Anthem STR Integrated Amplifier - Black Chassis - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-12-2019, 07:39 AM - Thread Starter
marty9876's Avatar
Quoted: 22 Post(s)
Arrow Anthem STR Integrated Amplifier - Black Chassis
***Sold***
Awesome 2ch integrated amplifier! Solid amplifier which doubles down (200w @ 8 ohm to 400w @ 4 ohms), advanced bass management with stereo sub outputs combined with ARC room correction checks all the boxes for a great 2ch setup. I used this with dual subs and the performance clearly stood apart from the rest. I was all digital/streaming, has phone inputs for the vinyl folks.
Selling due to unplanned move, no place for a 2ch setup in new house and I'm going to build (hopefully!) a dedicated HT. I enjoyed my adventure into 2ch, perhaps there will be a space in the basement in the future but for now I'm going feet first into HT.
Purchased on 5/19/18 from an authorized dealer. I can't find a single cosmetic flaw in the unit. I have original double boxes and all accessories.
Manufacturer specs: https://www.anthemav.com/products-cu.../page=overview
Number of reviews and documentation: https://www.anthemav.com/products-cu...r/page=reviews
$3,800, I'll pay shipping so I can ensure it's insured. Paypal fees on buyer.
  • High-resolution preamplifier section
  • High current, high output amplifier section
  • Amplifier uses 8 bipolar output devices per channel, a toroidal transformer power supply, and Advanced Load Monitoring for 200W at 8 ohms, 400W at 4 ohms, 550W at 2 ohms, all continuous
  • Anthem Room Correction (ARC®) optimizes in-room response for perfect sound
  • Bass management for two subwoofers, in mono or stereo
  • Up-sampling of lower-resolution sources to 32-bit/192kHz
  • S/PDIF coaxial and optical, and balanced AES/EBU inputs
  • Asynchronous USB Audio Input supports 32-bit/384kHz PCM, and DSD 2.8 / 5.6 MHz sources
  • MM and MC phono, balanced XLR, and single-ended analog inputs
  • Analog Direct mode
  • Graphic Front Panel Display for easy setup and navigation
  • Controllable via Ethernet, RS-232, or supplied IR remote
  • Available in Silver and Black Finishes
  • Crafted in Canada
ID:	2524674   Click image for larger version
ID:	2524680   Click image for larger version
ID:	2524682   Click image for larger version
ID:	2524688   Click image for larger version
ID:	2524692   Click image for larger version
marty9876 is offline
post #2 of 2 Old 02-13-2019, 08:11 PM
davidylan's Avatar
Quoted: 31 Post(s)
  • Crafted in Canada
Wish this had the HDMI I/O
7.1 Setup | Display: Screen Innovations 7 Series Zero Edge - Black Diamond 1.4 gain + Sony VPL-VW600ES | Processor: Anthem AVM60 | Amps: McIntosh MC8207 | Speakers: Paradigm Signature S8 V1 (2), C5 V1, (2) S2 V1, (2) Triad onwall gold surrounds | Subs: (1) SVS Ultra SB13
davidylan is offline
Reply Audio Gear
