the mean time, may I know if the smart mode function uses the 2 up-firing channels at all? What if I added the 2 rear surrounds, will smart mode uses them as well? I can't seem to find any info on this.. thanks for your help!!
Shinee8888 is offline
post #333 of 341 Old 11-16-2018, 05:59 PM
cydeweyz's Avatar
Quoted: 420 Post(s)
Liked: 402
Only Surround and Sports modes I believe. Smart mode interprets the source audio, then uses the appropriate channels.
cydeweyz is offline
post #334 of 341 Old 11-16-2018, 07:05 PM
Shinee8888's Avatar
Liked: 0
Thanks for your swift reply!!
So I guess if I only use smart mode, it will perform mostly like the ms650 then, since the top firing speakers will be idling.. quite a waste & not very smart..
How i wish I know the exact format that smart mode will output for a 2.0 or 5.1 source audio.. just like what we know for the rest of the sound modes..
post #335 of 341 Old 11-16-2018, 07:13 PM
cydeweyz's Avatar
Quoted: 420 Post(s)
Liked: 402
I posted a pic of that info some time ago. You’ll have to search back a bit though.
cydeweyz is offline
post #336 of 341 Old 11-20-2018, 03:11 PM
spyboy's Avatar
Quoted: 204 Post(s)
Liked: 150
In a previous post someone mentioned that the SWA 700 subwoofer uses a passive radiator. Passive radiator is closer to ported than it is to sealed. Everything I have read suggests that the SWA700 is sealed and does not use a passive radiator.
Can anyone clear this up for me please.
spyboy is offline
post #337 of 341 Old 11-22-2018, 07:09 AM
spyboy's Avatar
Quoted: 204 Post(s)
Liked: 150
I got the SWA W700 for $287.94 from BB after a price match with Amazon. I can probably set it up tomorrow or Saturday. The demo at BB was convincing.
cydeweyz likes this.
spyboy is offline
post #338 of 341 Old 11-22-2018, 07:29 AM
Quoted: 23 Post(s)
Liked: 2
Good deal
Sent from my Pixel 2 using Tapatalk
heyodee is offline
post #339 of 341 Old 11-29-2018, 08:48 AM
spyboy's Avatar
Quoted: 204 Post(s)
Liked: 150
Does anyone know if the SWA-W700 comes with a grill? We have a very inquisitive doggie that likes to chew on things
spyboy is offline
post #340 of 341 Old 11-29-2018, 09:58 AM
cydeweyz's Avatar
Quoted: 420 Post(s)
Liked: 402
It does not come with one so you would probably have to buy one. Or you can just turn this speaker side towards the wall.
cydeweyz is offline
post #341 of 341 Unread 02-14-2019, 06:08 AM
Quoted: 14 Post(s)
Liked: 3
Hey guys hoping you can assist me!!
I have purchased this soundbar (no subwoofer) and have also purchased a Samsung NU8000 tv. Both will be getting delivered today.
I will be connecting the soundbar to TV via Hdmi ARC ports.
My question is should I plug my PS4 Pro into soundbar or tv?
The nu8000 supports Dolby digital 5.1 via arc. I only have single soundbar setup (I will not be adding more speakers or subwoofer).
Given I only have the single soundbar, audio wise, will it make any difference if I connect the PS4 into tv or soundbar?
Also, what audio settings should I choose on PS4? LPCM or Bitstream Dolby/DTS? I know this soundbar only accepts 2.0 LPCM and I am just confused which setup/settings would be best.
Thanks in advance!!
Agent_009 is offline
Reply Soundbars
hw-ms750 , Samsung , soundbar , swa-w700
