Vizio Announces Three Dolby Atmos Soundbar Systems Including 5.1.4 - Page 23 - AVS Forum | Home Theater Discussions And Reviews
 330Likes
post #661 of 935 Old 12-07-2018, 12:50 PM
Quoted: 126 Post(s)
Liked: 143
Hello all,
We have begun releasing firmware 1.2.3.1 for the VIZIO Atmos sound bars.
This firmware includes the following improvements below.
Updates:
1. Color banding occurring when being pass thru the sound bar.
2. Apple TV 4K audio not switching to Dolby 5.1.
3. Factory reset not fully resetting network settings.
4. Sound bar stopped responding to CEC commands after system idled for 5 mins.
5. Resolved a Surround balance issue where surround balance was only increasing channel gain, and did not reduce the gain.
6. Other CEC compatibility issues.
This update will be rolling out slowly over the next couple of weeks.
Please let us know if you have any other issues.
a61688, Anago and leojj25 like this.
VizioService is offline
post #662 of 935 Old 12-09-2018, 01:00 AM
Liked: 2
I’d really like to get the SB36512-F6 but I have a lot of questions. I’m not an audio expert at all.
At the moment I have a 5.1 system with a 2009 or 2010 Sony receiver and small Harmon Kardon speakers from 2011 at the latest. My main issue with the system is that it’s too quiet for movies at Max volume and I don’t know why that is. Dialogue in quiet scene is just barely listenable sometimes. The front channels are all set to max volume but the side ones seem particularly quiet. I’m also passing through TV audio to the receiver through optical out because it won’t support 4K.
Instead of trying to get either a new receiver or speakers to solve all of this a 5.1 sound bar system seems like a good solution and the idea of having Atmos with it is really appealing. I’ve heard good things about the subwoofer. My main concern would be if it’s acfually worse than my current 5.1 system can be.
JackSawyer is offline
post #663 of 935 Old 12-09-2018, 03:40 PM
mark729's Avatar
Liked: 1
Angry
Still doesn't work.
keep loosing CEC and ARC function.
I need to soft power cycle or factory reset to work and it is not even last long.
I have a Vizio P65F1 TV and Vizio SB36512 conneted ARC port both side.
Do not buy Vizio soundbar yet. they are not ready.
Originally Posted by VizioService View Post
Hello all,
Updates:
mark729 is offline
post #664 of 935 Old 12-09-2018, 04:17 PM
Quoted: 29 Post(s)
Liked: 29
Originally Posted by mark729 View Post
Still doesn't work.
Speak for yourself, my vizio p quantum and the 5.1.4 handshake is excellent
divo1979 is offline
post #665 of 935 Old 12-09-2018, 05:30 PM
mark729's Avatar
Liked: 1
No one knows...Mine was working well for couple of weeks then screwed.
mark729 is offline
post #666 of 935 Old 12-10-2018, 02:21 PM
leojj25's Avatar
Quoted: 339 Post(s)
Liked: 203
Have Vizio replace yours
Vizio P65-E1 // Sony XBR49X900E
Sony Ht-ST5000 // RCA RTS7015B
Chromcast Ultra // Apple TV 4K
PS4 PRO
leojj25 is offline
post #667 of 935 Old 12-10-2018, 05:32 PM
Quoted: 75 Post(s)
The dialogue is very clear and it definitely gets loud enough. It will certainly be better than your receiver in that regard. Overall it sounds very good too, great bass and surround sound.
cb86 is offline
post #668 of 935 Old 12-11-2018, 08:22 AM
Bacon_67's Avatar
Quoted: 123 Post(s)
Liked: 58
Last night I noticed the right rear speaker on my 5.1.4 system has some slight static/distortion sound even when there is no sound coming from the main bar (only really audible when you're close to the speaker).
What are my options? Try different power outlets/surge protectors. Move the wires around? Going to try and fiddle with it tonight to see if I can make it go away...
Bacon_67 is offline
post #669 of 935 Old 12-11-2018, 08:48 AM
a61688's Avatar
Quoted: 164 Post(s)
Liked: 114
Make sure the speaker wire isn't touching sources of interference like other power cables.
a61688 is offline
post #670 of 935 Old 12-12-2018, 12:40 PM
T3h Professor's Avatar
Quoted: 13 Post(s)
Still doesn't work.
I have the exact same tv and bought the 36" soundbar from Costco. It worked fine for about two days and then suddenly had handshake issues left and right. I took it back to Costco since I had the 5.1.4 bar as well and that has worked flawlessly so far.
