Samsung HW-N950 Soundbar 7.1.4 Dolby Atmos - Page 93 - AVS Forum | Home Theater Discussions And Reviews
 1004Likes
post #2761 of 3140 Old 06-18-2019, 02:25 PM
naustin's Avatar
Quoted: 2023 Post(s)
Liked: 1369
Originally Posted by william06 View Post
I do my updates on the smart things app the latest 1007.5 a while back. Nothing on earc and I do not think there is no plan for it on the N950 even with the similarity to the q90 just as no dtsx for the k950. Just mention again very little issue with my N950 so far ,in fact my k950 gave me very little trouble.
Thanks for the help. My K950 was starting to have Atmos handshake issues so I decided to upgrade and avoid the audio splitting hassles. I'm looking forward to installing the N950. Based on my Q90 experiences, I am now adept with Smart Things & USB firmware updating (if needed).
naustin is offline
post #2762 of 3140 Old 06-18-2019, 02:30 PM
william06's Avatar
Quoted: 936 Post(s)
Liked: 521
That’s right I forgot to mention about the full hdr 4k60hz pass through, Ed+ atmos over arc and Dtsx. I retired my avrkey in a drawer somewhere lol.
naustin likes this.
Lg oled65G7P
Panasonic UB9000 . pioneer lx500 uhd blu ray players
atv4k 2nd gen cube, roku ultra 2019
Toshiba Xa2 HD-DVD
Samsung HW-Q90R ZA soundbar
william06 is offline
post #2763 of 3140 Old 06-18-2019, 03:40 PM
Quoted: 150 Post(s)
Liked: 154
Originally Posted by Shaffin View Post
I recently found a switch that works....FINALLY. I tried a few different ones recommended on here. Including ROOFULL 5 in - 1 out 4K 60hz HDCP 2.2 switch, a Kinivo 550BN 4k switch. Both had handshaking issues with the HDMI output. I would occasionally get a black screen. They both worked if I had turned my TV on and off a few times with the soundbar turned on. Eventually I could get it to work. I have a LG B6 OLED for reference btw. The soundbar is on the latest firmware as of this post.
But FINALLY, I found one that works perfectly!!! It was on this thread as one to try but nobody seemed to give it a go. I took the plunge only because of the issues I had with the above two switches.
Here is the info -
ViewHD Model: VHD-UHD4X1A
4 In - 1 out
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
If you search by that model it should work, just in case the link gets deleted. I hope this also works for someone else!
I also discovered the HDMI going from my switch to the soundbar had to be perfect for my ATV 4K to work on 4K @ 60hz HDR chroma 4.2.2. All of my other 4k sources (comcast, xbox, PS Pro) worked fine, it was just the ATV that was being a pain. So I tried several different cables I had, even a "premium ultra high speed cable". It would work on 4.2.0 chroma but it was unstable when I tried the check HDMI connection feature on the ATV. I tried a different cable and had artifacts, another one gave me flickering. Either way, it seems the soundbar is VERY picky about HDMI cables. I had bypassed the soundbar last night using the same premium cable that was causing my issues direct to my TV. Worked flawless but as soon as I ran it through the soundbar, all these issues came back. Long story short, I am now working flawlessly with the HDMI cable that came with the sound bar between the switch and the soundbar itself and then one of my premium cables going from the soundbar to the TV.
I ran the check HDMI connection feature multiple times with it on the highest bandwidth setting on the ATV (4k @ 60hz HDR 4.2.2). Absolutely zero issues. I even watched 4k content on multiple sources last night and no artifacts or flickering or anything. I have the switch set to EDID auto & ARC OFF.
I tried the Roofull switch as well and had problems where I would have to disconnect the power every single time to get audio for a 4k Blu-ray player. Are there any 5 in, 1 out switches that work with Dolby Vision? Thanks for the help.
longhorn23 is online now
post #2764 of 3140 Old 06-19-2019, 02:06 PM
Quoted: 20 Post(s)
Liked: 7
Here is the info -
4 In - 1 out
Thanks for posting this! Does the switch properly passthrough Dolby Atmos and Vision from the ATV 4K?
