FS: Fusion 8 MTM center 98.5 dB - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By bear123
post #1 of 7 Old 09-22-2019, 09:51 AM - Thread Starter
bear123's Avatar
Quoted: 2747 Post(s)
Liked: 4226
FS: DIYSG Fusion 8 MTM center channel 98.5 dB
Up for sale is this extremely capable, Fusion 8 MTM dual 8" woofer center channel with a horn loaded compression driver. This is one of the most capable center channels you can get for its size without stepping up to larger and or much more expensive offering from PSA or JTR.
$499
With a sensitivity of 98.5 dB and 8 ohms, this center channel will very easily achieve clean, clear, uncompressed reference level output even with a low powered AVR. Amazing slam, impact, and dynamics with extremely accurate frequency response. Even the $1500 Klipsch RC64-III comes nowhere close to the capability of this speaker as the Klipsch is only 93 dB sensitive. So this center channel speaker only needs 1/4th the power of the much more expensive Klipsch center channel.
A shot showing the cab. Looking closely you can see it is well braced. Built by a professional cabinet shop.
Here's the response at my listening position. This is a very neutral, accurate speaker:
The finish is a nice smooth satin black. I don't want to sell this speaker but it will no longer fit under my new, much larger display. . My loss is your gain.
ID:	2618706   Click image for larger version
ID:	2618708   Click image for larger version
Name:	Fusion 8 Center Channel.jpg
Mike Butny likes this.
bear123 is offline
post #2 of 7 Old 10-02-2019, 06:29 PM - Thread Starter
bear123's Avatar
Liked: 4226
11 day bump for update with frequency response.
bear123 is offline
post #3 of 7 Old 10-03-2019, 02:17 PM
Quoted: 56 Post(s)
Liked: 8
Do you have the dimensions? I'm about to pull the trigger on a PSA MTM-210c, but I like to save money!
colinmatheny11 is offline
post #4 of 7 Old 10-03-2019, 04:55 PM
mlkmgr's Avatar
Quoted: 26 Post(s)
Liked: 39
Interested but what type of mains would you mate this to?
mlkmgr is offline
post #5 of 7 Old 10-04-2019, 05:44 PM - Thread Starter
bear123's Avatar
Liked: 4226
10" high, 12" deep, 27" wide. 38 lbs. Front ported so close to a wall or in a cubby works.
bear123 is offline
post #6 of 7 Old 10-04-2019, 05:46 PM - Thread Starter
bear123's Avatar
Liked: 4226
It should work well with whatever mains you have, largely a matter of preference and intended use, what fits in your space, etc. This speaker is neutral and accurate and plays very loud with very low distortion, so very high fidelity. I would pair it with speakers that have similar qualities and it should match up well. It might not pair as well with highly colored speakers like B&W.
bear123 is offline
post #7 of 7 Old 10-24-2019, 06:13 PM - Thread Starter
bear123's Avatar
Liked: 4226
Bump, $499 shipped.
bear123 is offline
Reply Audio Gear