Maybe you have a bad unit.
T3h Professor is offline
post #671 of 935 Old 12-12-2018, 12:58 PM
a61688's Avatar
Quoted: 164 Post(s)
Liked: 114
Keep in mind that there have been updates to try and fix those issues. It's possible that the 36 would work fine nowadays.
a61688 is offline
post #672 of 935 Old 12-13-2018, 08:28 AM
sgruby's Avatar
Hello all,
Updates:
Excellent! I think some of these issues are ones that I've been experiencing. When will the firmware update be available for manual download?
sgruby is offline
post #673 of 935 Old 12-13-2018, 10:18 AM
Hubert.J.Farnsworth's Avatar
Quoted: 141 Post(s)
Liked: 45
To anyone who has tested both 5.1.2 and 5.1.4, what are the main differences (appart from the massive sub) and is it worth spending twice as much for the 5.1.4, does it sound twice as good? Also Are the height channels as bad as the 5.1.2 with tons of sound bleed in the front?
Hubert.J.Farnsworth is offline
post #674 of 935 Old 12-13-2018, 10:56 AM
Quoted: 126 Post(s)
Liked: 143
We will keep you posted on when this will be made available.
post #675 of 935 Old 12-13-2018, 10:57 AM
sgruby's Avatar
Thanks! Did the update get pulled due to issues?
sgruby is offline
post #676 of 935 Old 12-13-2018, 11:10 AM
Quoted: 141 Post(s)
Liked: 45
Hello, any plans of adding volume control for height channels?
post #677 of 935 Old 12-13-2018, 12:07 PM
Quoted: 126 Post(s)
Liked: 143
I do not currently have information on future updates or improvement but I can pass along your suggestion to our development team.
post #678 of 935 Old 12-14-2018, 05:11 AM
Quoted: 29 Post(s)
Liked: 29
@VizioService the newest firmware update that you all implemented for the SB 5.1.4 and the SB5.1.2 aren't really responding to HDMI handshakes and CEC accessibility. I have updated my 5.1.4 to the newest firmware, and it keeps losing CEC and ARC capabilities all the time. I have to unplug and replug the sound bar in order for my tv to connect with it every time I turn on the TV. Also like someone mentioned a dedicated volume update for the height channels would prove very useful. All of the sound seems to bleed forward when listening to audio formatted in ATMOS. Please revisit this new update because it seems very buggy for these new sound bars.
divo1979 is offline
post #679 of 935 Old 12-14-2018, 11:37 AM
Quoted: 126 Post(s)
Liked: 143
Hello All,
We have currently halted the further release of firmware version 1.2.3.1 due to the feedback we have received on a compatibility issues with Apple TV connected to the HDMI In on the sound bar.
We will be working quickly to resolve this issue and get a update released to correct this behavior.
For those that have already received the update we recommend that you connect the ATV directly to one of the TV’s other HDMI inputs and power cycle your TV, ATV and sound bar.
We will continue to update this thread as more information becomes available about this update.
Thank you all for you patience and feedback as we continue to work in enhancing the Atmos sound bar experience.
a61688, leojj25 and divo1979 like this.
post #680 of 935 Old 12-15-2018, 10:06 AM
thaiusmle's Avatar
Quoted: 26 Post(s)
Hello All,
Please look into Nvidia Shield issues as well - losing HDMI signal when changing frame rate and artifacts with 4:2:0 chroma. Thanks.
thaiusmle is offline
post #681 of 935 Old 12-18-2018, 06:20 AM
Quoted: 29 Post(s)
Liked: 29
@VizioService I know that you all are working tirelessly on the newest update for the atmos sound bars, and the community really does appreciate it a lot. I'm some what unhappy with the issues that these sound bars are having as I'm sure there are many others who would agree with me. For those that aren't having arc response and cec failures than that's pretty awesome. The update that you all launched with 5.1.4 seemed to work perfectly like a previous comment mentioned. I know I sound like a broken record with the same problems being worded differently, but when you spend a $1,000 plus dollars on a product you expect it to function properly with minor updates for a few quirk. These issues are major for some of us, I shouldn't have to unplug my $1,000 sound bar that I just purchased, and replug it back into the outlet in order for it to connect to my tv for sound and cec functions. I like the sound bar don't get me wrong, I'm not rich so this is an investment that I hope will pay off in the future. I may have spoken to soon stating that my handshake issues were perfect in previous post
divo1979 is offline
post #682 of 935 Old 12-18-2018, 11:14 AM
Quoted: 141 Post(s)
Liked: 45
A tuning option or adding a distance setting instead of channel volume would be great.
post #683 of 935 Old 12-18-2018, 11:52 AM
UHD Addict
aaronwt's Avatar
Quoted: 9214 Post(s)
Liked: 5923
Can these sound bars work with 96khz and 192khz audio? Or is it limited to only 48khz and lower?
