Samsung HW-N950 Soundbar 7.1.4 Dolby Atmos - Page 44 - AVS Forum | Home Theater Discussions And Reviews
 1004Likes
post #1291 of 3140 Old 10-06-2018, 01:15 PM
SkyYYZ's Avatar
Quoted: 267 Post(s)
Liked: 205
Like, if it was compressed audio, why would they output it as multi-channel LPCM and not just use Bitstream to handle the compressed audio? To my knowledge, high quality, multi-channel audio takes very little bandwidth.
I hope I don't seem argumentative (sometimes it can come across that way through the keyboard), I'm just confused as to why Apple is suggesting the opposite of what seems to be otherwise common knowledge, from somewhere...
SkyYYZ is offline
post #1292 of 3140 Old 10-06-2018, 02:30 PM
Quoted: 27 Post(s)
Originally Posted by lukather101 View Post
So can someone confirm if the new firmware us ok to download?
I’d like to know this too. Cheers
Badgerslayer7 is offline
post #1293 of 3140 Old 10-06-2018, 03:33 PM
Liked: 0
Hi ! I'm very interested by this soundbar, but I'm affraid with all the issues everybody describes.
I would like to connect my Apple TV 4k and my PS4 to the n950 soundbar, and the soundbar to my LG OLED C7. Is this configuration secure ? Or is this configuration subject to issues ? Is it possible to switch on/off the ATV + soundbar + TV only with the ATV remote ?
Thanks!!
benjiaddx is offline
post #1294 of 3140 Old 10-06-2018, 05:48 PM
Quoted: 203 Post(s)
Liked: 125
Originally Posted by SkyYYZ View Post
I guess my only remaining question is actually related to the ATV 4K: When directly connected to the N950—the way I'm going to rewire it—the ATV 4K is, in fact, sending lossless ATMOS to the N950 is in not?
ATV 4K sends Atmos as Dolby PCM/MAT.
See page 12:
https://www.dolby.com/us/en/technolo...me-theater.pdf
The K950 and N950 know how to generate Atmos audio from that.
Some devices don’t pass through PCM/MAT.
This came up for some of us that tried to send Atmos audio through our Oppo 203 Hdmi input to our K950. TrueHD and DD+ Atmos from our Nvidia Shields, Xboxes, and HTPCs worked. But PCM/MAT from the ATV, Xbox, and HTPC did not, and had to go directly to the sound bar.
meles and SkyYYZ like this.
Nvidia Shield - Zidoo X9S - HTPC/MPC-HC
Oppo 203 - Samsung HW-N950 - SVS PB12-NSD 7.2.4
LG 86UH9500
ntxoa is offline
post #1295 of 3140 Old 10-06-2018, 08:40 PM
UnfoldingSquid's Avatar
Quoted: 569 Post(s)
Liked: 367
That was my understanding as well. Seems pretty clear-cut and why question it, but Apple's explanation of its ATV 4K audio format is conflicting (and confusing) when they say:
"Audio will be decoded and sent to your equipment as uncompressed multichannel LPCM." (see image attachment above).
Does that mean that it streams compressed audio but then doesn't further compress it with Bitstream? Bitstream isn't an option on my ATV 4K.
I don’t know what they’re playing at. I suppose it’s possible if you had local content on the ATV that it wouldn’t be compressed, but all streaming services use compressed audio. Maybe ask around in ATV thread?
Samsung 75Q9FN
Samsung HW-N950
Samsung UBD-M9500
Samsung 55Q80R - Bedroom
UnfoldingSquid is offline
post #1296 of 3140 Old 10-07-2018, 12:11 AM
Liked: 0
What's the best way to connect this soundbar to a PS4 Pro? Optical or just use the HDMI that's connected to the TV?
Sc4r is offline
post #1297 of 3140 Old 10-07-2018, 12:42 AM
Quoted: 18 Post(s)
Liked: 3
Originally Posted by meles View Post
I own and use both Roofull 5x1 switches with my K950. This one:
is usually pretty good.
Their older one:
can get cantankerous and has a reputation for this. I usually can just turn it off with the remote which takes several attempts in my system as it wants to turn right back on. Usually once you have it off all the way it does seem to recover it. You can try unplugging the units. Hopefully the N950 is an improvement, but once in a blue moon I have to unplug the soundbar from the wall for 10 seconds or so if it won't accept Atmos.
What is the difference between these switches, I ordered the older version, should i return and get the new one?
meles likes this.
manny9 is offline
post #1298 of 3140 Old 10-07-2018, 04:04 AM
SkyYYZ's Avatar
Quoted: 267 Post(s)
Liked: 205
Fair enough, thanks for your thoughts. I'm just going to go with lossy Atmos is distributed to ATV 4K streaming movies from Apple, and that it uses uncompressed LPCM to deliver that audio to our AVRs/soundbars for maximum compatibility with all set ups. I appreciate your insight and will definitely check out the ATV owner's thread for more information.
