Salk Sound Veracity HT3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-18-2019, 07:49 AM - Thread Starter
point1's Avatar
Quoted: 226 Post(s)
Liked: 113
Hello All!
Selling this pair of great speakers as my new pair of SS 9.5s are on their way!
These are incredible sounding speakers with great looks.
I have the packaging but unfortunately won't ship to their dimensions and weight. Local pickup only, Socal ZIP 92860
Asking for $3000 for the pair.
A VERACITY 3-WAY
The Veracity HT3 is a true 3-way design that is essentially ruler-flat from 34Hz to 25,000Hz, with a frequency response from 29Hz - 40kHz +/- 3dB.
TRANSPARENT AND ACCURATE
HT3's are extremely transparent and literally disappear into the room. The top end is crystal clear with detailed overtones that make instruments and voices come alive.
LARGE SOUNDSTAGE
The soundstage is deep and wide with instruments and vocals precisely located within a panorama of sound. That, coupled with detail and transparency help create that "you are there" experience.
DEEP MUSICAL BASS
The HT3's 10 inch long throw woofer can handle all you can throw at it. Deep, tight musical bass is just part of the package.
FLAT RESPONSE
As you can see in this frequency response plot, the Veracity HT3 design is extremely accurate with ruler flat response. You will hear the music EXACTLY as it was produced.
PHASE COHERENT
In addition to flat frequency response, the Veracity HT3 design is phase coherent in the crossover regions resulting in a speaker that images exceptionally well.
Model Veracity HT3
Design 3-way ported
Tweeter RAAL ribbon
Midrange Seas W18
Woofer Custom 10 inch Response +/- 3db29Hz - 40kHz
Sensitivity 84 dB
Impedance 8 ohms
Alignment Ported
Dimensions12 W x 15 D x 40 H
Weight87 pounds
Retail Price$6495 per pair
ID:	2581550   Click image for larger version
ID:	2581552   Click image for larger version
ID:	2581554   Click image for larger version
ID:	2581556   Click image for larger version
point1 is offline
post #2 of 2 Old 06-22-2019, 03:39 PM - Thread Starter
point1's Avatar
Quoted: 226 Post(s)
Liked: 113
Bump
point1 is offline
Reply Audio Gear
