Martysub Flatpacks/Veneer Flatpacks - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 62Likes
post #301 of 393 Old 12-21-2014, 10:53 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 276
is the Marty cube a perfect square cube 24x24x24 inches?
Who needs 4K?... just go see your optometrist.
NODES is offline
post #302 of 393 Old 12-22-2014, 11:33 AM - Thread Starter
chalugadp's Avatar
Quoted: 1684 Post(s)
Liked: 1574
Not quite. Overall is 24" by 24" by 25.5" wide
chalugadp is offline
post #303 of 393 Old 12-22-2014, 11:35 AM - Thread Starter
chalugadp's Avatar
Liked: 1574
Originally Posted by DotJun View Post
You're saying the silenx is quieter than the noctua?
After running mine for a couple of days there pretty close. Both are good.
post #304 of 393 Old 12-22-2014, 11:38 AM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 276
Thanks, cannot wait to start gluing this sucker together.
NODES is offline
post #305 of 393 Old 12-23-2014, 11:30 AM
juiceblrc's Avatar
Quoted: 20 Post(s)
chalugadp,
Thanks for the sub demo Sunday. You have a nice system! Thanks for the general subwoofer advice. And by the way I tried audioclick.net & I have massive peaks & valleys in my frequency. Now I am trying REW and struggling. I posted the question under REW help (in DIY forum) if you get a minute.
For anyone considering these flatpacks the end result is good. While I didn't see the actual flatpacks the subwoofers looked good & performed well. SLP was high & it sounded great. The woofers didn't need to that move much & there was very little air flow our of the ports. I guess that is what you get when you have 4 subs in a room.
The minparty is HUGE! It looked like a small refrigerator. The martycubes were nice & small.
juiceblrc is offline
post #306 of 393 Old 12-23-2014, 11:47 AM - Thread Starter
chalugadp's Avatar
Liked: 1574
I don't use rew. With test tones from 15 to 100 hz every 5 hz you will get 95% of rew. Post the Spl numbers you recorded and I'll suggest some peq. I know you can't move your sub I believe.
Rew is great for nice looking graphs and there's a tonne of info besides spl available like waterfall plots. Most including myself have no idea what that stuff means. To achieve smooth bass response rew isn't needed. If your really determined to use rew then I am sure others will chime in.
post #307 of 393 Old 12-23-2014, 12:14 PM
juiceblrc's Avatar
Quoted: 20 Post(s)
I will post the PM you the frequencies when I get home. Your right I can't move my sub.
There were just so many huge peaks & valleys that I would be boosting & cutting everywhere. So, I thought REW would be best/quickest/easiest to use. My mistake.
post #308 of 393 Old 12-23-2014, 01:11 PM - Thread Starter
chalugadp's Avatar
Liked: 1574
Rew will just graph what your going to post. It just shows you response and suggests peq filters. If you Post numbers I can suggest filters. It will take 2 or three times with measurements to get it as smooth as possible. With only one sub you won't get really flat response but we can make improvements.
post #309 of 393 Old 12-27-2014, 12:28 AM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 276
Regarding using dowels as bracing:
What size of dowels should I get for the martycube?
Do you just glue them in place or Glue and nail them?
Can you over dowel an enclosure?
NODES is offline
post #310 of 393 Old 12-27-2014, 07:54 AM
vitaminbass's Avatar
Quoted: 24 Post(s)
There were quite a few using SI drivers in the older thread. On their website they have two different 18s, one quite a bit cheaper (and less capable) than the other. Which one was typically used? Or maybe they used to just carry one, sold it out and now have moved on to different product?
vitaminbass is offline
post #311 of 393 Old 12-27-2014, 02:10 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 276
PM'd
NODES is offline
post #312 of 393 Old 12-27-2014, 05:07 PM
joe801's Avatar
Quoted: 118 Post(s)
Liked: 89
Does anyone have pics of any complete Marty subs? Especially the mini marty and the marty cube. Trying to get an idea of size before ordering. I know the mini will be much larger. But would like to see what it looks like in a room.
joe801 is offline
post #313 of 393 Old 12-27-2014, 05:58 PM
cessna1466u's Avatar
Quoted: 117 Post(s)
Liked: 206
cessna1466u is offline
post #314 of 393 Old 12-27-2014, 06:32 PM - Thread Starter
chalugadp's Avatar
Liked: 1574
It's a little dusty
Minimarty
joe801 likes this.
post #315 of 393 Old 12-27-2014, 09:05 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 276
I just completed my martycube, I can take pictures of it beside my POLK Tsi 500 and my current SVS PB-2000 sub woofer.
joe801 likes this.
NODES is offline
post #316 of 393 Old 12-27-2014, 09:06 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 276
It's a little dusty
Minimarty
Any what kind of speaker is that in the picture for comparison purposes?
NODES is offline
post #317 of 393 Old 12-27-2014, 09:13 PM - Thread Starter
chalugadp's Avatar
Liked: 1574
Done already..... Man your fast. I believe thats a record . he only has had it for 4 hours . pics please or it didn't happen.
post #318 of 393 Old 12-27-2014, 09:31 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 276
All I need to do is the Speakon Jack hole and do I make it above the port on the side of the box?
NODES is offline
post #319 of 393 Old 12-27-2014, 09:46 PM - Thread Starter
chalugadp's Avatar
Liked: 1574
Best is side cuz only one wall to drill thru. Can put it in back but has to go thru port wall. Can't put it above port wall .
post #320 of 393 Old 12-27-2014, 09:52 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 276
Wife wants it on the side so we can move it back a bit further. Just to confirm the speakon will go above the "port bottom"marked piece of wood.
NODES is offline
post #321 of 393 Old 12-27-2014, 09:53 PM - Thread Starter
chalugadp's Avatar
Liked: 1574
Yes.
post #322 of 393 Old 12-27-2014, 11:06 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 276
So glue and brad nails is all that is required to hold this beast together? No screws necessary?
NODES is offline
post #323 of 393 Old 12-28-2014, 05:43 AM
joe801's Avatar
Quoted: 118 Post(s)
Liked: 89
Thanks for the pics guys. Looks like I will be getting the marty cube.
joe801 is offline
post #324 of 393 Old 12-28-2014, 10:30 AM
Liked: 0
I cant exactly pm you yet... new to the forums and haven't reached the 15 post count.. lol Anyway you can figure out a price for me via skype or something?
EllipticMonkey is offline
post #325 of 393 Old 12-28-2014, 11:01 AM - Thread Starter
chalugadp's Avatar
Liked: 1574
Yup
post #326 of 393 Old 12-28-2014, 11:13 AM
brendelac's Avatar
Quoted: 200 Post(s)
Liked: 106
Does anyone happen to know if/when the UXL-18 will be available again? I've emailed a few times now with no response.
brendelac is offline
post #327 of 393 Old 12-28-2014, 01:10 PM
jbrown15's Avatar
Quoted: 2524 Post(s)
Liked: 1997
Have you tried calling? Often the simplest and most direct line of communication is often the easiest.
I've heard that the current lead-time is around 8 weeks.
jbrown15 is offline
post #328 of 393 Old 12-28-2014, 02:26 PM
brendelac's Avatar
Quoted: 200 Post(s)
Liked: 106
Do you have their phone number? It's not on the contact page.
post #329 of 393 Old 12-28-2014, 02:52 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 276
Did you email over the holiday season?
NODES is offline
post #330 of 393 Old 12-28-2014, 03:05 PM
brendelac's Avatar
Quoted: 200 Post(s)
Liked: 106
Roughly 10 days ago and then about 6-8 weeks before that.
Closed Thread Audio Gear
