LG TV + ARC + Vizio Soundbar = No sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-14-2020, 01:12 AM - Thread Starter
mcaskey's Avatar
I'm starting to wonder whether this TV and soundbar combo isn't compatible.
The TV is an LG 65UB9200.
The soundbar is a Vizio 5.1.2.
In the soundbar instructions they say the TV needs to support bitstream, but I'm not able to find anything about that in the tv manual or menus, nor in google searching for "65UB9200 bitstream".
The optical audio connection works fine, but I read that optical doesn't support atmos.
mcaskey is offline
post #2 of 7 Old 01-14-2020, 07:48 AM
pbasil1's Avatar
Liked: 0
Have you tried a second HDMI cable to just eliminate the possibility of a bad cable?
What audio output options does your tv have in the settings menu?
pbasil1 is offline
post #3 of 7 Old 01-14-2020, 12:17 PM
Quoted: 42 Post(s)
Liked: 1
Did you set the sound output to HDMI ARC in your TV settings?
WkittySkittyLBoF is offline
post #4 of 7 Old 01-14-2020, 04:04 PM
Liked: 0
try the pcm setting in your tv audio menu's
Kid Poker is offline
post #5 of 7 Old 01-14-2020, 07:32 PM - Thread Starter
mcaskey's Avatar
I will try another cable.
The tv output options are either internal speakers or a combined option of auto/optical/arc. So I can't specify arc.
mcaskey is offline
post #6 of 7 Old 01-14-2020, 07:34 PM - Thread Starter
mcaskey's Avatar
I'm unable to select just arc. The option that includes arc is "auto/optical/arc"
mcaskey is offline
post #7 of 7 Old 01-15-2020, 06:26 AM
PlasmaHiDef's Avatar
Quoted: 364 Post(s)
Liked: 131
Correct, you can not get ATMOS with optical. It has to be HDMI.
LG OLED55B8PUA
LG OLED65C7P
LG UBK90
ATV 4K
Samsung HW-N950
PlasmaHiDef is offline
Reply Soundbars
