Faroudja NRS-DCS Digital Cinema Source DVD Video Processor - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-01-2020, 07:07 PM - Thread Starter
tbase1's Avatar
Quoted: 72 Post(s)
Liked: 77
Up for sale is a friends ultra high end dvd/cd video processor.......My friend had this installed in his home theater new. However, he's moving to high end 2 channel, so this is up for sale.
Unit and power cord only.....unit was controlled with a AMX home control system
$250 shipped
The NRS-Digital Cinema Source is designed for a high-end, big-screen system, where its video benefits will be most obvious. Most inexpensive scalers use widely available video processing chips, but Faroudja uses its own proprietary chips, which from past experience we know to provide excellent picture quality. The DVD player itself also benefits from high-end design touches, intended to reduce interference and improve picture and sound quality. Besides being able to use the DVD player, you can plug in all of your other video sources so they get the benefit of the NRS scaling.
The new NRS-DCS processor maximizes the benefits of digital video and audio from DVDs by incorporating a DVD drive within a full featured Faroudja video processor.The digital video is sent directly to the internal patented digital processing stages where the signal is deinterlaced, optimized and scaled up to the display's native resolution without leaving the digital domain. Additional circuits improve edge detail and color fidelity. This optimized signal is then sent to the display via a pixel accurate DVI (Digital Video Interface) output for a stunning video image. A full set of analog video inputs are also included so all your standard video sources can be digitized and scaled to the native resolution and sent via the DVI output. This includes satellite, cable, video games, camcorders and VHS. The audio performance from the DCS will impress the most demanding audiophile. Faroudja has applied a proprietary audio stage optimized for both audio for video and audio CD use. Low jitter crystal oscillators, multiple power supplies, RF suppression filters, special shielding and AES/EBU digital connectors all combine for an audio performance rivaling the most expensive CD-only transports. Faroudja is the reference of excellence for video.
Internal DVD drive allowing for direct access to the digital video
DVI and RGBHV/YPrPb Output from internal DVD and analog sources scaled to the native resolution of the display
Separate inputs for analog interlaced NTSC/PAL video sources (composite, S-video, YPrPb, RGB, Pass-Through)
Optimized for digital displays
Three digital audio outputs: AES/EBU, Coaxial (BNC & RCA)
DVI Pass-Though for installation flexibility
HDTV pass-through for installation flexibility.
Audio timing is reclocked and aligned for correct audio-for-video syncronization
Independent audio and video circuits with Integral RF suppression to reduce interaction between the different circuits.
Separate extremely low jitter crystal oscillators for DVD and CD audio frequencies
Isolated display and motor controllers with six highly filtered and regulated power supplies
Patented 3/2 Pull-down with advanced edit detection for error free deinterlacing of film originated sources
Patented DCDi (Directional Correlational Deinterlacing) for error free deinterlacing of video originated sources (such as sporting events)
Patented True Life Bandwidth Expansion for dramatic improvement in image detail
Aspect ratio control for proper image sizing on all screen types
Image positioning controls for installation flexibility
HD Transcoding YPrPb to RGBHV
Test pattern generator to assist with system setup
Direct Infrared commands for improved interface with control systems
ID:	2662552   Click image for larger version
tony4k
tbase1 is offline
Reply Video Source Items
