CasaTunes xli 6room audio card - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-08-2019, 04:42 PM - Thread Starter
hyeguy's Avatar
$300
Pulled this from a working system. I am the original owner and bought it new. You will have to download the software from casatunes. Their help and service is excellent. They will help you get everything working correctly. Supports up to Windows 7. No support for windows 10 but I had it working with windows 10.
please ask any questions
CasaTunes XLi is a simple single card whole house audio solution
for an experienced integrator looking for a cost efficient whole
house audio system for their clients. Included is an advanced DVDaudio
quality PCI-e sound card with a built in matrix switch that has
the capability to output music in up to 6 rooms. To complete the
installation add a CasaTunes XLa or other multi-channel amplifier
and speakers of your choice.
With the CasaTunes XLi, you can listen to as many as five different
audio programs in up to six rooms. The CasaTunes XLi has four
built-in, ready-to-go internal music sources and an input for one
external source. Each internal source is able to play back music
from your iTunes Plus library and/or Microsoft Windows Media
Player library, as well as music from an iPod and SHOUTcast™️
internet radio. The external sources typically come from an AM/FM
tuner, XM or Sirius satellite radio or other external music source.
With the CasaTunes software and the built-in hardware switch, you
can listen to different music in different rooms in the house or you
can set up “zone groups” which allow several rooms to be
controlled together.
Works with the iPhone app, CasaTunes Keypads and Internet
browsers for control.
Listen to 5 different audio
programs in up to 6 different
rooms or the same music in
perfect sync in all rooms
 Four built-in ready to go internal
music sources able to play back
music from your Microsoft
Windows Media Player Library,
iTunes library, iPods and
SHOUTcast™️ Internet Radio. You
can add your own additional
internet radio stations
 Listen to a single external source
(AM/FM tuner, XM or Sirius
satellite radio or many other
external music sources)
CasaTunes XLi Specifications
Requirements PC PC with open PCI-e X1 or greater slot
Microsoft Windows XP Professional
Operating Systems Windows XP Media Center Edition
32bit or 64 bit Vista Home Premium, Business or Ultimate
Windows 7 Home Premium, Pro or Ultimate
Windows Home Server
Server 2003, 2008
Environment Operating Temp 0 deg C to 40 deg C (32 deg F to 104 deg F)
General Frequency Response +- 0.5dB, 20 to 20khz
Signal to Noise Ratio > 100 dB
THD THD 0.03% or less
THD+N THD+N 0.05% or less
IMD IMD 0.03% or less
Output Level 3.2V p-p, max
Connectors Outputs 3.5mm jack (3.5mm to RCA cables supplied)
External In 3.5mm Jack for one ext. audio devices
hyeguy is offline
Reply HTPC Computer Items