I'll try one last time to get my TV to recognize the DD+ signal from the ATV 4K so that I can take advantage of ARC to free up a port on the N950. Failing a successful DD+ link between the two devices, I'll direct-connect ATV 4K to the soundbar again and accept it for now.
All this because I was stoked about having a free port on the N950 Too good to be true—d'oh!
SkyYYZ is offline
post #1299 of 3140 Old 10-07-2018, 06:38 AM
Quoted: 569 Post(s)
Liked: 367
Just because the TV and the soundbar support DD+ over ARC doesn't mean the ATV does, I'd say another question for the ATV thread.
Samsung 75Q9FN
Samsung HW-N950
Samsung UBD-M9500
post #1300 of 3140 Old 10-07-2018, 06:44 AM
SkyYYZ's Avatar
Quoted: 267 Post(s)
Liked: 205
Agreed. Again, thanks for your input.
SkyYYZ is offline
post #1301 of 3140 Old 10-07-2018, 11:10 AM
Quoted: 52 Post(s)
Liked: 0
So,
was really looking at n950.
Here's the problem:
Wifey really does not want any rear surround speakers on floor!
I really only see the n950 rears, that also have a upfiring speaker, mounted on stands behind seated position.
So, not sure what to do?
She'll let me have in-ceiling rears or I can have speakers mounted on side wall or ceiling but not in-ceiling.
Options?
andylewisdvm is offline
post #1302 of 3140 Old 10-07-2018, 11:16 AM
Quoted: 203 Post(s)
Liked: 125
Options?
On either side of the seating area can work.
How far are the side walls?
Can you exchange the wife?
meles, sovereignstar and New24K like this.
LG 86UH9500
ntxoa is offline
post #1303 of 3140 Old 10-07-2018, 11:38 AM
Quoted: 52 Post(s)
Liked: 0
Can't.
It's a great room and the sofa is a L-shaped looking at TV with a cabinet/buffet type counter riding along one entire wall on one side. So, definitely, can't put on sides.
Technically, side walls are about 14' apart.
I think images rotated. Ignore current tv position. We are having a entertainment unit built along the back wall, and then the L shape sofa will be rotated and aimed at back wall.
A wireless sub-woofer will be placed at front right corner.
going with soundbar obviously. tv has to go over fireplace. Another WAF.
images attached of room in construction
Name:	tv room 1.jpg
ID:	2465298   Click image for larger version
Name:	tv room 2.jpg
post #1304 of 3140 Old 10-07-2018, 01:57 PM
Gary J's Avatar
Quoted: 831 Post(s)
Liked: 384
So,
Here's the problem:
Options?
oh I don't know, maybe man up.
New24K and vicdvp like this.
Gary J is offline
post #1305 of 3140 Old 10-07-2018, 05:51 PM
jincuteguy's Avatar
Quoted: 89 Post(s)
Liked: 4
So how is this N950 compare to Sony Z9F and LG SK10Y? which one is superior in term of Atmos effect
jincuteguy is offline
post #1306 of 3140 Old 10-07-2018, 06:27 PM
Dime04's Avatar
Thanks!!
I have a similar setup to what you're asking about.... I have my ATV4K connected to the N950 and the N950 connected to an LG OLED B6. It works great with no issues! I get Atmos sound and Dolby Vision from the apps that support it. The ATV4K remote will also control the volume on the N950. When I put the ATV4K to sleep it shuts down the N950 and the TV and will also wake up both when the ATV4K is turned back on.
I don't have any experience with the PS4 though but I have a UHD Blu-ray player connected to the N950 as well which works with no issues.
Hope that helps.
Dime04 is offline
post #1307 of 3140 Old 10-07-2018, 06:39 PM
Liked: 3
I can't speak for the sony (Although I've read atmos effect isn't great due to the lack of physical overhead drivers) but my parents own the sk10y and I have to say the samsung is far better if only for the fact that it's a .4 setup instead of just a .2.
In terms of raw sound quality I don't really like the SK10y. The vocals always sound so muddy and boomy despite increasing the centre channel level in settings to stop them being drowned out in action scenes.
I love my n950 for sound quality. At least for what it is anyway.
Aussierox is offline
post #1308 of 3140 Old 10-07-2018, 06:39 PM
Quoted: 2693 Post(s)
Liked: 1338
If you go back one page and read, you will have your answer
Also every professional review I have read stated that the N950 is the best Atmos soundbar they ever tested.
meles, william06 and Dime04 like this.
Shopping List:
TV: LG CX/GX; Samsung Q90T/Q800T...?
