Odyssey Audio Candela vacuum tube preamplifier with optional remote included - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By joejoe571
post #1 of 26 Old 02-21-2020, 09:48 AM - Thread Starter
la10slgr's Avatar
SOLD Odyssey Audio Candela vacuum tube preamplifier with optional remote included
***AVAILABLE SOON - SEE BELOW***
Asking $900 obo
Odyssey Audio Candela vacuum tube preamplifier with optional remote included.
This unit is less than two years old and functions the same as the day it was new. This Candela has been used exclusively in a dedicated listening room which is smoke free and pets have never entered this room. It comes with remote and will be sent in original Odyssey box and packaging. The manual is provided via a link to the Odyssey website (see below). There is one small scratch on the rear of the case that is virtually undetectable from more than 12 inches away (see photos). Otherwise, it is cosmetically clean with no dents (note: the case has a brushed aluminum finish).
I am the original owner and Odyssey provides a 20 year warranty which is transferable to the second owner.
I have little activity here as I typically don't have much to say. You can verify my 100% rating on eBay with the same screen name (la10slgr).
Odyssey offers a “check-up” service in which they check the bias, offset, connections and power supply. Prior to this listing, I took advantage of this service and sent it to them for inspection so it will be coming to you as “factory fresh” as possible directly from Odyssey. Odyssey received the shipment 2-21-2020 and will ship as soon as the check-up is complete
Information from Odyssey’s website:
http://odysseyaudio.com/index.html
model specifications:
• “Current Source Loaded Grounded Cathode Amplifier" based design
• Vacuum Tube single ended stages
• Class-A single ended configuration
• Zero feedback
• Low output impedance
• Low current design
• Relay-controlled input selector
• Power supply rectification using ultra fast-soft recovery “Stealth” Diodes
• (2) ECC82/12AU7 tubes
• 14dB gain
• Frequency Response 10Hz - 50kHz
• RCA type inputs & output
• 4 line inputs
• 1 input can be configured for HT bypass *
• Input Impedance 47 kOhm
• 1 pair preamplifier output
• 2nd pair of pre outs optional *
• Preamplifier output impedance: <2 kOhm
• High quality Alps potentiometer
• Remote control volume option available *
• >16 lbs weight / >7.25 kg
• Dimensions: 18 width x 8 deep x 4 height (in) /
• 45.7 width x 20.3 deep x 10.2 height (cm)
Odyssey User Manual
http://odysseyaudio.com/odyssey-unif...ersmanual.html
Odyssey Warranty
http://odysseyaudio.com/service-20yearwarranty.html
Name:	front and top.jpg
ID:	2688024   Click image for larger version
Name:	main image.jpg
ID:	2688026   Click image for larger version
ID:	2688028   Click image for larger version
ID:	2688030   Click image for larger version
Name:	rear inputs.jpg
ID:	2688034   Click image for larger version
Name:	front window.jpg
ID:	2688036   Click image for larger version
Name:	top aerial view.jpg
ID:	2688038   Click image for larger version
la10slgr is offline
post #2 of 26 Old 02-22-2020, 03:56 AM
Liked: 0
Interested
Would I work with Klaus for shipping if purchased?
GentleBender is offline
post #3 of 26 Old 02-22-2020, 06:25 AM - Thread Starter
la10slgr's Avatar
Thanks for the interest! I was thinking that would be something I would take care of but am amicable to whatever makes you most comfortable.
la10slgr is offline
post #4 of 26 Old 02-22-2020, 06:52 AM
Liked: 1
Hello, also very interested, do you accept PayPal?
joejoe571 is offline
post #5 of 26 Old 02-22-2020, 08:46 AM - Thread Starter
la10slgr's Avatar
Yes
la10slgr is offline
post #6 of 26 Old 02-22-2020, 08:52 AM
Liked: 0
How much for shipping? I have a PayPal account too.
