soundbar advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-11-2019, 11:30 AM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
soundbar advice
I’m in the market for a new sound bar and Iv narrowed down to a few different options YSP-5600, Atlantic technologies PB-235, B&W panorama 2. Iv found a few good deals on these soundbars and could really use some advice. It’ll be going in my room and i’ll mostly be using it for movies & gaming (ps4 pro) and occasionally some music. Thanks guys
res036 is offline
post #2 of 2 Old 02-11-2019, 01:45 PM
UHD Addict
aaronwt's Avatar
Quoted: 8965 Post(s)
Liked: 5743
Well make sure they can handle up to 7.1 PCM audio then. Otherwise you would need to use legacy DD/DTS for output from the PS4. And of course that they can handle DOlby True HD and DTS-HD MA. If you plan on using it with movies. Otherwise again you would be stuck using 2.0 pcm or legacy DD/DTS with the movies.
49TB unRAID1a--53TB unRAID2--73TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
Reply Soundbars
