Sony HS-ST5000 Cabling - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By 3Dhereicome
post #1 of 4 Old 01-12-2020, 08:39 AM - Thread Starter
mis3's Avatar
Quoted: 41 Post(s)
Liked: 48
Best Buy installed my new TV and soundbar earlier this week.
TV: Sony 85 X950G
Sounder: Sony ST-5000
Before the new TV and soundbar, I used to connect everything to the TV and then a optical cable to feed the audio to the soundbar. I read that the optical cable is not capable to handle the new audio formats like Dolby Vision and Atmos.
The way they connected the systems were to connect nVidia Shield 2019, Blu-Ray to the TV via HDMI. Then another HDMI from the TV (eARC) port to the soundbar HDMI ARC port.
Everything works. I read that there are 2 options for the cabling; one is this current way and a 2nd way is to connect the other components to the soundbar and then 1 HDMI to feed video to the TV
For my new systems, what is the better option for cabling for best audio?
mis3 is offline
post #2 of 4 Old 01-15-2020, 10:47 PM
TheSonyExperience's Avatar
Quoted: 147 Post(s)
Liked: 163
Thumbs up
TV: Sony 85 X950G
Both of your devices support eARC, so you may as well take advantage of that. The recommended method would be to run one HDMI cable from eARC to eARC between the TV and sound bar. And if you are using a 4K Blu-Ray player of any kind, run that directly into one of the sound bar inputs.
Spoiler!
TheSonyExperience is offline
post #3 of 4 Old 01-16-2020, 01:13 PM - Thread Starter
mis3's Avatar
Quoted: 41 Post(s)
Liked: 48
Probably a stupid question.
In my current configuration where I connect all my devices to the TV, the TV feeds the audio to the soundbar via HDMI.
If I connect a device (Blu-Ray) directly to the soundbar, will the soundbar send the video to the TV; via the same HDMI eARC port?
mis3 is offline
post #4 of 4 Old 01-16-2020, 02:44 PM
3Dhereicome's Avatar
Quoted: 196 Post(s)
Liked: 133
Yes. That’s what ARC is, it’s “Audio return channel.” The HDMI carries both.
TheSonyExperience likes this.
3Dhereicome is online now
Reply Soundbars