I'm looking at the 5.1.2 system, since it's on sale now.
53TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #684 of 935 Old 12-19-2018, 08:11 AM
UHD Addict
aaronwt's Avatar
Liked: 5923
I went ahead and ordered a supposed open box in excellent condition from BestBuy. For almost half the normal price. but when I got home I had planned on testing things out. But it was anything but excellent condition, since it didn't work.
So I was able to exchange it this morning for a new one. Which works out great for the very low price. I just hope that this new one works.
a61688 likes this.
post #685 of 935 Old 12-19-2018, 06:25 PM
Chingu808's Avatar
Quoted: 68 Post(s)
Liked: 35
For the last 3 nights the open box excellent condition one keeps on popping back in stock for $279.99. I guess I'm lucky I did not buy it. To bad the $299.99 price is over at Sam's Club & Costco. Although not sure how much I would need this since I do not have a 4K TV to stream 4K content.
Chingu808 is offline
post #686 of 935 Old 12-19-2018, 07:53 PM
Quoted: 141 Post(s)
Liked: 45
$349 at Costco lately, not Black Friday good but better than $500
post #687 of 935 Old 12-19-2018, 08:49 PM
UHD Addict
aaronwt's Avatar
Liked: 5923
The brand new one I got at Best Buy in exchange for the open box at that price is working great.
I definitely like this sound bar better than the Sony 9000F I have been trying out. For several reasons.
The vizio does seem to have more power and can get louder. The Vizio also has more bass than the Sony.
I also hear more of the height effects from the Vizio with it's dedicated height speakers.
And of course the two surround speakers also greatly enlarge the soundfield.
I also tried some 192Khz and 96hkz TrueHD tracks and the Vizio was able to play them without any issue.
Although that is one thing I've always liked about the Sony sound bars. They would tell you the sampling rate of the content being played. The Vizio just shows you the format in the app. But for the setup I'm using it in, that is all I really need any way.
And it is working great with a 5x1 18Gbps HDMi switch connected to it.
For the price I paid for the Vizio, I am extremely happy with it. I did get the four year extended warranty for $50 from Bestbuy, just in case.
And the Vizio was at the current firmware out of the box. So I guess it was new stock?
And it's working fine with the ARC from my 2015 Sony UHD TV. It would automatically switch to the speaker bar for audio like it is supposed to.
The Vizio 5.1.2 sound bar seems to have a lot of bang for the buck.
a61688 and Anago like this.
post #688 of 935 Old 12-19-2018, 09:58 PM
a61688's Avatar
Quoted: 164 Post(s)
Liked: 114
Dump your HDMI switch model on here.
a61688 is offline
post #689 of 935 Old 12-20-2018, 05:53 AM
UHD Addict
aaronwt's Avatar
Liked: 5923
I'm using a couple of $40 to $50 switches in that setup. Which looks and behaves identically to the $70 Sewell 18Gbps switches I got last year for my main UHD setup. I'll need to find the links from Amazon later.
Sent from my Nexus 7 using Tapatalk
a61688 likes this.
post #690 of 935 Old 12-20-2018, 10:35 AM
UHD Addict
aaronwt's Avatar
Liked: 5923
Here are the two 5x1 Sewell HDMI switches I have.
https://sewelldirect.com/switchdeck-...-22-444-chroma
And here are the two 5x1 HDMI Switches I got from Amazon recently(One costing around $50 and the other around $40)
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
All four switches have worked with the same UHD/HDR10/DV components in my testing and use. Although I've had the Sewell switches in use for eighteen months. While I've only had the switches from Amazon in use for two months. So I have no idea how reliable the switches from Amazon will be in the long term.(since the reviews show that some people have had issues) But they all look and work identically, except for the color. And also use the same IR codes.
I got extended warranties through Sewell and Amazon just in case I have issues with the switches in the future.
a61688 likes this.
Reply Soundbars
atmos , soundbar , Vizio
