Convert 2D to 3D - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-09-2017, 10:20 PM - Thread Starter
cherishjoo's Avatar
Liked: 0
Convert 2D to 3D
Is there a free program that is able to convert my 2D videos to 3D?
I just purchased a TV that supports 3D playback and want to have a try and enjoy 3D movies.
cherishjoo is offline
post #2 of 4 Old 10-10-2017, 07:06 AM
Swederic's Avatar
It's possible that your TV may already have this feature.
Swederic is offline
post #3 of 4 Old 10-11-2017, 10:16 PM
Quoted: 66 Post(s)
Liked: 9
I have owned two TVs that supposedly auto-convert 2D to 3D, but they are honestly pretty bad at it. When movies are actually produced in 3D, it's a lot of manual work to apply it, and the director will control how it's done, and the result is exquisite. The automatic conversions done by a TV are just making guesses, so it's regularly wrong and an unwatchable experience. If you want to enjoy 3D movies, you should just buy some 3D discs, or rent from something like https://www.store-3d-blurayrental.com. Hope that helps!
David
Looking to buy any extra 3D movies/discs! Send me a PM!
webdj777 is offline
post #4 of 4 Old 10-14-2017, 06:01 PM
Deja Vu's Avatar
Quoted: 1002 Post(s)
Liked: 1052
If you use a computer try PowerDVD -- it has a 2D to 3D conversion, which is pretty good if you set intensity to around 30%.
The 2016 LG OLEDs have the best 2D to 3D conversion I've seen from any manufacturer; however, you have to go into 3D settings and set it to manual and set point-of-view to -5 or -6 and depth to around +15 or so.
Deja Vu is offline
Reply 3D Content
