Best small sub for a condo - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-17-2020, 03:13 PM - Thread Starter
Liked: 0
Hi:
I moved earlier this year from a home that had a dedicated home theater and dual PSA 18” subwoofers. I’ve had to live with a soundbar (albeit a very good one, Sennheiser Ambeo), but I miss some of the low end impact I used to have.
While I want more low end grunt, I also have to be sensitive to my neighbors and not overdo it. I plan to install a auralex subdudes under the subs to help with transmission through the floor (we live on the second floor of a 3 floor building) I’m open to further suggestions on how to maintain harmony with my neighbors and still have some good low end.
I’ve narrowed my choices to 2:
1. REL 1003
2. RSL Speedwoofer 10
The REL is a bit smaller and will fit better, it also probably has a bit less low end, but probably greater refinement. They’re both priced similarly and I plan to get duals.
Any and all suggestions gratefully welcome!
vidiot33 is offline
Reply Soundbars
