QualGear Pro-AV QG-KIT-CA-3IN-B Projector Ceiling Mount w/2 ft drop pipe - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-15-2019, 06:05 PM - Thread Starter
ttamez's Avatar
I ordered this mount along with a 2 ft drop pipe but ended up going with a wall mounted projector mount instead of ceiling because of where I needed to put the projector. Part number for the pipe is QG-PRO-PM-2FT-B. I mounted it for a week but the projector location didn't work out (A/C vent was in the way where mount should've been). Includes the 3" drop pipe that came with the mount and all mounting hardware. This is a mid duty mount that has a 70lb weight limit. Much better than some of the cheaper mounts which are flimsy and rock the projector if you just bump it.
This is the item on Amazon: https://www.amazon.com/QualGear-QG-K...dp/B01B1JFLV6/
$50 shipped.
ttamez is offline
Reply Accessories
