FS: 4x JBL 8340A surround speakers (with 2517 mounts) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-08-2017, 03:07 PM - Thread Starter
richard11's Avatar
Arrow Sold: JBL 8340A surround speakers (with 2517 mounts) $350
** sold
For sale are four JBL 8340A surround speakers, along with four matching JBL 2517 swivel mounts.
They are used but in perfect working condition. The grilles are excellent with no holes or scratches. The backs have some scratches but nothing major. The 2517 mounts are brand new and never used. Selling due to rearrangement of theater room. These speakers are simply amazing, including for front channel use. They are so efficient you only need a receiver to drive them to extremely loud levels, cleanly.
** sold **
$350 for one pair including pair of 2517 mounts
+$55 ground shipping to lower 48 states (free pickup in Austin, TX area)
If you want all four:
$660 for all four including four matching 2517 mounts
+$95 ground shipping to lower 48 states (free pickup in Austin, TX area)
JBL 8340a
High Power Cinema Surround Speaker for Digital Applications
SPECIFICATIONS
Frequency Range: 45 Hz - 18 kHz (-10 dB)
Frequency Response: 75 Hz - 16 kHz (±3 dB)
Power Rating: 250 watts continuous pink noise, 1000 watts peak
Sensitivity: 96 dB SPL, 1W @ 1m (3.3 ft)
Nominal Impedance: 8 ohms
Hor. Coverage Angle (-6 dB): 100° averaged 400 Hz to 12 kHz
Vert. Coverage Angle (-6 dB): 80° averaged 400 Hz to 12 kHz
Directivity Factor (Q): 7 averaged 400 Hz to 12 kHz
Directivity Index (DI): 8.4 dB averaged 400 Hz to 12 kHz
Crossover Frequency: 2.2 kHz
High Frequency Contour: ISO2969 Curve X surround contour
Polarity: EIA (Positive voltage to RED terminal gives
Low Frequency Transducer Nominal Diameter:: 250 mm (10 in)
High Frequency Transducer Nominal Diameter: 25 mm (1 in)
Downward Firing Angle: Nominal 20° when mounted flush on back panel
Enclosure Material: Textured Black H.I.P.S. Plastic
Grille Color: Black
Input Connectors: 5-way binding posts
Dimensions (H x W x D): 457 mm x 457 mm x 260 mm (18 in x 18 in x 10.25 in)
Net Weight: 8.6 kg (19 lb)
JBL 2517 Speaker Mount
Pan and Tilt Rotations
FEATURES
Alloy steel
Black powder coat paint
Designed for 8320, 8340A, and 8350 surrounds
SPECIFICATIONS
Working Load 20 lbs. (9 kg)
Shipping wgt 4 lbs. (1.8 kg) pair
Pack count 2 units/carton
Links to JBL's site:
http://cn.jblpro.com/china/products/...-systems/8340a
http://www.jblpro.com/www/products/c...-speaker-mount
ID:	2074633   Click image for larger version
ID:	2074641   Click image for larger version
richard11 is offline
post #2 of 6 Old 05-16-2017, 09:15 AM
Umar_Naseer's Avatar
Quoted: 38 Post(s)
PM sent
Umar_Naseer is offline
post #3 of 6 Old 05-16-2017, 12:53 PM
Quoted: 38 Post(s)
I'm interested buying all 4. Please PM me to discuss details.
post #4 of 6 Old 05-17-2017, 06:10 PM - Thread Starter
richard11's Avatar
Sale pending
post #5 of 6 Old 05-24-2017, 05:09 AM
Quoted: 72 Post(s)
Jbl 8340a
Hi Richard,
Have you sold your 4 x JBL 8340A ?
If not I would be happy to buy them.
Kind Regards
Klaus
Klaus.S is offline
post #6 of 6 Old 05-24-2017, 05:17 AM - Thread Starter
richard11's Avatar
Sorry, forgot to update. They are sold.
Reply Audio Gear
8340a , Jbl , speaker , surround
