Bose 700 vs. Sonos Beam - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By GregF2
  • 1 Post By blue comet
post #1 of 13 Old 11-15-2018, 07:45 PM - Thread Starter
Liked: 1
For marriage reasons, I needed small white speakers and a white soundbar for music primarily (I know, I know) and movies second. I have a large den with an open floor plan (den opens to dining room, foyer and kitchen). Budget was $2,000. My options were basically limited to Sonos and Bose.
I purchased the Bose 700 with 700 sub and surround speakers ($1800). I also purchased two Sonos Play:1 speakers, a Sonos Beam and a Sonos Sub ($1300).
I set them up, tuned them and played some tunes through them so I could have a side by side comparison (I did not do any movie or TV testing). Sub and speaker placement was identical and I switched between apps while listening to the same song to compare. The results were eye opening.
I fully expected the Sonos Beam to be noticeably worse due to size and price point. Not the case. I had two people listen with me and both preferred the Sonos over the Bose (in tests with and without the surround speakers).
The Bose could get louder, but at the volume I typically listen, the Sonos had a more accurate reproduction of the sound. The Bose soundbar just sounded like one big mid-range speaker and you could easily sense the sound was being manipulated by the software (DAC?). Also, the Sonos Sub was just as good, if not better than the Bose. Another surprise, IMO.
The one advantage the Bose had (aside from loudness) was that the soundstage was considerably larger, which may be a bigger deal for movies and surround effects.
One other thing I will say is that the Bose set up had some glitches (as is apparently typical with Bose) while the Sonos setup was quick and flawless.
The other notable thing is that the Bose could not handle Airplay. I've read that it will handle Airplay 2 in 2019 (via software update?), but I thought that meant that only Airplay 1 features would be supported. Apparently not. The only way to play music on the Bose is through TV, optical, or their limited music service offerings in their app.
Finally, I heard that the Sonos Beam is going on sale for Black Friday for $350 and that the Sub will be $600, so I will save another $150 when I ask Best Buy to price match in a week.
I am glad I did this test because I was leaning toward Sonos (due to price) but was going to go with Bose if the sound was MUCH better. I learned that it was Sonos that was actually better. Very happy with my purchase.
Oh, and for those wondering how my system compares to a real subwoofer and speaker setup (i.e. passive, wired, etc.), you leave a lot of sound on the table by going with small wireless speakers. But with the easy to use apps, quick set up and small, white speakers that the wife approves, its a compromise I can easily live with and still enjoy my movies and music.
Hope this helps.
Dandaman19 is offline
post #2 of 13 Old 11-21-2018, 10:18 AM
dojoman's Avatar
Quoted: 344 Post(s)
Liked: 103
FYI, Bestbuy will not price match any items from Black Friday whether you bought it prior to Black Friday or not. I tried to price match when Sonos Beam was on early access sale they won't do it. You would have to return it and re-buy it in with reduce price.
dojoman is offline
post #3 of 13 Old 12-24-2019, 06:08 AM
GregF2's Avatar
Quoted: 204 Post(s)
Liked: 129
Hope this helps.
Thanks - that was a very informative review. I am surprised that we don’t get more talk of comparing the Bose 700 system to the Sonos Beam/Playbar systems.
GregF2 is online now
post #4 of 13 Old 12-29-2019, 05:03 PM
Wiscoguy's Avatar
Just bought a Sonos Beam & so far very impressed. Used a Amazon wall mount & looks great mounted under my tv.
Wiscoguy is offline
post #5 of 13 Old 12-30-2019, 10:43 AM
GregF2's Avatar
Quoted: 204 Post(s)
Liked: 129
Anyone else test test Sonos against Bose 700?
Sony A9G 77
post #6 of 13 Old 12-31-2019, 06:53 AM
GregF2's Avatar
Quoted: 204 Post(s)
Liked: 129
Since there does not seem to be many comparisons or at least feedback of the Bose 700 system to the Sonos Playbar/Beam system, I ordered the Bose last night and will provide feedback to hopefully help others too.
It just amazes me there is not more talk about these two systems. Maybe there is and I just can’t find it. Strange...
