FS: ROTEL RMB-1075 Power Amplifier 5x120w - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-01-2019, 08:52 AM - Thread Starter
Liked: 0
Selling my ROTEL RMB-1075 5 channel power amplifier in very good condition.
This multi-channel power amplifier delivers 120 watts (all channels driven), thanks to a power supply composed of a generous 1,500 VA toroidal transformer and eight 10,000 µf British-made Slit Foil capacitors. 20 output devices, each of which is rated for 130 watts and 15 amperes of current capability, make full use of the supply 's potential. The RMB-1075 's generous headroom and state of the art signal-to-noise measurements ensure unsullied reproduction of the most dynamic as well as the most delicate sonic nuances. Complete with gold plated RCA and DB-25 input connectors, the RMB-1075 is ideally suited for either home theater applications or bi-amped systems optimized for music reproduction. Separate 12 volt "trigger " input and output jacks make this amplifier well suited for fully integrated systems with total remote control capability.
RMB-1075 5-channel, THX power amplifier
Frequency response: 10Hz-80kHz, ±0.05dB
Continuous power output: 120Wpc into 8ohms, 20Hz-20kHz
Speaker impedance: 4ohms minimum
Input impedance/sensitivity:33kohms/1.5V
Signal/noise: 115dB, A-weighted
Total harmonic distortion: <0.03%, 20Hz-20kHz
Intermodulation distortion: <0.05%
Dimensions: 1615/16" x 71/8" x 15" (WxHxD)
Weight: 43 lbs
Was $1100 new.
$450.00 + shipping
Name:	ROTEL 1075_Front2.jpg
ID:	2647974   Click image for larger version
Name:	ROTEL 1075_Front1.jpg
ID:	2647976   Click image for larger version
Name:	ROTEL 1075_back.jpg
ID:	2647978   Click image for larger version
Name:	ROTEL 1075_back2.jpg
ID:	2647980   Click image for larger version
Name:	ROTEL 1075_box.jpg
Builtbyalpine is offline
post #2 of 3 Old 12-03-2019, 03:42 PM
boltonic's Avatar
Quoted: 168 Post(s)
Pm sent. Haven’t heard back
boltonic is online now
post #3 of 3 Old 12-03-2019, 05:27 PM
Liked: 0
Location?
Neuht is offline
Reply Audio Gear
