FS: Monoprice Stealth Motorized Projector Mount-New in Box! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-20-2020, 09:07 PM - Thread Starter
KASOFO's Avatar
Quoted: 73 Post(s)
I am selling a brand new, never installed Monoprice Stealth Motorized Projector Mount. The mount is new and will ship in the original box. Specs are listed below. The new retail is $849.99 so there are some pretty big savings to be had. Price is $380.00 plus 3% if paid with PayPal. I will ship it at my expense or local pick-up in the Chicagoland area.
Easily fits into 2' x 2' ceiling opening and drop ceilings. Exceptionally smooth and quiet movement, these are excellent in-ceiling projector mount choices for homes and corporate offices. Bottom plates are easily finished with materials to blend with any décor.
Fits most installation requirements, needing only 12" of clearance above the ceiling. User defined descending limit to 36". All metal construction means years of solid reliability.
Preinstalled cable loom protects and keeps cables neat and clean for a professional look. Accommodates any small to mid-size projector up to 44 lbs.
Construction hardware and power cord included.
Features:
Replaceable ceiling decoration board allows you to match ceiling texture and material for seamless install
Electric positioning pre-set for max dissention
Integrated cable management keeps cables neat and clean and out of the way of moving parts
Use with large scale projectors up to 44 lbs.
Model 15495
Input Voltage 110 VAC, 60Hz
Input Current 1.47 amps
Power Consumption 170 watts
Motor Torque 20 N•m
Motor RPM 17 rpm
Maximum VESA® Pattern 500 x 500
Maximum Inverted VESA Pattern 300 x 340
Minimum Extension 11.2" (285mm)
Maximum Extension 78.8" (2000mm)
Dimensions 23.4" x 23.4" x 11.8"(595 x 595 x 300 mm)
Weight 41.9 lbs. (19.0 kg)
Maximum Projector Weight 44.0 lbs (20.0 kg)
ID:	2673238   Click image for larger version
ID:	2673240   Click image for larger version
ID:	2673242   Click image for larger version
ID:	2673244   Click image for larger version
ID:	2673248   Click image for larger version
Name:	154951 - Copy.jpg
ID:	2673252   Click image for larger version
Marantz 8802A Processor, Wyred4Sound SX-1000R Monoblocks X 3, Emotiva XPA-7 Gen3 Amp, Oppo 205 Ultra HD/Blu-Ray Player, JVC-DLA RS620U Projector, Dark Energy 127-Inch ALR Screen, Tekton Ulfberht’s Mains, Tekton Ulberht Center, Def-Tech SR8080-BP Surrounds (4), Seaton Submersive F2+ and F2 Slave Subs, Two Seaton F18+'s subs, Power Sound Audio S3010 sub, 4 ADX Maximus Bass Shakers
KASOFO is offline
post #2 of 3 Old 01-23-2020, 12:44 PM - Thread Starter
KASOFO's Avatar
Quoted: 73 Post(s)
Price lowered-$340.00 and bump per forum rules
Features:
Model 15495
Motor Torque 20 N•m
Motor RPM 17 rpm
KASOFO is offline
post #3 of 3 Old 02-13-2020, 07:17 AM
lotr07's Avatar
PM Sent
Johnny
lotr07 is offline
Reply Accessories