Blu-ray: Panasonic UB820
AVR/Pre-pro: Marantz 8805/7705 or 8012, or Yamaha 5200 or 3080
Speakers: GE Triton One.R, or ML ElectroMotion ESL X
New24K is offline
post #1309 of 3140 Old 10-07-2018, 07:23 PM
jincuteguy's Avatar
Quoted: 89 Post(s)
Liked: 4
Ok thanks....Does the SAmsung N950 has the port for you to connect your own Sub? or you have to use the sub that comes with it?
post #1310 of 3140 Old 10-07-2018, 07:34 PM
jincuteguy's Avatar
Quoted: 89 Post(s)
Liked: 4
Originally Posted by william06 View Post
I tried a lgsk10y between my k950 and N950 and the difference to me was mamouth.
So the difference between LG sK10Y and N950 is mamouth in terms of Atmost effect? or sound quality?
post #1311 of 3140 Old 10-07-2018, 07:54 PM
jincuteguy's Avatar
Quoted: 89 Post(s)
Liked: 4
Currently I have the KEF LS50W and JL Audio E110 Sub.
Should I spend money and get 2 surrounds + 2 Atmos modules + 1 Center + 1 AVR to complete the 5.1.2 setup?
Or spend $1600 on the entire Samsung N950? Which one you guys think will yield better ATmos effect
post #1312 of 3140 Old 10-07-2018, 08:34 PM
william06's Avatar
Quoted: 936 Post(s)
Liked: 521
Both by a mile
meles likes this.
Lg oled65G7P
Panasonic UB9000 . pioneer lx500 uhd blu ray players
atv4k 2nd gen cube, roku ultra 2019
Toshiba Xa2 HD-DVD
Samsung HW-Q90R ZA soundbar
william06 is online now
post #1313 of 3140 Old 10-08-2018, 02:43 AM
Liked: 0
Hope that helps.
Thank you for your answer ! Did you update your firmware with the last version ?
Is somebody able to give me more details about the issue of automatic shut down after 5 minutes of inactivity: Is this issue still present with the last firmware update ?
How does this issue work exactly ? I mean, the soundbar shut down after 5 minutes without sound ? Or 5 minutes without image ? For exemple, if I'm watching photos on my apple TV, the soundbar will shut down automatically after 5 minutes or not ?
post #1314 of 3140 Old 10-08-2018, 04:49 AM
I've receveid mine this morning, no problem so far, but i haven't connected the soundbar to the wifi atm, so no firmware upgrade.
I just have a question. When a source is Atmos or DTS-X, the soundbar show it but not when the source is DTS 5.1 ... How to no know if the output is 5.1 ? Thank you.
beligasse is offline
post #1315 of 3140 Old 10-08-2018, 07:25 AM
Hello, i played several games this week, shadow of tomb raider and assassins creed odyssey with this n950, i noticed that the sound is not evenly seperated, the right side seems to hollow, and my further test shows that the rear speaker is not in same level, the easiest way is to summon ikaros the eagle in odyssey and it screechs bigger from left rear channel and this explained the hollow happening at right side. Anyone experience same problem? And how to set the level manually between left and right? This is silly as the only option is set level for both simultaneously. Sorry for my english.
Edward Soesanto is offline
post #1316 of 3140 Old 10-08-2018, 07:45 AM
Gary J's Avatar
Quoted: 831 Post(s)
Liked: 384
Can you change soundbar sources with a Samsung Q9FN TV remote?
Gary J is offline
post #1317 of 3140 Old 10-08-2018, 08:29 AM
SkyYYZ's Avatar
Quoted: 267 Post(s)
Liked: 205
Negative. I have to switch inputs using the N950 remote in my setup (UHD player audio directly connected to soundbar/video going directly to the TV). The only N950 options I have available are HDMI, WiFi & BT sound settings within the Q9FN Sound menu. It's possible I haven't discovered a way to do it yet with the TV remote...I've only had the set for a few days and have been busy trying out a bunch of things.
SkyYYZ is offline
post #1318 of 3140 Old 10-08-2018, 09:43 AM
conazo's Avatar
So can someone confirm if the new firmware is ok to download?
No one seems to want to answer this, I too would like to know if it's safe to update to the new firmware. Thanks
conazo is offline
post #1319 of 3140 Old 10-08-2018, 09:46 AM
jincuteguy's Avatar
Quoted: 89 Post(s)
Liked: 4
Can I hook up just the Samsung N950 sound bar to an AVR, then hook up my own Sub and rear surround speakers to the AVR?
Basically I just want to use the soundbar as the front L+R and Center speakers , and my own Sub and Rear surrounds .
Will this work? Anyone tried this setup?
post #1320 of 3140 Old 10-08-2018, 01:31 PM
Quoted: 569 Post(s)
Liked: 367
And @lukather101 I have almost no issues with new firmware, it doesn’t yank me out of Sources to TV Plus anymore. I do have issues with Vudu not loading well on UHD and sound skipping intermtantly but that’s the only app with problems.
Samsung 75Q9FN
Samsung HW-N950
Samsung UBD-M9500
Reply Soundbars
