DC Area/NOVA - Salamander Synergy Triple - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-13-2019, 08:59 PM - Thread Starter
nhpm510's Avatar
Quoted: 24 Post(s)
DC Area/NOVA - Salamander Synergy Triple $125
Salamander Triple AV Console - walnut
Originally $1,100 - yours for $125
Has a couple of minor imperfections from moves - nothing terrible.
Heck, the wheels are worth the $125.
The Synergy System is a fully modular furniture system that takes the concept of customization to a whole new level. Synergy allows someone to define a highly personalized piece of furniture that can handle any combination of electronic gear they come up with. The patented design permits a virtually limitless number of customization possibilities, so anyone can create something that is uniquely their own. The line is constructed of the finest materials, such as real hard woods and durable anodized aluminum support posts. Since its introduction, the Synergy System has set the standard for what A/V furniture should be.
Triple units provide plenty of space for audio/video collections, including your new plasma monitor. The unit comes with fully adjustable black shelves, and includes a removable black rear panel that has been sized to allow cables to pass over and/or underneath it.
Features:
Snap-on Hinges fully extend doors and remove easily for better in-cabinet access
Soft-Close Doors makes door closing smooth and quiet
Perforated Door Inserts permit IR signals, add ventilation and mask speakers
Infinitely Adjustable Shelves
Removable Rear Panel allows easy access to A/V components
Precision Leveling Feet keep the cabinet level even on uneven floors (multiple foot options available)
Name:	6911 Cardinal Hill Pl West-046-34-Recreation Room-MLS_Size.jpg
nhpm510 is offline
Reply Accessories
