6x6 HDBaseT AV Matrix - 100m (4K @ 60 up to 70m) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-04-2019, 11:26 AM - Thread Starter
Rise & Grind
dinamigym's Avatar
Quoted: 321 Post(s)
Liked: 290
ELAN Essentials EL-4KPM-V66-A1812
Brand New in box original owner asking $2500 OBO. I moved before installation.
EL-4KPM-V66-A1812 Features at a Glance
Advanced HDBaseT technology offering uncompressed video and audio with zero latency
Features 6x HDMI inputs which can be independently routed to 6x HDBaseT + HDMI outputs
Simultaneous HDBaseT and HDMI outputs to allow connection to dual displays per zone
Input 1 supports dual HDBaseT & HDMI to enable integration of remote HDMI sources up to 1080p 70m distance (4K up to 40m)Up to 18x12 Audio Matrix independently controllable from video
- 6x independent analog L/R audio inputs which can be routed to audio outputs or embedded onto HDBaseT/HDMI outputs
- HDMI audio breakout to Coaxial digital and analogue L/R audio outputs with variable pre-amp line level control
- Supports ARC (Audio Return Channel) via HDMI and Optical digital inputs from compatible EL-4KHDBT-RX-70-E-ARC-IRS receivers
Extends HDMI up to distance of 100m over single CAT cable
Supports 4K UHD video up to 70m (3840 x 2160 @30Hz 4:4:4, 4096 x 2160 @24Hz 4:4:4, and 4K @60Hz 4:2:0)
Supports all industry standard video resolutions including VGA-WUXGA and 480i-4K
Supports 3D signal display
Supports all known HDMI audio formats including Dolby TrueHD, Dolby Atmos, Dolby Digital Plus and DTS-HD Master Audio transmission
Integrated Ethernet switch (LAN Serving) when used with EL-4KHDBT-RX-70-E-ARC-IRS (sold separatley). EL-4KHDBT-RX-70-E-ARC-IRS features a 3 port 10/100 Ethernet switch
Web interface module for control and configuration of Matrix
Supports bi-directional RS-232 from all input and output locations (with compatible transmitters & receivers)
Supports bi-directional IR from all input and output locations
Includes 6 x 5v-to-12v IR converter cables for IR Input and 2 RS-232 control cablesControl of Matrix via front panel, IR, RS-232 and TCP/IP
Supports PoH (Power over HDBaseT) to power compatible HDBaseT transmitters & receivers
3rd Party drivers available for all major home control brands
Advanced EDID management
HDCP 2.2 compliant
2U Design for 19" rack mount integration - Mounting kit included
dinamigym is online now
post #2 of 2 Old 01-10-2019, 08:09 AM - Thread Starter
Rise & Grind
dinamigym's Avatar
Quoted: 321 Post(s)
Liked: 290
HDCP 2.2 compliant
Price drop to $2000 OBO.
Trinnov Altitude 16, Magico A3, Magico ACC, Magico A1s, Dual Rythmik FV25HP
Amps- ATI AT523NC, AT524NC, AT528NC
Kaleidescape Terra Server/Strato, Oppo UDP-203, Apple TV4k, XFinity X1
Sony VPL-VW5000, 136" 2.35:1 Stewart Studiotek 100 screen, Lumagen Pro 4242
Reply Video Source Items
