Vizio SB3651-E6 36" 5.1 SmartCast Soundbar Review - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By imagic
  • 1 Post By Rip_VanWinkle
post #1 of 15 Old 06-20-2018, 08:54 AM - Thread Starter
Mark Henninger
imagic's Avatar
Quoted: 9159 Post(s)
Liked: 16150
The Vizio 36" 5.1 SmartCast Soundbar SB3651-E6 may not be new, but it offers good looks and solid performance that's well above what's typical for its MSRP.
Click here for the review: https://www.avsforum.com/review-vizi...ecast-spotify/
Mark Henninger
Editor, AVS Forum
imagic is offline
post #2 of 15 Old 06-21-2018, 07:16 AM
Liked: 0
Review to post shortly, stand by...
Got one for fathers day and posted a question, let me know if you're experiencing the same thing. I'm new so it wont let me post my link yet, but it's at the top of the page as of now.
Jason Plott is offline
post #3 of 15 Old 06-22-2018, 06:27 AM
Liked: 0
What type of TV do you have? I have a TCL Roku TV and have experienced audio lags with this sound bar. Did you notice any lag with your setup?
tylerjarvis is offline
post #4 of 15 Old 06-22-2018, 06:37 AM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 16150
No, I did not have any real issue. Usually it would be the TV lagging behind the image and not the other way around. If you switch to game mode on the TV is the lag still there? If not you need to add some delay.
Then there's the issue of "how is everything connected" and there are many options. Anyhow, as long as it's the TV picture that's lagging behind the sound, you should be able to fix it.
Mark Henninger
Editor, AVS Forum
imagic is offline
post #5 of 15 Old 06-22-2018, 08:28 AM
guacamoleparty's Avatar
Quoted: 134 Post(s)
Liked: 115
I have this soundbar and there is a firmware push that it receives that makes the subwoofer EXTREMELY loud and unusable. I had to swap it out at Costco for a stock firmware and not use the Vizio app so it would not update. Just curious if you ever had that problem, or if it was how I was using it (with an XboxOneX). I have to run the EQ in Movie because Direct exhibits the loud bass. Thoughts?
guacamoleparty is offline
post #6 of 15 Old 06-22-2018, 08:40 AM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 16150
I did not have that problem at all, the subwoofer functioned normally through the course of the review. I cannot really speculate, but that does not sound right.
guacamoleparty likes this.
Mark Henninger
Editor, AVS Forum
imagic is offline
post #7 of 15 Old 06-26-2018, 01:58 PM
Quoted: 197 Post(s)
Liked: 33
I found this to be true also. I'm not sure about the firmware update being the cause. Do you know the FW version you have now?
I could adjust the levels to make it better, but I just use the Move EQ setting as well.
Do you know if using the toslink cable from the TV output to the soundbar makes a difference?
Tfid is offline
post #8 of 15 Old 06-26-2018, 03:26 PM
Quoted: 134 Post(s)
Liked: 115
Im using the optical connector out to my Xbox one X, straight to it. I'll check the firmware version when I get home but I do recall it being different than the listed one on the Vizio website. I havent used the app in a long time, but Ill try to force it to reset and see if it pulls an update once I get home. I suspect it is either an unreleased firmware OR it updated to the wrong firmware. Annoying to say the least.
Edit: FW version the VizioCast app shows is v1.0.81 - can anyone confirm what version they have?
post #9 of 15 Old 06-30-2018, 05:54 AM
Quoted: 13 Post(s)
Thanks for the review. While the enthusiasts naturally get excited about high-end stuff, there is a place for the budget conscious too. Simplicity is also nice, for most of us. (I do recall seeing a cartoon in which one audiophile is showing off his system to another, while explaining "I like it because it is both expensive AND complicated.") Clearly, given modern technology, a lot is possible even with tight constraints. So the question I pose is in no way intended to dismiss the virtue of this package.
However, I do recall reading something Mark wrote in which he listed factors to consider regarding sound systems. Among other things, he suggested that if your speakers didn't go down to 30 Hz, the addition of a good sub could enhance enjoyment. With that in mind, I wonder if anyone has suggestions on what would be a relatively simple, low cost 5.1 system that includes response down to 30 Hz? Obviously, it would have to be more expensive than the system Mark reviews here.
Rip_VanWinkle is offline
post #10 of 15 Old 06-30-2018, 06:11 AM
Noydcom's Avatar
Quoted: 247 Post(s)
Liked: 174
Check out this Cnet Editors Choice from VIZIO SmartCast 45” 5.1 Sound Bar System | SB4551-D5: https://www.bestbuy.com/site/vizio-s...AV2eh396OIjvSg
Noyd Communications Inc. representing:
VIZIO, DVDO, 1MORE, Puro Sound Labs
Noydcom is offline
post #11 of 15 Old 06-30-2018, 06:21 AM
Quoted: 1039 Post(s)
Liked: 571
I would reccomend this https://www.parts-express.com/t652-5...oofer--300-699
Its not audiophile quality but sounds damn good for the price. and the sub goes to 25hz, or so it says
liffie420 is offline
post #12 of 15 Old 06-30-2018, 09:17 AM
Quoted: 13 Post(s)
Thank you.
Noydcom likes this.
post #13 of 15 Old 06-30-2018, 09:17 AM
Quoted: 13 Post(s)
Thank you.
post #14 of 15 Old 07-06-2018, 08:53 AM
Quoted: 207 Post(s)
Liked: 32
I have this and have not updated the FW because of others reporting problems. It is set up in my bedroom with a 43" TCL S series. I've had some sync issues. The sound is delayed, so there isn't a quick fix. The other issue I have is that there isn't a good dynamic volume for night listening when I stream content. I have truvol on, but it doesn't do anything.
It works great with the center channel cranked if you are ok with no dynamic volume.
HarpNinja is offline
post #15 of 15 Old 07-06-2018, 11:16 AM
Noydcom's Avatar
Quoted: 247 Post(s)
Liked: 174
For audio delay adjustment, go to AV Delay decrease it to its lowest level. Or go to the TCL to see if you can delay the video output.
For night listening use the Night Mode ON - the sound bar will lower bass frequency levels to provide a
more quiet environment.
Noydcom is offline
Reply Soundbars
sb3651-e6 , soundbar , Vizio
