Vizio Announces Three Dolby Atmos Soundbar Systems Including 5.1.4 - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 328Likes
post #721 of 912 Old 12-27-2018, 08:24 PM
Liked: 2
I'm happy to say I've fixed the colour banding issue! I manually updated to 1.2.3.1 through USB which wasn't available through the soundbar, no more banding, looks perfectly clean.
Really happy with this soundbar, far better than my 5.1 system. The sound is so much more enveloping with the height channels.
aaronwt and a61688 like this.
JackSawyer is offline
post #722 of 912 Old 12-28-2018, 12:40 AM
Mauer's Avatar
Quoted: 44 Post(s)
Anyone here with the 5.1.2 system and an Xbox One X? Is there any input or audio lag when the Xbox is connected directly to the soundbar via HDMI?
Mauer is offline
post #723 of 912 Old 12-28-2018, 05:34 AM
UHD Addict
aaronwt's Avatar
Quoted: 8896 Post(s)
Liked: 5687
I'm using an XB1S with mine. I haven't noticed any lag issues when playing a game. Or with the Dolby Atmos test videos on the Xbox.
Sent from my Nexus 7(16GB) using Tapatalk
Mauer likes this.
53TB unRAID2--45TB unRAID3--35TB unRAID1a
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #724 of 912 Old 12-28-2018, 10:12 AM
guacamoleparty's Avatar
Quoted: 119 Post(s)
Liked: 107
Another question for an Xbox owner. I have the prior 5.1 Soundbar and in 'direct' mode the subwoofer is INCREDIBLY loud. I had to turn it down a lot, is this system better balanced? Im using it in Dolby Digital. Thoughts? Thank you!
guacamoleparty is offline
post #725 of 912 Old 12-28-2018, 11:06 AM
taichi4's Avatar
Quoted: 529 Post(s)
Liked: 308
Are there any detailed owner reviews of the 5.1.2? Professional reviews seem mostly positive, but with some criticism of ultimate sound quality. Because of the low prices on this unit at Costco, I'm tempted.
taichi4 is offline
post #726 of 912 Old 12-28-2018, 11:36 AM
Bacon_67's Avatar
Quoted: 108 Post(s)
Liked: 47
From time to time I’ll get a loud distorted sound from a number of different devices over ARC on the 5.1.4 system and nothing else, which will usually go away when I try replaying a video. Anyone else experiencing this?
Bacon_67 is offline
post #727 of 912 Old 12-28-2018, 02:34 PM
Liked: 2
I don't have an Xbox but on PS4 when I set my audio output to Linear PCM I can't hear any dialogue audio. I have to set it to Dolby or DTS to hear it.
post #728 of 912 Old 12-28-2018, 02:39 PM
UHD Addict
aaronwt's Avatar
Liked: 5687
I haven't tried 7.1 pcm output from my XB1S with the Vizio. Only Atmos. I'll need to switch it to 7.1 pcm output to see if there are issues.
Sent from my Galaxy S8 using Tapatalk
aaronwt is offline
post #729 of 912 Old 12-28-2018, 02:54 PM
a61688's Avatar
Quoted: 163 Post(s)
Liked: 114
You won't get 5.1 or 7.1 pcm using optical/HDMI arc. Only stereo. Not sure what plugging it directly to the soundbar would result in though. It SHOULD work but I don't own the bar yet so I won't say I'm certain.
a61688 is online now
post #730 of 912 Old 12-29-2018, 07:17 AM
UHD Addict
aaronwt's Avatar
Liked: 5687
If the XB1 is set to PCM and going to a TV with regular ARc, it should only be outputting stereo PCM, since that is all it can handle. You need eARC to handle multichannel PCM audio.
I know the Vizio can at least handle 5.1PCM. because that is what I needed to send from my SACDs, since the Vizio couldn't handle DSD audio, like the Sony sound bar I had tried.
