Samsung Q70R Soundbar question please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-01-2020, 11:20 AM - Thread Starter
Lend27's Avatar
Quoted: 274 Post(s)
Liked: 65
Does the Q70R soundbar do Dolby Vision passthrough?
I'm finding conflicting info online.
Lend27 is offline
post #2 of 8 Old 02-01-2020, 02:46 PM
Quoted: 21 Post(s)
Liked: 25
It does not unfortunately that's why I returned it. Samsung went all in on HDR10+ and not DV.
Family Room: Sony XBR-65Z9D, Samsung HW-Q80R soundbar/Bedroom: Sony XBR-55HX929, Sony Ht-CT800 soundbar/Weight Room: Sony XBR-46XBR8
JG526 is offline
post #3 of 8 Old 02-02-2020, 07:28 AM - Thread Starter
Lend27's Avatar
Quoted: 274 Post(s)
Liked: 65
Thank you for the reply.
I guess I will look at the LG SL8YG. They claim to do Atmos and DV passthrough. We shall see :-).
Lend27 is offline
post #4 of 8 Old 02-02-2020, 12:51 PM - Thread Starter
Lend27's Avatar
Quoted: 274 Post(s)
Liked: 65
Samsung Q70R setup question Please
I just bought a Samsung Q70R soundbar.
I connected my Nvidia Shield in to the 1 HDMI in on the soundbar, then out of the soundbar to my ARC (HDMI3) input on my Sony XBR65X930E tv. Everything works fine, including Dolby Vision passthrough.
Now for my dilemma:
I have 2 other devices connected to my tv.
HDMI2 is a Firetv 4K stick
HDMI4 is my Apple TV 4K.
When I change the input on the tv to 2 or 4, I see the correct video, but no sound from the soundbar.
I thought that since I was using ARC on both the soundbar and tv, the soundbar would automatically feed the appropriate sound to the tv.
Am I missing something? Do I have a connection wrong?
Thanks for any help you can provide.
Len
Lend27 is offline
post #5 of 8 Old 02-02-2020, 01:47 PM
RKSKYDANCER's Avatar
Quoted: 399 Post(s)
Liked: 160
Now for my dilemma:
Len
Why not just buy a good HDMI switch box (3 ports) that supports HDR & 4K and connect all your devices to it, then have the 1 HDMI cable to the Q70R soundbar input? Keep the arc HDMI connected to the TV as you have it now.
(Living Room) Sony XBR65X950G 4K TV, Harman Kardon Enchant 1300 & HK Enchant subwoofer, Sony UHP-H1 SACD & Panasonic DP-UB420 4K BD players.
(Garage) Sherwood RX-4105 Receiver, Samsung DVD/CD player, Klipsch 2.5 med oak speakers
RKSKYDANCER is offline
post #6 of 8 Old 02-03-2020, 09:45 AM - Thread Starter
Lend27's Avatar
Quoted: 274 Post(s)
Liked: 65
Great idea! That will work for me!
Len
Lend27 is offline
post #7 of 8 Old 03-21-2020, 02:26 PM
danbfree's Avatar
Quoted: 833 Post(s)
Liked: 376
It 100% absolutely does, it's that Samsung doesn't do DV on their TV's so they don't mention it on their soundbars much, but if it didn't support it at launch then it does now... but like the rear channels not muxed in thing, it definitely does now... I got mine for an insane deal at BF because people tend to believe only what comes out initially and even months after issues are fixed you still see people spreading the wrong info.
Edit: I now see OP bought one anyway and found that DV works great.
danbfree is offline
post #8 of 8 Old 03-21-2020, 02:42 PM
danbfree's Avatar
Quoted: 833 Post(s)
Liked: 376
Now for my dilemma:
Len
Of those 3 devices I only have the Shield and I run mine through the soundbar too, I have a XBR75X900F, so a year newer, so when I tried moving the Shield off soundbar ARC over to HDMI 3 I just had to restart the Shield before audio kicked in since it's different formats supported... Then DV and Atmos totally still worked through Netflix too.
danbfree is offline
Reply Soundbars
