Official Nakamichi Shockwafe 9.2 and 7.2 dts:x dual subwoofers soundbars thread - Page 192 - AVS Forum | Home Theater Discussions And Reviews
 1380Likes
post #5731 of 5749 Old 02-10-2020, 06:01 PM
Quoted: 61 Post(s)
Liked: 24
Originally Posted by thepacifist View Post
Hi All,
Looking for some help here.
SETUP
Xbox one x -> Nakamichi shockwave pro 7.1 (upgraded and verified FW33) -> Vizio M65
Issue - Xbox one doesn’t play anything - no streaming media’s, no games.
Just shows no signal on the TV.
I have 12 bit color depth selected on the Xbox. 12 bit (and 10 bit) color depth at least show me the Xbox menu. If I select 8 bit, I can’t even see the menu. In the video options of Xbox one x, all checkboxes are ticked.
I have checked the cable by directly connecting the Xbox one x to the tv and everything works fine.
I believe you have one setting that should be changed. You need to play around with turning a few things off.
stu5797 is offline
post #5732 of 5749 Old 02-11-2020, 09:12 AM
jjnbos's Avatar
Liked: 63
Originally Posted by Nack attack View Post
My tv is an lg6900 pub my specs say it doesn't pass dolby atmos through Can I just plug my cable box into the soundbar and arc out of the soundbar to the TV and will dolby atmos work for me this way for Netflix. I also have a Sony x700 DVD with the Netflix app would that work instead of going thru the cable box
I tried connecting my old TiVo to the Nakamichi and it was a disaster of intermittent sound , crazy sound bar crashes etc. On the other hand after connecting the TiVO directly to my LG C9, it all works great.
In short, TiVO direct to TV, TV on ARC (soundbar HDMI 1), and e.g. Apple TV 4k and Sony Blu-ray direct to sound bar inputs 2 and 3. Soundbar inputs 2 and 3 are the high speed aka "Atmos inputs" so be sure to use them! This works great. I was filled with anger until I got to this set up, now I love my Naka :-)
Vg247 likes this.
jjnbos is offline
post #5733 of 5749 Old 02-11-2020, 09:21 AM
In The Bay's Avatar
Quoted: 182 Post(s)
Liked: 46
Originally Posted by Jrodriguez559 View Post
Thanks for the reply yea i just got my soundbar back from Nakamichi it was at there facility for 2 months being tested. So yesterday i finally got it back hooked everything up directly to the soundbar and nothing seems to work correctly, but if i connect directly to TV HDMI everything goes back to normal and works over ARC. I will contact Nakamichi tomorrow and see what i can do or if theres any issues they know of.
My Vudu issue on Shield seems to have been resolved. I really did not do anything! I checked this morning and UHD was back, so was Atmos...
In The Bay is offline
post #5734 of 5749 Old 02-12-2020, 08:31 PM
Jrodriguez559's Avatar
Quoted: 17 Post(s)
Liked: 1
I will double check mine tonight to see if its fixed as well. I hope so because i still have atmos support through vudu when connected directly to tv but every other service(netflix, disney, prime) does not support atmos this way.
Jrodriguez559 is offline
post #5735 of 5749 Old 02-13-2020, 11:14 AM
Quoted: 17 Post(s)
Liked: 1
No luck with my Shield plugged in to HDMI 2. Still giving me "sd" quality on vudu and all streaming apps give error codes and will not play.
post #5736 of 5749 Old 02-13-2020, 04:26 PM
Liked: 2
Hi All,
SETUP
I assume you've tried the Nak's setup page for Xbox one x? I have the same set up and also using a Vizio. I had trouble to and one thing I had to do was change the input for Nak (arc) on Vizio to UHD (this is not default). Menu > Input settings > Nak (allow UHD). It also took multiple HDMI hand shakes as my Vizio & Xbox still had my old soundbar settings. Once that finally triggered, all the 4k started coming through.
clay50 is offline
post #5737 of 5749 Old 02-13-2020, 07:50 PM
Liked: 6
Originally Posted by ScottFern View Post
Is anyone having issues with a Roku Streaming Stick+ plugged into their sound bar? I am having issues with the Roku remote button pushes being recognized unless I put the remote on top of the streaming stick.....