Sent from my Nexus 7 using Tapatalk
aaronwt is offline
post #731 of 912 Old 12-29-2018, 09:47 AM
asc72's Avatar
Liked: 0
I am debating whether to pick up the 5.1.2 or go for the .4. Some of the early reviews I read on the .2 were that the Atmos effects were a bit weak. Is that the experience of others here or has it been improved with firmware updates?
asc72 is offline
post #732 of 912 Old 12-29-2018, 10:32 AM
a61688's Avatar
Quoted: 163 Post(s)
Liked: 114
It will be weaker than the .4 because it has half the height channel speakers. Think of it this way: price vs performance. Which do you value more than the other? Your answer is the one should probably get.
aaronwt and calfcramp like this.
post #733 of 912 Old 12-29-2018, 05:23 PM
UHD Addict
aaronwt's Avatar
Liked: 5687
I just tried 7.1 pcm output from my XB1S with the Vizio 5.1.2 sound bar. I had no audio issues when playing Black OPs 4. And when using the netflix surround test, the 5.1 channels all showed up when the xbox was set for 7.1 pcm output.( I put it back to Atmos audio when I was finished though)
I still need to pick up a PS4 for that setup. I should have picked one up in November when they were $200. I guess I could move my PS4 Pro/XB1X from another room into the room with the Vizio. But I have no desire to be moving my XB1X or PS4 Pro around.
The Vizio bar has worked great so far with most of the audio formats I've tried. Even with DOlby True HD at 192khz and 96Khz sampling rates. The only thing I've tried so far that didn't work was DSD audio from an SACD.
aaronwt is offline
post #734 of 912 Old 12-30-2018, 08:21 AM
taichi4's Avatar
Quoted: 529 Post(s)
Liked: 308
But how does the 5.1.2 sound overall?
taichi4 is offline
post #735 of 912 Old 12-30-2018, 08:27 AM
a61688's Avatar
Quoted: 163 Post(s)
Liked: 114
I can only tell you what I see 'on paper' as I do not own any of these yet. The .2 has smaller speakers, a smaller sub and only 2 height channel speakers.
post #736 of 912 Old 12-31-2018, 02:42 PM
Nu11u5's Avatar
How well do the upwards facing speakers work for Atmos in a two story room? I suspect that it won’t be ideal but I am considering these sound bars as a replacement for my aging 250W Sony soundbar.
Nu11u5 is offline
post #737 of 912 Old 12-31-2018, 03:05 PM
a61688's Avatar
Quoted: 163 Post(s)
Liked: 114
Vaulted ceiling? I could see that being a problem. Probably very 'echo-y' for any sound system. You'd have to play with changing the positions of the rears to get the most of it.
post #738 of 912 Old 12-31-2018, 04:11 PM
Nu11u5's Avatar
Not vaulted - it’s flat but 20ft up. The room is actually taller than it is wide.
Looked at Vizio’s manual and they advise no higher than 12ft ceilings. Guess that answers that.
Nu11u5 is offline
post #739 of 912 Old 12-31-2018, 06:06 PM
taichi4's Avatar
Quoted: 529 Post(s)
Liked: 308
With 20 foot ceilings you need ceiling speakers, as no Atmos enabled soundbar, and few if any Atmos enabled towers could muster up the energy to sustain coherent reflected sound with that high a ceiling.
But the new Vizio soundbars have DTS Virtual X, which I have every reason to believe will work pretty well with any of the true Surround models. Virtual X works essentially independently of room acoustics, including ceilings. The 5.1.2 model might work very well in this regard, as Virtual X will be more anchored with the rear speakers even if they're not height enabled.
taichi4 is offline
post #740 of 912 Old 01-02-2019, 08:48 AM
Nu11u5's Avatar
This will only work with content mastered in DTS-X, though - right?