MeanMachine likes this.
Sony A9G 77
post #7 of 13 Old 12-31-2019, 06:52 PM
MeanMachine's Avatar
Quoted: 436 Post(s)
Liked: 58
Keep us posted
Sent from my iPhone using Tapatalk Pro
MeanMachine is offline
post #8 of 13 Old 01-05-2020, 08:03 AM
Liked: 0
Mainly bc they are both over priced and not much better then the comp
Antec800 is offline
post #9 of 13 Old 01-05-2020, 10:48 AM
blue comet's Avatar
Quoted: 27 Post(s)
Liked: 30
From a movie listening standpoint I think that JBL 5.1 and Polk Magnifi Max SR beats both of them...
blue comet is offline
post #10 of 13 Old 01-05-2020, 04:10 PM
GregF2's Avatar
Quoted: 204 Post(s)
Liked: 129
I ended up keeping the Sonos Beam, Sub and Sonos One Gen 2 speakers. Not sure why you think that whole combo is overpriced as total with tax was about $1050. I got the Black Friday Costco deal for the Beam, which was $192 (includes tax). Not sure how anything can come close to beating that, especially at that price...
Sub is great and well worth it and the rears make the system complete. Could not tell any difference compared to the Bose 700 system. Especially when it is at least $800 more. I will upgrade to the Playbar, if that ever gets upgraded, as I do think sounds some what better than the Beam, but with the old tech and more money, it was not worth it.
I agree the Bose is overpriced. Especially the 700 rears.
Sony A9G 77
post #11 of 13 Old 01-05-2020, 04:12 PM
Quoted: 436 Post(s)
Liked: 58
Have you heard the GBL 5.1 compared?
post #12 of 13 Old 01-05-2020, 05:41 PM
denslayer's Avatar
Quoted: 61 Post(s)
Liked: 37
Not beam related but I"m impressed with my playbar and 2 play 1's
Sony 65inch 900F, Apple TV4k, Xbox one S, sonos 5.1,Marantz pm7000n, kEFLS50
denslayer is offline
post #13 of 13 Old 01-11-2020, 03:58 PM
Liked: 0
I have a full atmos 5.1.2 setup however for general tv viewing the tv audio was just pants.
So I looked at both Sonos and Bose soundbar options and went for the 700 Bose with sub.
I thought both systems sounded clear and crisp with good tight base however for watching Netflix or prime as well as the news on tv1 the Bose provided a wider fuller soundstage. The Bose has two side firing speaker tubes which do a pretty decent job of throwing and mimicking a 3.1 system. They do have good left and right separation.
In addition the Bose linked in really well with my home HEOS set up and had Alexa... which amused the kids who love the beat box and chewie and also enabled my missus to listen to radio without hunting for a remote...
One month in and we love the Bose. Easy to set up and does exactly what it says on the tin. No need for surrounds and atmos etc on the bar as if we really need this then ...the home theatre is just a click away (as is our projector and 100” screen).
Only downsides are :
1) I had to ask Bose tech support to send me an IR blaster to communicate with my Sony tv through their universal remote. A known issue but the tech support sent me one overnight post for free. It works a treat now.
2) the remote backlight doesn’t stay on for very long and can’t be altered. It does however work really quite well and feels nice in the hand!
3) initial set up had some teething issues with CEC but then who doesn’t.. never been an issue since.
Overall for watching tv/ Netflix general use and casual radio playback or picking up music from my home NAS it’s pretty solid. As well as for PlayStation gaming. I give it a solid 8/10 and would recommend it to those that don’t mind the price tag. However if you are comparing Bose and Sonos then you don’t mind the price tags anyway.
If you want to turn this in to a 5.1 you can add wireless surrounds but from what I have seen and heard the surrounds kind of do the job in small medium sized spaces but I would rather stick with my B&W HT and marantz set up. My living room is 18’ by 18’ and we have our main sitting position some 12’ away using a 65” Sony Master series A9f. The Bose sits really well under the tv.
Just my2p
Robbon is offline
Reply Soundbars
