FS: Klipsch KS-525-THX Surround Speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-21-2019, 02:13 PM - Thread Starter
McLuvin's Avatar
Quoted: 354 Post(s)
Liked: 149
FS: Klipsch KS-525 THX Surround Speakers
In brand-new/mint condition and they probably do not have more then 10 hours on them. They were placed gently on fabric stands and not mounted.
Non-smoking, no pets, and all items include original packaging and manual as seen in the picks.
From the manufacturer:
https://www.klipsch.com/products/ks-...-speakers-pair
As part of the THX® Ultra2 family, the KS-525-THX surround loudspeaker with Klipsch Wide Dispersion Surround Technology™ (WDST) brings a new dimension of reality to home theater by using the same high-performance technology as the Klipsch professional cinema systems.
Features:
  • Two 5.25-inch Cerametallic™ woofers
  • Dual 5-inch square Tractrix® Horn tweeters
  • Top-of-the-line internal wiring
Specifications:
Frequency Response80Hz-20kHz ± 3dBSensitivity96dB @ 2.83 volts / 1 meterNominal Impedance8 ohms compatibleHigh Frequency Crossover2100HzPower Handling100 watts maximum continuous (400 watts peak)Enclosure TypeSealedEnclosure MaterialMedium density fiberboard construction (MDF)TweeterTwo 1" (2.5cm) magnetically shielded titaniumdome compression drivers with neodymium magnet structuresHigh Frequency Horn5" square 90° x 60° Tractrix® HornsWooferTwo 5.25" (13.3cm) magnetically shielded, Cerametallic™ cone, cast aluminum frame driversInputsTwo sets of binding post speaker terminals (connected via brass strap jumpers)Dimensions13.75" (35cm) H x 13" (33cm) W x 8.5" (21.6cm) DWeight20 lbs. (9.1kg)FinishGalaxy Black cabinet with Black anodized aluminum fasciaMounting2-bolt pattern 1/4"-20 thread
$850 Shipped from Texas
eBay ID: greg_goff35oz
Audiogon ID: goffg
Please let me know if you have any questions. Thanks for looking.
ID:	2593220   Click image for larger version
ID:	2593222   Click image for larger version
ID:	2593224   Click image for larger version
McLuvin is offline
Reply Audio Gear
