Sony HT-ST9 subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-16-2018, 06:23 AM - Thread Starter
jrmauric's Avatar
I bought a used Sony HT-ST9. it did not come with a subwoofer. I cannot find anywhere the subwoofer model SA-WST9 used that fits with the HT-ST9. Can anybody tell me if I buy a used Sony wireless subwoofer lets say step down model like a Sony CT780, will it pair with the HT-ST9 sound bar if I try? I know I would probably lose some sound quality from the smaller subwoofer, but would it work? Sony tech says no it will not work it has to be paired with the original soundbar, I would expect him to say that but will it really work?
jrmauric is offline
post #2 of 6 Old 01-17-2018, 12:22 PM
Quoted: 25 Post(s)
Liked: 8
That information is true. I would not have bought that unit without the sub
dwest1023 is offline
post #3 of 6 Old 01-17-2018, 12:42 PM - Thread Starter
jrmauric's Avatar
Thanks so much for your response.
jrmauric is offline
post #4 of 6 Old 01-18-2018, 05:24 AM - Thread Starter
jrmauric's Avatar
Has anybody ever tried pairing a different model number of subwoofer HT-ST9 and were successful. If not why will it not work. different frequency?
jrmauric is offline
post #5 of 6 Old 01-20-2018, 05:53 AM
winb83's Avatar
Quoted: 39 Post(s)
I believe you could probably use a HT-ST7 or 5 sub with it. I have the 9 and 7 and they use the same wireless module.
winb83 is offline
post #6 of 6 Old 01-20-2018, 08:20 AM - Thread Starter
jrmauric's Avatar
Thanks so much for the information!
jrmauric is offline
Reply Soundbars