post #7 of 26 Old 02-22-2020, 09:06 AM - Thread Starter
la10slgr's Avatar
I responded to your pm
la10slgr is offline
post #8 of 26 Old 02-22-2020, 09:18 AM
Liked: 1
Originally Posted by la10slgr View Post
Yes
Also interested in shipping information
Thank You
post #9 of 26 Old 02-22-2020, 09:26 AM - Thread Starter
la10slgr's Avatar
Thank You
Please send me a pm.
la10slgr is offline
post #10 of 26 Old 02-22-2020, 09:48 AM
Liked: 1
Hi, just sent a pm, not sure if you will receive, because it says you must have 15 posts to send a pm, just joined today, when I saw your ad on another site.
Thanks Joe
post #11 of 26 Old 02-22-2020, 12:27 PM - Thread Starter
la10slgr's Avatar
Thanks Joe
Hi Joe,
I sent you a pm, let me know if you don’t receive it.
la10slgr is offline
post #12 of 26 Old 02-22-2020, 01:13 PM
Liked: 1
Hi Joe,
Hi LA, the last pm I see from you is where you asked where else I saw your ad,I replied HIFI Shark, did you get that one....this sight is not to user friendly LOL!
post #13 of 26 Old 02-22-2020, 01:19 PM - Thread Starter
la10slgr's Avatar
i still have nothing from you.. However, if we keep this up, you'll probably hit your 15 posts in a matter of no time!!!! Glad you said hifishark as that was the only place I could think of that would reference this ad... whew!! A thought, I guess you could make a few more comments on this thread to get to your 15 then check to see if you can send/respond to messages...
la10slgr is offline
post #14 of 26 Old 02-22-2020, 01:26 PM - Thread Starter
la10slgr's Avatar
joe
just sent you another pm
la10slgr is offline
post #15 of 26 Old 02-22-2020, 01:27 PM
Liked: 1
Thanks LA I am really interested, I have a pair of Loreli's, and a Kahartago with Kismit upgrades, just need a Candela to drive!
la10slgr likes this.
post #16 of 26 Old 02-22-2020, 04:28 PM
Liked: 1
Do you use any other odyssey components?
post #17 of 26 Old 02-22-2020, 05:22 PM
Liked: 1
I tried to find you on EBay, no luck,probably not looking in the right around area.
post #18 of 26 Old 02-22-2020, 06:51 PM - Thread Starter
la10slgr's Avatar
I have a Khartago extreme.. great set up!
la10slgr is offline
post #19 of 26 Old 02-22-2020, 07:07 PM - Thread Starter
la10slgr's Avatar
see following image
la10slgr is offline
post #20 of 26 Old 02-22-2020, 07:15 PM - Thread Starter
la10slgr's Avatar
ebay rating
la10slgr is offline
post #21 of 26 Old 02-23-2020, 05:16 AM
Liked: 1
What are you using for a preamp now?
post #22 of 26 Old 02-23-2020, 05:17 AM
Liked: 1
Where are you located?
post #23 of 26 Old 02-23-2020, 08:44 AM - Thread Starter
la10slgr's Avatar
Hi Joe,
I responded but it seems a handful of posts got deleted, very weird... quick version:
1. I wanted Hdmi and surround sound capabilities so I got a marantz processor. I think the Candela sounds better when comparing the two as the build quality definitely shows.
2. Colorado, but like I said, the Candela will be coming to you directly from Odyssey
3. Seeing as how one of the deleted posts mentioned you wanted to make this happen, I will send you another pm to discuss purchase details
la10slgr is offline
post #24 of 26 Old 02-23-2020, 09:42 AM
Liked: 1
Hi,sending you an email now,
Joe
post #25 of 26 Old 02-23-2020, 11:55 AM - Thread Starter
la10slgr's Avatar
Sale pending
la10slgr is offline
post #26 of 26 Old 02-25-2020, 05:23 PM - Thread Starter
la10slgr's Avatar
Sold
la10slgr is offline
Reply Audio Gear
candela , odyssey , preamp , stereo , tube