Sent from my Pixel 3 XL using Tapatalk
fruitypwny is offline
post #2765 of 3140 Old 06-19-2019, 02:25 PM
Shaffin's Avatar
Quoted: 20 Post(s)
So this switch passes up to 18Gbps HDMI bandwidth and the ATV 4K (per apple) requires 48Gbps with Dolby Vision and Dolby Atmos. They actually recommend using a Belkin 48Gbps HDMI cable. I haven't found a HDMI switch that can do ultra high speed 48Gbps so I have my ATV 4K going direct to the sound bar and everything else going through the switch because I don't have any other devices that can do DV & Atmos. I technically can get the ATV to work going through the switch but the HDMI connection is telling me "looking better" when I have it on 4k @ 60hz HDR and Chroma 4.2.2 with Atmos enabled. Originally when I hooked up this switch it reported no issues. I did some digging and found all this info I just mentioned. Keep this in mind when it comes to using a HDMI switch but the switch works perfectly for my Comcast, Xbox and PS pro. I even hooked up a Nvidia Shield 4k and that works without any issues as well.
Shaffin is offline
post #2766 of 3140 Old 06-19-2019, 02:41 PM
Gary J's Avatar
Quoted: 831 Post(s)
Liked: 384
So it looks to me like there is still no 4-1 switch where you can hook up any four devices you want without issue. I am resigned to having my cable TV and Fire TV Cube hooked up to the switch and the Nvidia Shield to the N950 HDMI 2. When I need the X-Box I pull the Shield cable and plug it in the X-Box.
Gary J is offline
post #2767 of 3140 Old 06-19-2019, 03:31 PM
Shaffin's Avatar
Quoted: 20 Post(s)
I have 4 devices plugged into my switch without issue, its just the ATV 4K that requires ultra high speed bandwidth that from what I've seen won't work with any of the switches people have posted links to here.
Shaffin is offline
post #2768 of 3140 Old 06-19-2019, 03:34 PM
Gary J's Avatar
Quoted: 831 Post(s)
Liked: 384
Not my idea of without issue.
Gary J is offline
post #2769 of 3140 Old 06-19-2019, 04:01 PM
Shaffin's Avatar
Quoted: 20 Post(s)
The ATV won't work with any of these cheap switches from china, would have to spend a few hundred on a switch to get one that will work with an ATV 4K. I rather just go direct to the SB with my ATV and use the other HDMI on the SB for the stuff plugged into the switch. Not sure there is a cheaper solution.
Shaffin is offline
post #2770 of 3140 Old 06-19-2019, 04:03 PM
naustin's Avatar
Liked: 1369
I updated my N950 to 1007.5 through Smart Things yesterday and it seemed to have taken it since the info screen shows 1007.5. Today the bar keeps flashing UPDATE
naustin is offline
post #2771 of 3140 Old 06-19-2019, 05:31 PM
william06's Avatar
Quoted: 936 Post(s)
Liked: 521
Try redoing update over if that does not work unplug reset and when you go into smart things see if the update is there nif it keeps flashing then I would exchange it
Lg oled65G7P
Toshiba Xa2 HD-DVD
post #2772 of 3140 Old 06-19-2019, 08:35 PM
naustin's Avatar
Liked: 1369
I now believe the UPDATE was because I did unplug the SB and it was re establishing Wifi and checking for an update that it didn't need. It appears to be ok now. Thanks for the help.
naustin is offline
post #2773 of 3140 Old 06-19-2019, 08:43 PM
william06's Avatar
Quoted: 936 Post(s)
Liked: 521
Great I hope you enjoy it as much as I have
post #2774 of 3140 Old 06-20-2019, 02:31 PM
naustin's Avatar
Liked: 1369
So this switch passes up to 18Gbps HDMI bandwidth and the ATV 4K (per apple) requires 48Gbps with Dolby Vision and Dolby Atmos....
So it looks to me like there is still no 4-1 switch where you can hook up any four devices you want without issue...
@lparsons21 posted this switch on the K950 thread. YMMV https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
naustin is offline
post #2775 of 3140 Old 06-20-2019, 02:56 PM
Gary J's Avatar
Quoted: 831 Post(s)
Liked: 384
2x1 probably most work, 3x1 some still do. It's the 4x1 and greater where these devices seem to get stumped.
Gary J is offline
post #2776 of 3140 Old 06-20-2019, 02:59 PM
naustin's Avatar
Liked: 1369
More stuff on the subject from CNet yesterday.
https://www.cnet.com/how-to/hdmi-swi...-need-to-know/
naustin is offline
post #2777 of 3140 Old 06-21-2019, 05:54 PM
Quoted: 378 Post(s)
Liked: 254
Does anyone use speaker stands for their rear speakers? If so, what kind?