Nu11u5 is offline
post #741 of 912 Old 01-02-2019, 01:25 PM
taichi4's Avatar
Quoted: 529 Post(s)
Liked: 308
I don't specifically know the answer to that, but I know that Virtual X will up mix standard multichannel sound (7.1.4), and of course you can probably opt to listen to multichannel rather than Atmos from most sources and enjoyed height.
And it may do something with Atmos… I'm just not sure. But Virtual X seems a good option if you can't put speakers in your vaulted ceiling, and I have the sneaky suspicion that Virtual X will work better with any number of surround speakers then it will from something like the Yamaha YAS 207. And possibly the newer soundbars will add in a little additional processing to the mix, more fully exploiting the potential of Virtual X.
Remember, the forebears of DTS demonstrated a complete 360°sound field using only two speakers in their laboratory, and so psychoacoustics is a very interesting thing.
taichi4 is offline
post #742 of 912 Old 01-02-2019, 06:46 PM
taichi4's Avatar
Quoted: 529 Post(s)
Liked: 308
Well how about that. I had some gift cards for Costco, and was thinking of picking up the Vizio 5.1.2 for $349.99 (the price last night, and I think this morning), and as of this evening the price shot up $100, making it more expensive than Amazon!
Now I have two complaints against Cosco, the other being dress socks that tear when you pull them off your feet.
taichi4 is offline
post #743 of 912 Old 01-02-2019, 07:36 PM
x3angel's Avatar
What happens when you play DTS-X content through this device? Does it use the DTS X VIRTUAL affect?
Sent from my SM-G955W using Tapatalk
x3angel is offline
post #744 of 912 Old 01-02-2019, 07:45 PM
UHD Addict
aaronwt's Avatar
Liked: 5687
Yes. The bar gets the DTS-HD MA audio and uses the virtual DTS effect.
aaronwt is offline
post #745 of 912 Old 01-03-2019, 07:39 AM
snoopysony's Avatar
Quoted: 46 Post(s)
I have the 5.1.2 and an Xbox 1X that's plugged into the soundbar via HDMI and I notice no input or audio lag.
Mauer likes this.
snoopysony is offline
post #746 of 912 Old 01-03-2019, 07:41 AM
snoopysony's Avatar
Quoted: 46 Post(s)
I haven't done a detailed review yet, but the sound can get very loud with little to no distortion, of course it depends on what you're listening to. Also, the sound is crisp and clean (at least to my ears).
post #747 of 912 Old 01-04-2019, 02:00 PM
Millicurie999's Avatar
Wireless Rear Speakers connection
I brought the 5.1.4 but haven't set it up due to ongoing home renovation. My question is therefore theoretical at this stage....I know that the rear speakers are connected to the wireless subwoofer. However, if for WAF reason, I don't want to have wires connecting the rear speakers to the sub, can I add a wireless hub (RCAs) to beam the output from the sub to the rear speakers?
I guess I would need something like this. (x 2; one for the each side).
The sound quality isn't that important, they are surround channels after all; more important is feasibility. Thoughts?
Millicurie999 is offline
post #748 of 912 Old 01-04-2019, 02:40 PM
Nu11u5's Avatar
Why has none of the information I’ve read on this system mentioned this. Everything made it sound like the wired rear speakers must hook up to the soundbar/receiver and that only the sub used wireless.
This fact is a huge game changer since my room layout would be very difficult to accommodate wires.
Nu11u5 is offline
post #749 of 912 Old 01-04-2019, 03:55 PM
a61688's Avatar
Quoted: 163 Post(s)
Liked: 114
Wires from surrounds go to sub, sub is installed to power behind your couch somewhere. It wirelessly communicates with the sound bar up front. The wires you are worried about....... are hidden behind your couch.
Anago likes this.
post #750 of 912 Old 01-04-2019, 04:31 PM
UHD Addict
aaronwt's Avatar
Liked: 5687
That looks like even more wires to deal with.
a61688 and guacamoleparty like this.
aaronwt is offline
Reply Soundbars
atmos , soundbar , Vizio
