Vizio component help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-02-2020, 08:20 AM - Thread Starter
Liked: 0
Unsure what's this is called or where to get a replacement. It's the link between the power cord and the power supply board. It has it's own little circuit board that's burned out. Came from sound bar. Sticker says
3A99-0312-0416
62G4P181A(OA)
Any help would be appreciated thanks
Jonheras is offline
post #2 of 2 Old 01-02-2020, 09:46 AM
kjfalls's Avatar
Location: Dennison IL, just across the state line from Terre
Quoted: 339 Post(s)
Liked: 118
Do you have a model number for the sound bar? I know Visio makes nothing, they are not a manufacturer. For their designs they get parts from outside companies and rely on third-party manufacturers to assemble. The manufacturers use whatever parts are available. The parts they use today may not be they used before. Is the part number supplied a component number or card number? What is the model number of the soundbar?
kjfalls is offline
Reply Soundbars