Sent from my SM-G975U using Tapatalk
longhorn23 likes this.
Damar1979 is offline
post #2778 of 3140 Old 06-22-2019, 06:25 PM
Antarius's Avatar
Quoted: 230 Post(s)
Liked: 160
Is there a way to tell which audio type is playing?
Antarius is offline
post #2779 of 3140 Old 06-23-2019, 07:23 AM
Quoted: 25 Post(s)
Liked: 1
Only atmos and Dtsx
lukather101 is offline
post #2780 of 3140 Old 06-23-2019, 07:47 AM
glenngreen's Avatar
Quoted: 25 Post(s)
These are what I'm using:
Damar1979 likes this.
Fear is a path to the Dark Side: Fear leads to Anger, Anger leads to Hate, Hate leads to Suffering.
--- Master Yoda, a long time ago in a galaxy far, far away.
glenngreen is offline
post #2781 of 3140 Old 06-23-2019, 07:49 AM
Quoted: 378 Post(s)
Liked: 254
Originally Posted by glenngreen View Post
Thanks! How do you like them? How sturdy are they?
post #2782 of 3140 Old 06-23-2019, 07:52 AM
Quoted: 378 Post(s)
Liked: 254
It will only display when it's playing either Dolby Atmos or DTS-X. But with that being said it will also play dolby true HD as well as DTS master HD, and also the lossy codecs Dolby Digital Dolby Digital+ and DTS
william06 likes this.
post #2783 of 3140 Old 06-23-2019, 09:07 AM
glenngreen's Avatar
Quoted: 25 Post(s)
I like them. They are sturdy, and they look very nice. 36" is a good height for couch ends but there are also 24" available if you prefer the shorter table height. The taller ones are just about ear height sitting on a sofa.
post #2784 of 3140 Old 06-23-2019, 09:09 AM
Quoted: 378 Post(s)
Liked: 254
For your setup do you have them right next to you? Or a little bit behind? Which do you find more immersive?
post #2785 of 3140 Old 06-23-2019, 09:59 AM
glenngreen's Avatar
Quoted: 25 Post(s)
I have two recliners against (nearly) the rear wall. Maybe my head is 12-15" from the wall. Speakers are against the wall, and spread maybe 3 feet wider than the recliners. Immersion is very good.
post #2786 of 3140 Old 06-23-2019, 10:53 AM
Antarius's Avatar
Quoted: 230 Post(s)
Liked: 160
I bought this switch and have ATV4K and UBK90 plugged in. Both work fine with DV and DA. Don't listen to 48Gbps requirement nonsense.
Antarius is offline
post #2787 of 3140 Old 06-24-2019, 12:02 PM
Quoted: 38 Post(s)
Liked: 7
I use these: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Inexpensive and works well. I put a review on amazon also with pics.
Cb675 is offline
post #2788 of 3140 Old 06-24-2019, 12:06 PM
Quoted: 38 Post(s)
Liked: 7
Well out of the frying pan and into the fire Since my K950 was acting up and BB had the Q90R for only a 100 more than the N950, I purchased the HW-Q90R.
Being bleeding edge is no fun. Continuous audio drop outs from ARC and nothing on the two HDMIs. Since the SB is designed to work with the Q90 TVs wifi, there isn't an obvious way to be the internet with a non Samsung TV so I can not update the firmware. Samsung's quick start manual is terrible as is the Support website for this brand new model. Guess I'll try Samsung telephone support before I box the Q90R up and get an N950. I really love the rich musically and depth of the Samsung Atmos bars but jeez.
Im selling my N950 if youre interested. Excellent condition. I moved into a new home recently and decided to do media room. No need for N950.
Cb675 is offline
post #2789 of 3140 Old 06-24-2019, 02:02 PM
naustin's Avatar
Liked: 1369
Thanks I exchanged my Q90R for a new N950. I've got an old K950 I need to sell.
naustin is offline
post #2790 of 3140 Old 06-24-2019, 02:24 PM
naustin's Avatar
Liked: 1369
Originally Posted by UnfoldingSquid View Post
As far as I can tell, the only differences are the Q90 has a bigger sub (6 1/2” to 8”) and the Q90 has “adaptive sound” to enhance voices at lower volumes.
The N950 has an 8 inch sub just like the K950. https://hometheaterreview.com/samsun...dbar-reviewed/
naustin is offline
Reply Soundbars
