DIYSG HTM-8's and Fusion 8 MTM Center - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-27-2019, 04:02 PM - Thread Starter
bear123's Avatar
Quoted: 3239 Post(s)
Liked: 4854
Two DIYSG HTM-8 speakers fully assembled and finished in satin black. Used the CNC cut flat packs and pre-assembled crossovers. Lined with denim insulation. The area inside the ports is painted black so the port holes are black without any visible materials inside.
HTM-8: $599/pair SOLD
Sensitivity 94 dB 1w/1m
Impedance: 8 ohm
Power handling: 250 watts
Frequency response: 70-20KHz +/-3dB although they extend much lower in my room(Audysey sets them to 40 or 60) so perfect for crossing to subs.
Fusion 8 center channel: SOLD
These speakers will easily play very clean and clear to reference level even with AVR power. Frequency response is extremely accurate and very even across a very wide seating area for superb sound quality.
If someone wants a great set of DIYSG speakers for LCR without all the work involved, here is a turnkey set at cost.
Prefer local pickup SW PA but will ship at buyers cost.
Here is an image of my *in room* frequency response without any eq. This is with the speaker stuffed into a corner in a bookshelf resulting in the big peak in low frequency output. Obviously, applying eq below 500 Hz to flatten out this response will make the speaker +/- a dB or two out to 10K with a gradual decline(as is generally desired) above 10 KHz, but I wanted to show the native response of the speaker in room. Actually, this boost down low that had to be eq'd down by room correction simply results in much higher headroom in the lower frequencies.
For any serious inquires, I also have sweeps done at all seating locations of my wide sectional, which show a very smooth, consistent response across all seats. A *very* well designed speaker with an amazing waveguide.
ID:	2632946   Click image for larger version
bear123 is offline
post #2 of 7 Old 11-10-2019, 04:27 PM - Thread Starter
bear123's Avatar
Liked: 4854
Center channel is sold, HTM-8's still available, $325/each.
bear123 is offline
post #3 of 7 Old 11-20-2019, 02:46 AM - Thread Starter
bear123's Avatar
Liked: 4854
Bump, HTM-8's still available. If you ever wanted high efficiency DIY speakers but don't want to do the work, here's a finished set available for what the raw parts would cost you unassembled.
bear123 is offline
post #4 of 7 Old 01-11-2020, 05:00 AM - Thread Starter
bear123's Avatar
Liked: 4854
New lower price: $599 for the pair.
Name:	HTM-8 On axis in room gated.png
bear123 is offline
post #5 of 7 Old 01-20-2020, 08:16 AM
thisismyname123's Avatar
Quoted: 168 Post(s)
Liked: 64
Still available? I was looking to add a bunch of these for surround and atmos but I only see HTM 12 on the DIYSG site.
Im checking with Erich if he'll have them available again
thisismyname123 is offline
post #6 of 7 Old 01-22-2020, 08:12 PM
Audio Pack Rat
sealmaniac's Avatar
Quoted: 85 Post(s)
Liked: 133
I will take them! Pm sent.
Spoiler!
sealmaniac is online now
post #7 of 7 Old 01-23-2020, 02:28 AM - Thread Starter
bear123's Avatar
Liked: 4854
Here's the photo you asked for:
bear123 is offline
Reply Audio Gear
