WTB 2-channel power amplifier/2 monoblock amplifiers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-04-2016, 11:08 AM - Thread Starter
phillyd32's Avatar
Quoted: 39 Post(s)
Looking for a 2-channel amplification solution. I have a Pioneer SC-85 for processing/preamp. I was looking at an Emotiva XPA-200, but they're being discontinued and can't find any used or new in stock. Any similarly powerful/clean solution is in consideration. Looking to spend no more than $400. I live near Louisville, KY for shipping/pickup purposes.
Source: HTPC, Pro-Ject Debut Carbon Esprit SB Beatles Edition > Pro-Ject Phono DC
Display: Vizio M55-E0 55" 4K TV
Audio: Marantz AV8003 | Crown XLS 1002 | Klipsch Cornwall III SE Matte Black
phillyd32 is offline
post #2 of 13 Old 01-04-2016, 12:40 PM
chadamir's Avatar
Quoted: 177 Post(s)
Liked: 60
Is this for a two channel setup? The emotiva is only going to give you about 15 more watts/ch (8 ohm) at two channels driven over the SC-85.
chadamir is offline
post #3 of 13 Old 01-04-2016, 06:21 PM - Thread Starter
phillyd32's Avatar
Quoted: 39 Post(s)
I've already side-by-side tested the amp from the Pioneer (rated 135w) with a Yamaha R-S700 and the Yamaha (rated 100w) and the Yamaha sounded much better. Power isn't really the issue, its amp quality.
post #4 of 13 Old 01-04-2016, 06:57 PM
gentlejax's Avatar
Quoted: 48 Post(s)
Liked: 27
im glad you said that. most of us that have owned enough gear have figured out that AVR units dont have the amp sections that stand alones do. even if that pioneer is a ICE amp or whatever.
gentlejax is offline
post #5 of 13 Old 01-05-2016, 04:19 PM
jmd1982's Avatar
Quoted: 66 Post(s)
i have 2 xpa-1's for sale but iam sure shipping would be an arm and a leg from new york they are very heavy
jmd1982 is offline
post #6 of 13 Old 01-05-2016, 07:25 PM
Kensmith48's Avatar
Quoted: 128 Post(s)
Liked: 36
I have a 2 channel ATI 1502 for sale. 150 w per channel. $250.00 + shipping. Shipping weight is approx.50 lbs. from 48611. I can supply pics if interested.
Kensmith48 is offline
post #7 of 13 Old 01-06-2016, 12:05 PM
The Village Idiot
Knucklehead90's Avatar
Quoted: 848 Post(s)
Liked: 786
Take a look at this Acurus 200x3 amp. 200wpc into 8ohms and 250wpc into 4ohms. $300. Nice price. I'd contact the seller to see if this is the older flat faced amp or the later one which has an oval machined into the front face with the name Acurus - by Mondial logo inside. Both models are Mondial USA built amps. I've owned 3 Acurus amps and found them all to be very stout. Even the A150 had plenty of power. Many good reviews to be found online. I'd jump on that amp if I were looking for something to drive the front three speakers.
Yamaha A-S1000 - Salk Song Towers - HTPC (Linux) - Oppo 103 - Marantz TT42 (WWG1WGA) --- Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #8 of 13 Old 01-06-2016, 12:22 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4802
So you've determined it's the actual amp section rather than the processing in either unit? Why wouldn't the Pioneer continue to sound like the Pioneer with an external amp?
lovinthehd is offline
post #9 of 13 Old 01-06-2016, 12:25 PM - Thread Starter
phillyd32's Avatar
Quoted: 39 Post(s)
I ran pre-amp outs from the Pioneer to the main in on the Yamaha (goes straight to the amp) and it was a major improvement over the Pioneer. The only factor that changed was the final amp stage.
post #10 of 13 Old 01-06-2016, 12:29 PM
lovinthehd's Avatar
Liked: 4802
Sounded more like an AB comparison. Did you level match for your comparison? Did you try it the other way around? Not my experience that external amps make a profound difference....not compared to processing at least.
post #11 of 13 Old 01-06-2016, 01:13 PM - Thread Starter
phillyd32's Avatar
Quoted: 39 Post(s)
I think you might be severely overestimating the amp stage in the SC-85, it's an enormous difference. Yes for small differences blind AB with volume equalization is needed but you can tell the difference in two vastly different products without that.
post #12 of 13 Old 01-06-2016, 01:15 PM - Thread Starter
phillyd32's Avatar
Quoted: 39 Post(s)
I'll do some research and send you a PM
Thanks for the input, I'll take a look.
post #13 of 13 Old 01-06-2016, 03:42 PM
smfins's Avatar
Quoted: 58 Post(s)
Xpa-2
I have an Emotiva XPA-2 i can do for $500 shipped. its a GEN 1. PM me if interested. thanks!
smfins is offline
Reply Audio Gear
