Samsung HW-N950 Soundbar 7.1.4 Dolby Atmos - Page 86 - AVS Forum | Home Theater Discussions And Reviews
 874Likes
post #2551 of 2553 Old 04-15-2019, 11:05 PM
Liked: 0
Originally Posted by Strasburger000 View Post
“Dolby Atmos” will show on your soundbar screen, and disappear after few seconds. I would advise to play “our planet” as it’s Dolby vision and Dolby Atmos to test what’s wrong with your system. First of all make sure, English (Atmos) is chosen from the audio/ subtitles list in Netflix. If you still won’t see “Dolby Atmos” on soundbar, then I would guess, you need to check your TV Audio settings whether Atmos pass through is enabled, and finally whether your HDMI cable has the latest specification (2.0a?)
Hey Strasbuger, i think I see the problem. Looking in the actual TV settings, the option to switch dolby atmos on is greyed out. Like the Soundbar isnt recognised as capable or something. Any ideas?
Thanks in advance mate
Alexalex111 is offline
post #2552 of 2553 Old 04-16-2019, 06:28 AM
Denis Fyodorov's Avatar
Originally Posted by talkshowchris View Post
I've got a problem with small crackles every now and then when playing Atmos content. It happens about 10 times per film and at random times.
DTS X appears to be fine.
Has anyone else experrienced this bizarre issue?
I have. What kind of device is the source of sound? I had it with PC connected to the soundbar via HDMI, and it turned out the cause was the NVIDIA high definition audio driver, which is installed with the NVIDIA graphics drivers. The solution was to remove this driver and install the default Windows driver for High Definition Audio. Details in this post: https://www.avsforum.com/forum/195-s...l#post57655126
This completely removed crackles in my case in all scenarios. Now, when installing NVIDIA graphics drivers, I have to skip the audio driver component, because it's the same faulty HD Audio Driver ver. 1.3.38.13 that has not been updated for a while now.
If it's not PC with an NVIDIA card that you use, then the issue might be caused by something else. There are numerous suggestions throughout the web, related to crackling, but in my case it was due to the audio driver.
Denis Fyodorov is offline
post #2553 of 2553 Old 04-16-2019, 12:23 PM
UnfoldingSquid's Avatar
Quoted: 460 Post(s)
Liked: 285
My TV isn’t an LG, but it does have something similar in audio settings to where options are grayed out, if a source isn’t playing that kind of content. I would suggest playing something in Netflix that is definitely Atmos and THEN going to that pictured audio menu to see if you can turn Atmos on, once it’s selected to On then it should auto switch back and forth.
Samsung 75Q9FN
Samsung HW-N950
Samsung UBD-M9500
UnfoldingSquid is online now
Reply Soundbars
