Adding rear speakers to Yamaha Soundbar YSP-2500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-03-2020, 07:59 AM - Thread Starter
Liked: 0
Hi,
I have a YSP-2500...very happy with it but would like to add wireless rear speakers...seems complicated..I thought about doing this:
- get a cheap used Yamaha Musiccast receiver (RX-V385)
- get 2 Musiccast 20 speakers and connect them as rear speakers...
- configure the soundbar as fronts and center
so far so easy...now the thing I am unsure about:
The YSP2500 gets its signal from TV through HDMI. I would hook up the receiver through optical out of the TV...so the soundbar and the receiver dont get the identical signal ...will I run into sync problems???
I guess I can connect the soundbar via the receiver as well to take care of that if there is an issue???
Thanks and best wishes,
Roman
Roman Fischer is offline
Reply Soundbars