The Roku needs to be connected to your TV, then, separate HDMI cable from your TVs arc to the sound bar arc
Vg247 likes this.
texastone is offline
post #5738 of 5749 Old 02-13-2020, 07:59 PM
In The Bay's Avatar
Quoted: 182 Post(s)
Liked: 46
I assume you already did the HDMI reset? Probably it is not an issue with the HDMI cable because things work fine when connected to the TV directly...
post #5739 of 5749 Old 02-13-2020, 08:10 PM
ScottFern's Avatar
Quoted: 142 Post(s)
Liked: 29
Interesting, I always assumed you had to plug the Roku into the sound bar if you wanted Dolby Atmos. But its best practice to plug the Roku into the TV? It makes sense though because the two TVs I've used Roku Sticks directly connected to the TV worked the best with communication to the remote.
ScottFern is offline
post #5740 of 5749 Old 02-13-2020, 08:12 PM
In The Bay's Avatar
Quoted: 182 Post(s)
Liked: 46
https://www.helpdesk.nakamichi-usa.c...re-stick-audio
"Connect Roku Premiere+ Stick to soundbar HDMI 2 or 3 (processing prioritized ports) with the a HDMI male-to-female cable extension."
post #5741 of 5749 Old 02-13-2020, 08:41 PM
Liked: 6
I have some questions
What is DRC? THE Choices are off, DRC 50 and DRC 100 and what is the best setting
What is SSE? and the best settings
What is PURE Direct and what is the best settings the choices are stereo, pure direct, native and neutral x
Thank you
Dynamic range control is the adaptive adjustment of the dynamic range of a signal. The dynamic range of a signal is the logarithmic ratio of maximum to minimum signal amplitude specified in dB. You can use dynamic range control to: Match an audio signal level to its environment.
See number 2 is my fav. Sounds sir to Dolby aurround
post #5742 of 5749 Old 02-14-2020, 08:13 AM
Quoted: 12 Post(s)
Liked: 1
Ok got my new girlfriend the 2019 9.2.4 and let me tell you OMFG. Absolutely the best soundbar on the market hands f*cking down!!!!!!!
Absolutely ridiculous dolby atmos experience
Had the Samsung q90r was very good, returned it and let's just look at it this way guys the nakamichi is like having sex with a porn star compared to most other woman. It's just a never forgotten experience
Thank you nakamichi you nailed it with this one!!!!!!!
Nack attack is offline
post #5743 of 5749 Old 02-14-2020, 07:31 PM
Eric Van Boven's Avatar
Quoted: 94 Post(s)
Liked: 68
I dont think its perfect but a great bar. Still some firmware bugs that need to be fixed. Hdmi cec needs some work, very wonky sometimes.
Eric Van Boven is offline
post #5744 of 5749 Old 02-15-2020, 07:25 AM
Quoted: 12 Post(s)
Liked: 1
In my opinion what sets this apart from all soundbars is 2 things the extra set of side surround speakers and for sure the 2 10" Subs a truly immersive and unforgettable experience
post #5745 of 5749 Old 02-15-2020, 09:00 AM
Movie78's Avatar
Quoted: 978 Post(s)
Liked: 297
Guys i have new Nvidia Shield and i can't seems to get Kodi Bitstream to work, all the audio codec is playing in PCM, can some one help me.
Movie78 is offline
post #5746 of 5749 Old Yesterday, 11:21 AM
DeeL2003's Avatar
I'm having audio issues with Plex on the Nvidia Shield. Everytime I pause, FF, Rew, etc I would lose audio. It seems like the soundbar would freeze for a few minutes or longer. I have to exit Plex and go back in to get the audio back. This seems to happen with either DTS-HD, True HD, Atmos.
DeeL2003 is offline
post #5747 of 5749 Old Today, 11:51 AM
Brainodo's Avatar
I have issues with Plex too. Menu sounds work fine but in order to get audio on a file, I need to switch inputs and back.
Brainodo is offline
post #5748 of 5749 Old Today, 02:22 PM
murali_v_2000's Avatar
Get the 8.0.3 update for Shield. In Nvidia Shield, set "Auto" in Advanced Audio settings. Inside kodi, goto Audio settings (In Advanced Mode) and enable "pass-through" mode. Now Nvidia Shield running Kodi will pass bitstream for the Naka to decode. BTW connect Nvidia Shield to HDMI2 or HDMI3 of Naka.
murali_v_2000 is online now
post #5749 of 5749 Old Today, 02:26 PM
timgrady's Avatar
Quoted: 25 Post(s)
Liked: 35
I'm using PCM output on my Tivo. I fixed all of the sound issues with the Nakamichi. When it was bit streaming, the constant changes between PCM, DD, 2.0, 5.1, etc. really threw off the sound bar. No issues with my BluRay player, TV's ARC, or ATV4k.
Ttim
timgrady is online now
Reply Soundbars
button* , nakamichi shockwafe , nakamichi soundbar
