Advice on a BF flat panel wall mounts please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-17-2019, 02:25 PM - Thread Starter
PRO710HD's Avatar
Quoted: 86 Post(s)
Not sure if this is the correct forum as I didn't see a dedicated forum for flat panel accessories?
I need 2 flat panel mounts. I see that Bestbuy has the Sanus brand mounts on their BF ad. Any advice/opinions on those mounts? I'm hoping to drill as few holes as possible as it's going into brick masonry/stone (Florida house) walls.
1 55" Plasma fully adjustable tilt left/right adjustable
1 39" LCD Panel fixed or tilt mount
PRO710HD is offline
post #2 of 5 Old 11-17-2019, 03:28 PM
hiperco's Avatar
Quoted: 195 Post(s)
Liked: 120
Take a look at monoprice and Harbor Freight mounts.
hiperco is online now
post #3 of 5 Old 11-23-2019, 03:03 AM
jimmyv2000's Avatar
Good commercial grade mounts
Home Depot sells great sturdy commercial grade mounts. These work well for brick/masonry. They have one i paid almost $60 for it.
This is a full motion mount and you drill 2 holes into your brick.
https://www.homedepot.com/p/Commerci...kn14kWBQyGKQI0
jimmyv2000 is offline
post #4 of 5 Old 11-25-2019, 08:50 AM
kiddk1's Avatar
if you have an amazon account check here, lots of discounted amazon products including mounts
https://www.vipon.com/
"I'm not in this world to live up to your expectations and you're not in this world to live up to mine. "
-Bruce Lee
kiddk1 is offline
post #5 of 5 Old 11-28-2019, 10:06 AM
rikhek's Avatar
Quoted: 21 Post(s)
MONOPRICE - Excellent quality at give away pricing. Amazing.
rikhek is offline
Reply LCD Flat Panel Great Found Deals!
